hatch swap 900 to 9-3 - The Saab Link Forums
Old 07-11-2009, 01:12 PM   #1
TheTalladegaKid's Avatar
Here's a stupid question. Does the 9-3 hatch fit on the 900se? Im sure ill get flamed for this one....
TheTalladegaKid is offline
Old 07-11-2009, 01:20 PM   #2
BurnsSide42's Avatar
I believe yes - however the hatch strut mountings are different... so may require a little welding to swap over one style to the other.
Check out
for your repair needs
BurnsSide42 is offline
Old 07-11-2009, 03:46 PM   #3
Castor Troy's Avatar
uh...stig just did this, and it did not require any welding of any sort.
you need the trunk lid, the corner fill pieces (plastic bits under the tail lights) and either the inner our the outer tail lights (i believe the other tail lights) for the swap.
Castor Troy is offline
Old 07-11-2009, 07:26 PM   #4
stig's Avatar
No welding. I didn't have to swap any lights. Even the all the wiring plugs right in
'96 Miata - Simplify and add lightness
'96 9000 Aero - Complicate and add torque steer
stig is offline
Old 07-12-2009, 09:27 AM   #5
9000Andrew's Avatar
Send a message via AIM to 9000Andrew
My brother has a 95 900se coupe and it has a 9-3 hatch on it. I think it's a direct swap.
9000Andrew is offline
Old 07-12-2009, 10:44 AM   #6
I wonder then how a set of oem hatch struts from a ng900 1994-1997 won't fit a 2002 9-3 hatch. One of the sets is longer and has an offset head where it attaches to the body. The other is shorter and straight.
Check out
Old 07-12-2009, 02:10 PM   #7
Was there any problem with the brake light failure warning?
Old 07-12-2009, 05:45 PM   #8
stig's Avatar
Now that you mention it, Tweek... I do have a brake light failure warning.
stig is offline
Old 07-14-2009, 11:03 AM   #9
weird. I wonder how we could avoid this? yet still be able to use the brake light failiure display
Old 07-16-2009, 05:19 PM   #10
The 9-3 uses LED bulbs where as the NG900 used the regular bulbs. The difference in the expected resistances is what triggers the message so just ignore it. It may be possible to keep it from coming on with the Tech II?? I doubt it but it may be possible
hkayssi is offline
Old 07-16-2009, 06:43 PM   #11
dan-the-kid's Avatar
I'm sure with a similar set up with resistors for the LED corner/tail light mod, you could get the message to go away.
dan-the-kid is offline
Old 07-19-2009, 08:25 PM   #12
I didn't think the NG900 monitored the 3rd brake light. I could be wrong, though.
Jeremy R. is offline
Old 07-20-2009, 04:38 AM   #13
nowhereman's Avatar
it does as mine went off when more than 2 bulbs were out
exactly..
2008 9-3 SS: Stg 1
nowhereman is offline
Old 07-22-2009, 07:13 PM   #14
There goes my idea of replacing all 4 bulbs with LEDs! At least until I decide to add a resistor to the mix...
