Replacing E-brake lines - The Saab Link Forums
Old 08-14-2013, 07:40 PM   #1
I'm going to replace the ebrake cable (the whole thing). The P.O. had cut it on the drivers side a bit before the hook.
I don't see the spring that attaches to the mechanism on the outside either.
I was wondering as the ebrake has not been used in what I'm assuming as a few years, what else should I pick up that is necessary to a complete job?
From my understanding there is a drum brake on the inside of the disk brakes, should I find some new shoes? If I need to replace the rear disks soon, would it be easier to just get it new together?
I'm trying to save money, but I would like to use all "new" peices.
I'm looking for a nice sharp ebrake in the end, you know, for spirited winter driving, lol.
Also a picture tutorial would help immensely. Platinoff didn't seem to have one. Thanks
, I am trying to get it off the ground so likes are appreciated!
Volvo802 is offline
Old 08-15-2013, 06:33 AM   #2
ninehundredt's Avatar
The easiest way to remove the old cable is with a pair of bolt cutters. Will save you a lot of time and headaches. As for the actual emergency brake assembly I would remove the rotor and inspect the shoes and springs before dropping $50+ on a rebuild kit. Otherwise it's not too hard to replace the springs and pins with a little patience.
ninehundredt is offline
Old 08-15-2013, 08:32 AM   #3
srp
srp's Avatar
Send a message via AIM to srp
Some good info: https://www.saablink.net/forum/car-pr...only/17816.htm
Most of the parking brake hardware inside the drum can be refurbed with a wire wheel and some high temp grease. Parking brake pads typically last the life of the car unless something has failed.
Be-careful with using the parking brake for some quick turns, there is a bracket midway back in the trans tunnel that is held on with some small spot welds that holds the cables. It will rip off under force.
srp is offline
Old 08-15-2013, 09:38 PM   #4
Sounds good. Ill actually likely pick up a rebuild kit for both sides, and keep it with me just in case (return it otherwise). Do you think there is a spring (the one on the outside that attaches to the little eyelet to keep it disengaged) will be in the kit?
Most of the parking brake hardware inside the drum can be refurbed with a wire wheel and some high temp grease. Parking brake pads typically lasts ife of the car unless something has failed.
Awesome, not sure how I missed that sticky! Too bad he didn't do it while his girlfriend was driving this car (bought it from Nick, btw hi Nick I know you're probably reading this, hehe) have a dremel set, so ill try and pick up some hi-temp grease too while I'm out. Would having said bracket welded on a bit more solid be worth it?
Hopefully a clean up will work, but I'm never too optimistic on VT cars.
Volvo802 is offline
Old 08-16-2013, 05:11 AM   #5
The kits cover both sides:
Saab Parking Brake Hardware Kit - eEuroparts.com 101K10048 - Free Shipping
Check around for the external parts. I'm sure they can be picked up somewhere if your concerned about them.
Old 08-16-2013, 05:57 AM   #6
srp
srp's Avatar
Unfortunately, the parts that normally seize up are not included in the kit.
Pad expander:
90495967 Genuine Saab - Parking Brake Cable Dust Seal - Free Shipping
90496947 Genuine Saab - Parking Brake Expander Shackle - Free Shipping
90111317 Genuine Saab - Parking Brake Expander Arm - Free Shipping
90075839 Genuine Saab - Parking Brake Expander Pin - Free Shipping
Pad adjuster:
90075042 Genuine Saab - Parking Brake Shoe Adjuster Screw - Free Shipping
90075044 Genuine Saab - Parking Brake Adjuster Shoe Sleeve - Free Shipping
90075043 Genuine Saab - Parking Brake Shoe Adjuster Screw - Free Shipping
My pad expander and adjuster were both seized along with my parking brake cables being fubared. Luckily I was able to take them apart, clean them up and reassemble.
srp is offline
