Flywheel - to resurface it or not... - The Saab Link Forums
Old 09-27-2013, 04:18 AM   #1
So, replacing the clutch.
Got the old off and was surprised to see how clean/smooth the flywheel is.
Still can see semblance of the original machining.
Since my machine shop wont lighten it (they don't want to be responsible for future cracking etc.) - I am not sure whether I really need/want to have it machined.
Its doesn't cost much, money isn't the issue. But it doesn't "seem" like its needed.
Thoughts?
Thanks,
Andrew
Ashbypa is offline
Old 09-27-2013, 08:25 AM   #2
lms
Do it, it's one of those while you are in there things. I did not once and regretted it.
lms is offline
Old 09-27-2013, 08:58 AM   #3
9ryan3viggen's Avatar
Do it, it is cheap and a MUST DO.
9ryan3viggen is offline
Old 09-27-2013, 02:36 PM   #4
if surface is not gouged up leave alone i never mechined flywheel ever leave alone
daniel is offline
Old 09-27-2013, 03:22 PM   #5
Thanks. I ended up taking it in. For 40 bucks it was piece of mind.
However the shop owner was able to show me that while it looked clean and flat, it was actually worn at a very minor angle - like a cone. More space on the outer edge than inner. While minor, it'll be good to be perfectly flat.
Now how to pull the rold rear main seal....
Thanks again
A
Ashbypa is offline
Old 09-27-2013, 08:12 PM   #6
bogan's Avatar
Read page one of this .. It has how I replaced my rear main seal .. a while back
https://www.saablink.net/forum/perfor...-9-3/59597.htm
bogan is offline
Old 01-10-2014, 03:45 PM   #7
What is a typical cost to expect to pay for a surfacing of the flywheel and typical cost of a lightening of the flywheel?
Progression is offline
Old 01-10-2014, 04:30 PM   #8
pretty sure it was 50. They should resurface the clutch contact surface as well as the pressure plate mounting surface to maintain dimensions.
Ashbypa is offline
Old 01-10-2014, 04:59 PM   #9
Drew in Houston's Avatar
Always always always always resurface your flywheel when replacing your clutch. Always.
Drew in Houston is offline
Old 01-11-2014, 03:47 AM   #10
bogan's Avatar
yeap ...resurface 100 %
bogan is offline
Old 01-17-2014, 10:09 AM   #11
8valvegrowl's Avatar
Maybe 4 years back I had my flywheel resurfaced and lightened by 3 lbs (from 15 to 12, the most that the machinist was comfortable removing from the back side) for about $90 IIRC.
I was upgrading to a Viggen clutch for my Stg3 2.0, so I wanted to do everything once.
I agree with most of what's been said here. Always, always resurface.
8valvegrowl is offline
Old 01-17-2014, 03:57 PM   #12
lightened flywheels
Mail in lightening for about 200. I'm planning on sending the v6 one in (it is super heavy). I can't find anybody local that will do it that I feel comfortable with. These guys (I've called them) seem like they know what they're doing.
Might be out of service for a bit if it is you dd.
Tboy is offline
