Gasoline additives - The Saab Link Forums
Old 08-31-2009, 06:37 AM   #1
lacedwithGRIME's Avatar
Gasoline additives
Alright so I was talking to some random who was telling me about Gasoline additives to remove gunk thats built up in the motor, etc.
Then I saw the same stuff being talked about on a car show, so heres my question...
Does anybody use any?
If so is it with every fillup or once every now and then...
Also, any specific brands/chemicals we should stay away from in our saabs?
Thanks again in advance guys!
lacedwithGRIME is offline
Old 08-31-2009, 08:01 AM   #2
Real Lyte's Avatar
Send a message via AIM to Real Lyte
Just to start, this is a huge debate, good luck.
Personally I use B-12 (at any autozone) once maybe every 12k or right before a big trip because it increases mileage and slightly cleans things in the fuel tank (once again debatable, but I see minor increases). Not to mention its a whole 3 bucks, why not?
'89 900 Turbo Vert Black
Real Lyte is offline
Old 08-31-2009, 08:24 AM   #3
Moonracer's Avatar
I've been a believer in Techron, We use it in our shop with good results in customers cars. I think the better fuels will reduce the need for these products though. The biggest reason we have for using it is the build up of carbon on the backs of the intake valves. This is most noticable with the oxygenated fuels. This carbon acts like a sponge and soaks up the fuel before it can get into the combustion chamber causing hard cold starts. The better fuels, in our area called Top Tier Fuels, will have the additives already blended into the fuel.
Moonracer is offline
Old 08-31-2009, 09:09 AM   #4
Champ's Avatar
+1 on Techron, I use it maybe once an oil change or so? That's probably a little aggressive, but you can't really over use it so why not.
Champ is offline
Old 08-31-2009, 01:25 PM   #5
watkins's Avatar
Send a message via AIM to watkins
The only thing I use that doesnt require special equipment is Lucas
watkins is offline
Old 08-31-2009, 02:54 PM   #6
Wagon Shaggin'
Saabeh's Avatar
Lucas oil additives are bad for use in a situation with gears. Do you want air bubbles in your trans/diff?
Saabeh is offline
Old 08-31-2009, 05:15 PM   #7
christian900se's Avatar
I think he is talking about gas additives... I know it probably did next to nothing, but I used to get a half a tank of 93 octane and dump a bottle of NOS "race only" octane booster in. I could have sworn the engine became a bit more responsive in the lower revs, especially when accelerating from a stop.
Just do an Italian tune-up every once in a while.
christian900se is offline
Old 08-31-2009, 05:49 PM   #8
Wagon Shaggin'
Saabeh's Avatar
I didn't know that lucas made gas additives, if they did I probably would not use them. This is based off of the experience I had with building small marine engines. We HAD to use lucas oil and it did nothing but bad. I can't imagine one product is better from the same company. bobistheoilguy.com
Saabeh is offline
Old 08-31-2009, 08:54 PM   #9
watkins's Avatar
Lucas fuel injector cleaner/gas treatment is, I believe, the only one to not contain alcohol. Its a lubricant-based product that makes sure oil is not pulled off of surfaces by the additive. It does in fact work to break things loose when used in conjunction with a proper Italian tune-up.
Octane boosters do not increase octane by a measurable amount. Furthermore, increased octane does nothing to clean out your engine. All octane is is a measure of resistance to detonation.
watkins is offline
Old 09-01-2009, 03:15 AM   #10
Rudedog's Avatar
+1 and BG's BK44. I use a can every 10-15k.
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 09-01-2009, 03:54 AM   #11
lms
Techron, before oil change.
lms is offline
Old 09-01-2009, 05:34 AM   #12
Same, use a bottle of Chevron Techron once a month or so. Probably a bit too frequent but every oil change interval seems like a good time for it.
Haven't tried the Lucas fuel treatment/injector cleaner yet. Might give it a try but like others have said I don't think it will make much of a difference if you are using quality gasoline to begin with.
-Ryan
99' Viggen
LB Viggen is offline
Old 09-01-2009, 07:30 AM   #13
Greek Mod
grkguy89's Avatar
i have heard of adding acetone to get more performance
has anyone tried this?
Current Activity: Moderating
grkguy89 is offline
Old 09-01-2009, 07:36 AM   #14
Too big of a pussy to try it.
Old 09-01-2009, 07:52 AM   #15
turbocon86's Avatar
Chevron Techron get's my vote too. A mechanic friend of mine told me he can tell every motor that has been running it that he works on--very clean internals. He also uses it in his own cars--collectible VWs.
As far as the octane boost, acetone's OK, but it is commonly sold as nail polish remover. It will melt paint and certain plastics. Use toluene if you want to boost octane. Toluene is what the refineries use to increase octane and is also the stuff you'll generally find in the half-assed "octane boosters" that you can buy at WalMart and the like--just in very small amounts. Throw a gallon of it in your tank if you want to see any real octane increase.
1993 900T Comm Ed #3
1993 900T Comm Ed #249
1994 900T Comm Ed #363
turbocon86 is offline
Old 09-01-2009, 08:24 AM   #16
lms
I have used toulene, but it's not worth it anymore due to cost. It used to be pretty damn cheap, but not now.
lms is offline
Old 09-01-2009, 08:51 AM   #17
turbocon86's Avatar
Yikes! I just checked the prices of Toluene and Xylene. When did the prices jump so much? Producers used to base their pricing on about $.50 over the wholesale (pre-tax) price of regular unleaded pump gas. Now Toluene is over $10 a gal--that's nuts! At that price it would cost over $5 a gal for a Toluene/Gas mix to yield 100 octane.
Old 09-01-2009, 08:58 AM   #18
and this is why this recession is slowly draining everyone.
Old 09-01-2009, 09:36 AM   #19
Tikka's Avatar
Send a message via AIM to Tikka
Not really. Refineries have processes to increase octane that create aromatics and hydrogen from paraffins. The octane increase comes from the creation of aromatics. Toluene is an aromatic, but they don't specifically target that reaction. We try to target benzene since it has high octane and has one less carbon (so you can get high octane with less mass).
Which is fine. Because another guy got hit by a deer. Yes, a deer ran into a man.
Tikka is offline
Old 09-01-2009, 09:47 AM   #20
turbocon86's Avatar
I'm no chemist, so I'll defer to your expertise. I see benzene's got a lower octane rating than toluene (101 vs. 114). Is it commercially available to use as an octane booster? Price?
