special brake tool? - The Saab Link Forums
Old 08-07-2009, 12:49 PM   #1
Send a message via AIM to nomadtw
special brake tool?
someone mentioned the need for some special tool to replace the brakes (rotors and pads) on my 900se
i haven't heard any mention of this at all....but that happens
is there some special tool? or is that something from older saabs and not the gm saabs?
1997 900 SE Convertible - now with 100% more drop top
nomadtw is offline
Old 08-07-2009, 12:52 PM   #2
Castor Troy's Avatar
you need a large allen key to pull the caliper carriers off, a t30(iirc) to pull the rotors off (assuming you still have the torx screws holding the rotors on), and a flathead screwdriver to pop out the pad retaining clips off.
thats it, iirc
Castor Troy is offline
Old 08-07-2009, 12:52 PM   #3
nowhereman's Avatar
no need for a special tool to do it. however there may be a tool that makes it easier... but i did mine without anything special..
2008 9-3 SS: Stg 1
nowhereman is offline
Old 08-07-2009, 12:54 PM   #4
Champ's Avatar
The allen key for the front caliper carriers was 7mm. Not large but somewhat not standard.
I just did it last month and it didn't take anything special. If you have a good set of sockets, pliers, torx and that 7mm allen you'll be gold
Champ is offline
Old 08-07-2009, 01:43 PM   #5
The special tool is for the older c900s with sliding yoke calipers.
Old 08-07-2009, 06:23 PM   #6
srp
srp's Avatar
Send a message via AIM to srp
May need some "special" tools if the rotor retaining screw is seized.
srp is offline
Old 08-07-2009, 07:33 PM   #7
NahumCC's Avatar
No speacial tool as stated.
5mm hex key for the rotor set screw.
7mm hex key for the sliding pins
10mm hex key for the caliper carrier bracket.
1 flat blade from prying off the spring retainer
9mm wrench for the bleed valves
large pipe wrench or c-clamp to compress piston.
Doesn't take long at all to do the brakes. I did this today along with the major service on a NG900 to prep it for sale. These are the only tools you'll need.......that is unless the rotor set screw strips and you'll then need an EZ out.
2013 FR-S
NahumCC is offline
Old 08-08-2009, 10:02 AM   #8
ok, that's what i needed to know
good to hear
nomadtw is offline
