Viggen vs 9-3 brake master cylinder. - The Saab Link Forums
Old 04-27-2006, 01:43 PM   #1
http://www.thesaabsite.com/93/93Brakes.htm
Anybody know why the Viggen master cylinder wich is supposed to be better, would cost alot less than a standard 9-3 master cylinder.
Also, the fluid resevoirs seem to be the same for Viggen or standard 9-3. True?
Old 04-27-2006, 01:55 PM   #2
Trollerator
abdukted1456's Avatar
I bet you NickT knows this one.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 04-27-2006, 02:14 PM   #3
guru's Avatar
Ok, now I have to ask the really dumb question: why would they use a different brake master cylinder?
guru is offline
Old 04-27-2006, 02:17 PM   #4
Bigger brakes.
Old 04-27-2006, 02:20 PM   #5
DeLorean's Avatar
check EPC.
DeLorean is offline
Old 04-27-2006, 02:26 PM   #6
guru's Avatar
Originally Posted by Tweek's Turbos
Bigger brakes.
That's what I assumed, but I wasn't sure. Thanks
guru is offline
Old 04-27-2006, 02:36 PM   #7
iwantaviggen's Avatar
its good to ask.. others are mostlikely wondering the same thing!
now will it be overkill on a non viggen brake set up?
iwantaviggen is offline
Old 04-28-2006, 07:20 AM   #8
The calipers are the same sized, its just the rotor is bigger. So nobody knows?
My epc isn't loaded, I'm trying to buy a new comp.
Old 04-28-2006, 09:02 AM   #9
dip
dip's Avatar
Send a message via Skype™ to dip
I don't have a clue why the price is that much lower, but the Viggen uses the master cylinder, reservoir and other associated hardware from a 9-5. The idea obviously was to adapt it for bigger brakes. The brake fluid capacity on the Viggen is also higher than on regular 9-3s (in the whereabouts of 900 ml vs 600 ml).
I also remember Nick saying that the stock NG900/9-3 master provides better stopping. Maybe it's out of context, so you better take it to him.
dip is offline
Old 06-04-2008, 06:39 PM   #10
mg_td's Avatar
so whats the total fluid capacity of my viggen brake system? its not listed in the manual.
238.8 whp 272.1 wtq
mg_td is offline
Old 06-04-2008, 08:12 PM   #11
NahumCC's Avatar
I asked this a while ago and Nick talked about it. You can't use the viggen mastercylinder on the standard 9-3.
Dimtry your right about what you just said with the standard ng900 and og9-3's capable of higher brake pressure. Nick said that the larger bore of the viggen master cylinder reduces the benefit of the stronger accumulator from the 9-5. I'll see if I can find the thread.
2013 FR-S
NahumCC is offline
Old 06-04-2008, 08:15 PM   #12
NahumCC's Avatar
Found the thread. Here is the link.
https://saablink.net/forum/showthread...aster+cylinder
2013 FR-S
NahumCC is offline
Old 06-05-2008, 06:33 AM   #13
Nick Taliaferro
GenuineSaab's Avatar
Vig uses RHD 9-5 master.. Has a special block to turn the reservoir to clear the delivery pipe. Also uses the 9-5 brake booster with 2 stages. Since the caliper pistons are the same there is no real reason to do this other than getting more assist and making it a bit easier to modulate. I personally like the feeling of the 9-3 brakes, the 9-5 booster is so flexy that no matter what you cant get a solid pedal.. I am comparing this to my V4 with non boosted brakes. The pedal is rigid in that old car.
Nicholas Taliaferro
GenuineSaab is offline
Old 06-05-2008, 06:53 AM   #14
This is pretty critical information. I know when my brake servo went out on my Viggen I was facing a huge price for a new one. I ended up getting one from a wrecker, but I believe the list price for Viggen servos are way more than 9-5 or 9-3 ones.
nbndtrain is offline
Old 06-05-2008, 06:56 AM   #15
I don't have your fancy big brake kit up front but I have a good setup over all. My biggest let down is the lack of a firm pedal. The brakes have been bled correctly over the years I have owned it. I was told the pedal is as good as any other Viggen's. If thats the case, thats dissapointing. The bite is certainly there, especially with a true performance tire like the Azenis 615.
Jameson is offline
Old 06-06-2008, 11:04 AM   #16
Yes, having the full package brakes done finally, I don't think the feel, and effect can be improved any more (cost effectively).
