New Vaccuum Lines.. - The Saab Link Forums
Old 08-25-2009, 03:50 PM   #1
Send a message via AIM to Geudrik
New Vaccuum Lines..
Ok, I have a saab 9-3 SE (2000) and am about to embark on the "Replace all hoses with silicone hoses" adventure.
Can anyone tell me a ballpark guess on how much hose I'm going to need and of which diameters?
Thanks guys!
(ps: the replace the turbo adventure is set to start next weekend )
'99 9-3 :: Stage [Stuck in 3rd]
'00 9-3 :: Stage [Broken]
Geudrik is offline
Old 08-25-2009, 04:03 PM   #2
Moreboost's Avatar
vacuum lines i think 10 feet should be good, i ordered 11 just to be safe, and i think the diameter is 4mm but im sure someone else can chime in
Moreboost is offline
Old 08-25-2009, 05:15 PM   #3
Legit's Avatar
you can use 3.5 or 4mm ID and I got 12 ft, which was enough
2002 Viggen Convertible
Legit is offline
Old 08-26-2009, 05:59 AM   #4
Thanks guys!
What'd you guys do about your Y or T Adapters? Just reused the old ones?
Geudrik is offline
Old 08-26-2009, 06:03 AM   #5
mcrowley's Avatar
You can buy new plastic fittings at any auto parts store.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-27-2009, 09:05 AM   #6
OK, does anyone know where this vaccuum lines goes? In the close up pic, its the vaccuum line closest to the camera. The larger photo is for reference to where the little plastic piece is located... I'm at a loss, its the only line that isn't hooked up and I can't find the nipple...
Geudrik is offline
Old 08-27-2009, 09:44 AM   #7
SPG-GASM's Avatar
Is your BPV plugged in? It looks like the line that is supposed to run to it.
SPG-GASM is offline
Old 08-27-2009, 10:49 AM   #8
I dont know what the BPV is, or where it plugs in...
<-- Nooooooooob
Geudrik is offline
Old 08-27-2009, 11:05 AM   #9
8valvegrowl's Avatar
The BPV is upfront by the radiator, I don't think that's where your missing line goes. That module looks like it might be emission related. I'm not as familiar with T7 on the 9-3's.
8valvegrowl is offline
Old 08-27-2009, 11:59 AM   #10
Legit's Avatar
the bypass valve is the black thing on the right side of the shiny tube that goes into the intake pipe. I think that hose gets connected to said black thing.
Legit is offline
Old 08-27-2009, 03:25 PM   #11
soccerrplyr's Avatar
it does unless you put in a boost guage tap there
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 08-27-2009, 06:02 PM   #12
Ok, I dont think its any of the above...
The hose (the one that was stock that I took off) was about a foot long, so I cut the new one the same length. On the right of the engine block, theres a thick, plastic pipe (air tube Im guessing) and this short piece of vaccuum line goes under it somewhere I think (based on the placement of the stock tube I found dangling. I can take more pics if that's more helpful... Actually, see pic...
I think it gets connected somewhere around the locations of the arrows, down in the engine, I just can't find the nipple...
The one that goes into the radiator is plugged in, that hose is about 3 feet long. Theres another one that plugged into the silver box underneath the oil fill cover black housing thing. There's just that third one that's short, about a foot long...
Geudrik is offline
Old 08-28-2009, 09:27 AM   #13
If you are going to replace all the vaccum lines, might as well replace the t's and y's to. to might that makes the most sense. Kind of like replacing a head and keeping the same spark plugs. It is keep, and it will same you trouble, and you know that everything is new.
saabtech9-3 is offline
Old 08-31-2009, 06:32 AM   #14
interesting idling issues now - seems somewhat random, but when i come up to a light and am parked, it idles hard. Not all the time, just sometimes. And it reverts back to regular idling if I put the car into neutral. Also, brakes seems strange, sometimes work right off the bat, other times gotta let the car get warmed up before the brakes work...
ideas?
Geudrik is offline
Old 08-31-2009, 06:41 AM   #15
lacedwithGRIME's Avatar
ideas?
mine does the same thing at times...
i dont think its anything to worry about.
lacedwithGRIME is offline
Old 08-31-2009, 08:17 AM   #16
The brake issue is due to a vacuum leak to the brake booster, my 9-5 did the same thing until I got all the vacuum issues dealt with.
As for the idle. Is your A/C on? I've found that automatic Saabs have a rougher idle in gear when the A/C is on.
