oil recommendation - The Saab Link Forums
Old 02-07-2006, 12:04 PM   #1
trexturk's Avatar
Send a message via AIM to trexturk
oil recommendation
Hey guys, im really thinking about switching my oil from regular to full synthetic.
I just got the nordic stage 3 and i know that im gonna be beating on my car more this year
Would you guys recommend the switch?
How often would you change the oil?
I'll prolly be using mobil1 10-30.
Thanks
Now: 04 Nogaro S4
Past: 99 Stage 4 9-3
trexturk is offline
Old 02-07-2006, 12:17 PM   #2
WyldSaabMan's Avatar
mobil one is some good stuff.
I know people are going to yell at me, but I once waited 8000 miles to do an oil change...things were hectic...anyway I was down barely half a quart...which is way in spec, and the oil didn't look very dirty at all.
2 months ago I dropped the pan when I had the subframe off, there was so sludge whatsoever and the pickup screen was free of any crap. I have been using mobil one ever since I got the car at 66k miles. It now has 96 its good stuff!
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 02-07-2006, 12:28 PM   #3
saabkid37's Avatar
i switched to mobil 1 when i got stage 4...its good. I go 3-5k miles while im at school but home ove rthe summer its a strict 3k. Couple tiny leaks showed up tho because the synthetic causes the gaskets to swell...nothing major tho...
some of my high hp buddys went back to a semi synth blend...not sure as to the reasoning tho...
saabkid37 is offline
Old 02-07-2006, 12:48 PM   #4
Trollerator
abdukted1456's Avatar
I always get the full synthetic every 3000-3500K.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 02-07-2006, 01:16 PM   #5
StX221's Avatar
up until now, i have driven 20k miles and used mobil 1 every 2-4k miles (depends on driving styles, condition, all that jazz.) if i make it mostly highway, i'll let it go up more towards 4k, but usually right around 3k is good.
I am going to buy a case of amsoil european special blend (or whatever its called) 5w-40. its apparantly really good stuff and i want to run it a few times through. i had the pan dropped at about 70k miles and it was clean as clean can be. i am not too worried about having a sludged up engine anymore.
i would definitely reccommend full synthetic oil just for its benefits, even if its not required by an auto manufacturer. the extra 10-15 bucks per oil change is well worth it.
Nick
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 02-07-2006, 01:18 PM   #6
mcrowley's Avatar
Paul at Automotion told me he's had problems with CEL's in cars running Mobil 1 and suggested I use Kendall or Castrol full syn or something similar. I usually change mine every 3-4 months since it takes me about that long to rack up 3000 miles.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 02-07-2006, 02:00 PM   #7
CooperS7777's Avatar
Not to hijack a thread, but any thoughts on switching over a NG900 with 96k on it now?
Ive had it since 60k and havent had any issues - at the time there was huge debate about switching over and I chose to stick with what I knew.
-Coop
CooperS7777 is offline
Old 02-07-2006, 02:13 PM   #8
trexturk's Avatar
thanks for the reply guys,
I have about 107k now, but close to 65k on the engine.
How would you guys suggest doing the swap?
Now: 04 Nogaro S4
trexturk is offline
Old 02-07-2006, 05:38 PM   #9
Editor
I just recently made the switch, about the gasket and seals comment, I've also heard since it's a thinner consistently they can swell and you can see some leakage on the block... however, I JUST did a head re-torque, and I can confidently say I have ZERO oil on my block since I changed the oil. I've run a synthetic blend since I've owned the car, and it was the same with the previous owner. I have 132 on the clock. From what I've been told, it can't HURT anything, but since it's this far gone, the effects of life longevity won't be AS noticeable just because we're already getting down the road a little bit... anyway, maybe it's in my head, but it feels like things are lubricated better with the stuff... doesn't Saab recommend synthetic in the turbo'd cars?
Les Bouquins is offline
Old 02-07-2006, 05:39 PM   #10
Editor
-Coop
It couldn't hurt. If you see some residual oil on the block though, don't worry. Just make sure your level isn't dropping and you should be fine.
Old 02-07-2006, 06:03 PM   #11
iwantaviggen's Avatar
get post on that mr. unkept!
knowledge for the brain...
you all have a lot of miles on them cars.. not that its bad.. but man i hate putting miles on mine...60k right now and i hate it...
and and Trex i hate you for the ECU upgrade!
iwantaviggen is offline
Old 02-07-2006, 06:08 PM   #12
JK
JK's Avatar
I always start using it in my cars right off the bat regardless of mileage or oiul used by previous owners. Don't know what the others owners of my 1995 Aero had been using, but I have only put M1 5w-40 or 0w-40 in it and it runs great and at 3000 miles oil actually looks like what brand new non-synthetic looks like. Just a VERY light amber and my car has done over 190k miles! Last time I had the valve cover off it looked better than most 100k cars I have seen (I am guessing that the car has seen full synth most of its life).
I have had some issues with oil seepage after switching on some of my past cars, but it really seems like a small price to pay for an oil that I swear has gotten me better MPG and smoother idling motors in evey car that I've made the switch on.
always a SAAB guy at heart
JK is offline
Old 02-07-2006, 06:48 PM   #13
spgdude's Avatar
Send a message via AIM to spgdude
I use castrol syntec in my 95' aero, previous owner used a synthetic not sure what kind but no leaks. My 93' cse has had amsoil synthetic since 70k, now at nearly 300k with no oil seal leaks. Never had any bad experiences and the consensus seems to be that its better than non-synthetic so I figure why not.
77' Datsun 280z
02' 9-5 Aero B234/19t
07' 9-7x
09' 9-5 SportCombi 5mt Stg1
spgdude is offline
Old 02-07-2006, 07:46 PM   #14
Editor
It's just a car, man! It took me a long time to accept that fact, but it is just a car... I love 'em, you love 'em. Saabs are sweet, but it's meant to be driven.
Old 02-07-2006, 08:14 PM   #15
?? yu atlking bout the milage part??
yeah true but im OCD.. haha no im not but well probably am...
its like a pet peve wiff mee...
Old 02-08-2006, 03:21 AM   #16
mcrowley's Avatar
I don't think you're the only one who hates seeing the mileage tick away...I turned 50k about three weeks ago and I cringed when the digits rolled over in the odometer...oh well.
Same thing with my car. The synthetic just doesn't seem to get quite as dirty looking despite its better lubrication and detergent qualities.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 02-08-2006, 04:43 AM   #17
marky373's Avatar
Send a message via AIM to marky373
Ive heard pretty good about royal purple, and have been using it for the last 2 years ~20,000 miles. I have yet to hear anything bad about it.
marky373 is offline
Old 02-08-2006, 05:31 AM   #18
i dont mind seeing the milage pile on...I actually like it...just because I like seing my car being used, and performing great...and seeing the shock in peoples face, when i tell them how many miles I have...and all the shit I keep doing to it. And how it keeps working so well
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
Old 02-08-2006, 07:21 AM   #19
saab by goran's Avatar
Send a message via AIM to saab by goran Send a message via MSN to saab by goran
one off best oil
http://www.redlineoil.com/
SAAB By Goran ( Maptun stage 6 )
saab by goran is offline
Old 02-25-2006, 07:42 AM   #20
i swithced mine over at 93k from whatever the previous owner was using.(assume saab oil) to mobil one, so probably not a switch at all.
ricot83 is offline
