no start after wash - The Saab Link Forums
Old 08-12-2013, 07:21 PM   #1
saabfan9's Avatar
no start after wash
hey guys I have a 2000 9-3 se with a 2.0 turbo, 90,000 miles ran fine until I had the porters at work clean the car up (yes under hood as well) I know anything can happen but these guys clean our dealership cars all day/every day so this was nothing out of the ordinary for them..... well they could not get the car to re-start fuel pressure good 40+ psi I swapped the DI with my 9-5 aero close inspection of all connectors no signs of any water and no codes...i'm going to let the car sit over night to "dry" out....any other ideas? thanks for the help guys ......forgot to mention all fuses good, pulled the plugs yes old but the car was running fine a 1/2 hour prior nothing out of the ordinary as far as raw fuel did get a slight smell out of the tail pipe....not sure what else to check
saabfan9 is offline
Old 08-13-2013, 04:02 AM   #2
Turbo00's Avatar
When you say doesn't start, it just cranks and doesnt catch?
I'm betting it's not that water got somewhere, it's that they knocked something loose depending on how much scrubbing they did. Double check the main wiring harness & all connections, special attention to the DI, MAF, BPC, etc. Never know, may start after drying out. Could also be an unrelated issue like CPS that just happened to manifest at a weird time.
Turbo00 is offline
Old 08-13-2013, 04:32 AM   #3
saabfan9's Avatar
looked around I didn't see anything out of ordinary I was hoping to see a fault code develop... oh sorry yes she just cranks, I have my 2005 9-5 aero that I could try a few parts (like the DI)
saabfan9 is offline
Old 08-13-2013, 05:58 AM   #4
There's not much that would cause it to no-start.
I'd start with the crank sensor. check the connector up at the throttle body. It's the blue one. pull it apart, and make sure there's not water shorting it out. a bad CPS will cause the injectors to not spray, and it won't start.
Even with a bad/unplugged MAF, it'll start.
The DIC could cause a problem, but it's less-likely. you can usually listen after you turn off the car for the cleaning phase. if you hear that, I'd say you're alright.
Also, if one of the coils were bad, it'll usually start/idle fine, but driving doesn't work.
in bad cases, if a coil is bad, it'll start and run like crap... but will still run.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 08-13-2013, 06:54 AM   #5
They should have washed it while it was running.
Ditto on the CPS connector. I would disconnect all the harness connections one by one, spray with any water displacer, and reconnect....
It might run rough for a few minutes...
Old 08-14-2013, 06:59 AM   #6
saabfan9's Avatar
very cool thanks for the leads guys...where is the crank sensor located ? can I get to it from the top or bottom?...... went out to the car tues morning started right up all day long no problems go out to the car today again cranks no start no rain no moisture i'm guessing not related now...no codes, fuses good, good fuel pressure, swapped di's with my 9-5..... any ideas?
saabfan9 is offline
Old 08-14-2013, 08:31 AM   #7
If you're looking at the car from the top front, the crank position sensor is located on the front of the block, right side near the tranny, about 4 inches up from the oil pan. There's a black wire that links it to a connector on the right side of the engine, top, just behind the head.
Old 08-14-2013, 12:11 PM   #8
saabfan9's Avatar
no start monday,tuesday starts run/drives like nothing happened, i had assumed it was wet, now dry working just fine..wed. again no start i did find water in that blue connector but nowhere else, cleaned and dried, still no start (just cranks) no rain or moisture in the air...so i'm not sure if it is related to getting the engine compartment wet....if it was a crank position sensor (or signal) you would think i should have a code since it is the main input to the pcm
saabfan9 is offline
Old 08-14-2013, 12:55 PM   #9
saabfan9's Avatar
since there is no codes could a theft security issue be a problem?
saabfan9 is offline
Old 08-15-2013, 05:40 AM   #10
saabfan9's Avatar
not seeing any voltage at the crank sensor/pcm connector
saabfan9 is offline
Old 08-15-2013, 08:24 AM   #11
I have had two crank sensors fail and never saw a CEL. One failed a few times and would work when it cooled off - again, no CEL. The other one just straight crapped out, also, no CEL.
Is your fuel pump OK too? Do you hear it when you key ON?
BuHuSPG is offline
Old 08-15-2013, 10:28 AM   #12
WSW
WSW's Avatar
Ohm out the cps
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 08-16-2013, 06:48 AM   #13
saabfan9's Avatar
I tried multiple combinations of the 3 wires for the crk sensor everything was zero ...so now I get the fun job of a crk sensor right?
saabfan9 is offline
Old 08-16-2013, 07:04 AM   #14
It's certainly one of the easiest things to replace. My advice...use a wire brush and brake cleaner to clean the rust and grossness from around the crank sensor before you remove it. That hole goes directly to the crankcase. You don't want that junk falling in.
Craig R.
g96nt is offline
Old 08-16-2013, 09:00 AM   #15
WSW
WSW's Avatar
Ohm out the crank sensor itself and spray connectors with contact cleaner
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 08-16-2013, 09:49 AM   #16
saabfan9's Avatar
tried to ohm out sensor got all zero's in any combonation of the 3 wires spec is something like 540 ohms..... now i was trying this morning to get the sensor out and i'm a tech so i have decent patience but that thing was kicking my ass this morning
saabfan9 is offline
Old 08-16-2013, 11:05 AM   #17
WSW
WSW's Avatar
Bad cps then. Mine was shorted internally and read ol when I ohmed it.. Start spraying pb blaster at the Cps area.. Stupid t25/30 screw they used will probably strip
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 08-16-2013, 01:48 PM   #18
Aikmanson's Avatar
CPS is a very easy job. Do yourself a favor and just order one, it will go bad eventually anyways.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Aikmanson is offline
Old 08-16-2013, 03:49 PM   #19
saabfan9's Avatar
... yep i think thats the road i was heading down have to come at it again with different stuff (assortment of tools)
saabfan9 is offline
Old 08-16-2013, 10:13 PM   #20
N.A.S Story's Avatar
If its your crank sensor you'll notice no tach bounce when cranking.. Like they said these fail regularly
Sent from AutoGuide.com Free App
N.A.S Story is offline
