Alternator - The Saab Link Forums
Old 08-17-2009, 05:27 AM   #1
mcrowley's Avatar
Alternator
For preventative measures I'm probably going to switch out the original 142,000 mile alternator on my 96 900 in the near future. My question is if there is a higher amperage one I can use vs the stock 90amp. Is it possible to use the 120 amp out of a 9000 or V6 900?
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-17-2009, 06:44 AM   #2
Champ's Avatar
Likely not - when we replaced the one in our lemons car (94 900 V6) it was a different (and harder to find) part entirely.
Champ is offline
Old 08-17-2009, 07:12 AM   #3
stevehayes01's Avatar
I would look at the one from an OG9-3 .... it is 120AMP in 99 and 00 and 130amp in 01-03.
I am currently running a '97 90amp in my 9-3 while I am having my 120amp rebuilt.
stevehayes01 is offline
Old 08-17-2009, 07:38 AM   #4
mcrowley's Avatar
Thanks Steve. So pretty much the 900 and 9-3 ones are interchangeable then it sounds like.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-17-2009, 10:41 AM   #5
Smaart Aas Saabr's Avatar
Why change the alternator for "preventative" reasons, it may end up worse than what you have
assuming the bearings are good just change the regulator and the brushes if you really want to chase trouble...
Smaart Aas Saabr is offline
Old 08-17-2009, 11:18 AM   #6
mcrowley's Avatar
See, I'm not ready to assume the bearings are good. I've changed pretty much all of the other accessories/pulleys except the alt and ac compressor. There has always been an interesting noise that came from the back of the motor in that area. I'd just rather play it safe then be stuck somewhere with a dead car.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-17-2009, 11:19 AM   #7
srp
srp's Avatar
Send a message via AIM to srp
Find a local rebuilder. Tell him you want to up the amperage. Should not be to expensive or a big deal.
srp is offline
Old 09-03-2009, 05:02 AM   #8
mcrowley's Avatar
Swapped in a 130amp from eeuro last night for the original 90 that was in the car. Turns out the noise I've been hearing for months was howling bearings!
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-03-2009, 02:26 PM   #9
Sleepy7666's Avatar
Not to thread jack but my 99 9-3SE has a 130 amp. It was an early 9-3 too.
Did the SE and S have different amp alternators?
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 09-03-2009, 06:59 PM   #10
mcrowley's Avatar
Well my car is a 900SE so that explains the lower amperage.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-03-2009, 07:05 PM   #11
srp
srp's Avatar
130 is the same physical size and shape as the NG one? Did it come with a pulley on it? Or did you need to swap that out?
srp is offline
Old 09-04-2009, 04:26 AM   #12
mcrowley's Avatar
The 130 from eeuro came with a pulley. Physically its bigger because theres obviously more wire wound inside the case. The easy way to get it in the engine bay is to cut off the passenger's side exhaust hanger, wedge the new alt in from below, then weld the hanger back on.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
