Trick to loosening the timing chain? - The Saab Link Forums
Old 06-07-2012, 07:17 AM   #1
Marks9-3's Avatar
Trying to pull the head, I've looked at one shitty diagram on how to loosen it and I can't make rhyme or reason out of it.
I have the timing all lined up already, just need to get the slack off the chain so I can get it off the cam gears.
Marks9-3 is offline
Old 06-07-2012, 07:19 AM   #2
viggenkid's Avatar
cant you just unbolt the timing gears?
viggenkid is offline
Old 06-07-2012, 07:21 AM   #3
Marks9-3's Avatar
Maybe? If so, awesome. Can I get it back together doing that in reverse?
I've never pulled a head, I just know what needs to come off in order to get it out.
Marks9-3 is offline
Old 06-07-2012, 07:46 AM   #4
SPG-GASM's Avatar
Remove the 12mm bolt in the center of the tensioner. Then remove the idler pulley do you can fit a 27mm deep well socket over the rest of the tensioner.
SPG-GASM is offline
Old 06-07-2012, 07:53 AM   #5
yeah, I always just used a deep 27mm socket to get to the tensioner.
The tough thing is that the bolt that holds the idler pulley on goes through and prevents you from being able to slide the socket in. you have to remove, or at least loosen the bolt holding that pulley on. once you do, stick a socket in, and back out the tensioner.
alternatively, you can take off the cam gears, and let the chain fall (you won't loose it unless you removed the link) but eventually you'll need to get that tensioner out, and disassmble it to re-time the engine. It will be MUCH easier with the head on a bench, though.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 06-07-2012, 09:27 AM   #6
Marks9-3's Avatar
I was able to get it off.
Seems like the chain is stuck on something though, crank doesn't want to spin.
Marks9-3 is offline
Old 06-07-2012, 11:15 AM   #7
132417SAAB's Avatar
Where is the chain? Just hanging out in the timing cover? Pull the chain up to where it would sit on thr cam gears so theres not oodles of slack
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 06-07-2012, 11:37 AM   #8
Marks9-3's Avatar
I did, probably need another hand but it's not budging. Spent maybe 5 min on it before I needed to get cleaned up for work.
F'ing eeuro and their not shipping everything right the first time has totally botched my timing with working on the car.
Side note, I have some buildup in between the intake valves on the piston. Best way to clean them up? Cross hatching is still on the walls though which was nice to see. No apparent wear. I didn't drain the coolant completely so a little dribbled onto the pistons when removing the head, hince the spots.
Marks9-3 is offline
Old 06-07-2012, 01:27 PM   #9
Any time you pull the head, it should take a trip to the machine shop for a bake/plane (cleaning and decking)
My guy charges me $99, and it comes back looking brand new, and with no "crap" built up on it, and you know you have a nice clean/flat mating surface.
It sounds like you're waiting on eeuro, so you might as well send it off...
Craig R.
g96nt is offline
