9-3 vs 900 convertible top - The Saab Link Forums
Old 07-02-2009, 07:27 PM   #1
Send a message via AIM to nomadtw
my guess is no, but...
are they somehow compatible? if i had a replacement 9-3 top, could it be installed on the ng900?
nomadtw is offline
Old 07-02-2009, 07:41 PM   #2
no. one is electric other one is hydraulic.
they first went with hydraulic for the c900, then they switched to electric in ng900 and again chose hydraulic in the og9-3.
source: saabdriver87
rafal is offline
Old 07-02-2009, 07:47 PM   #3
christian900se's Avatar
What Rafal said. Plus, the structural design is different. This is evident when you look at the fabric stitchings and fabric joints.
christian900se is offline
Old 07-02-2009, 07:50 PM   #4
that's all what i figured
i know that the 900 is electric... and loud... but i wasn't talking of replacing the whole system, just the top with the metal and cloth etc
nomadtw is offline
Old 07-02-2009, 08:06 PM   #5
I think the frame work (mechanical) within the top is different between the models unfortunately
Old 07-03-2009, 04:37 AM   #6
so the real finding here is that nobody has actually tried it? just assumed it wouldn't work
both the electric motor and the hydraulic system use a linear actuation to move the top up and down right?
what about the geometry of that motion, lenght of the linear motion, start and end thresholds?
are the mounting points different?
nomadtw is offline
Old 07-03-2009, 05:00 AM   #7
I just assumed you wanted information, you are asking us about it so if you think you know better then try it. I own a convertible, Ive had the whole top mechanism replaced, and I saw it happen so Im telling you what I know.
Old 07-03-2009, 05:31 AM   #8
no don't get me wrong, i appreciate the input, and the speculating that it wouldn't work is good, i was hoping to draw someone out who HAS tried it, my reply wasn't directed at you, or with any sort of malice.
i'm still shopping for a car, i don't have one at all
the reason i wanted to know is because i have an opportunity to get a heck of a deal on a brand new 9-3 top, and there's an otherwise awesome looking 900 on ebay right now but with a bad top.
i figured that with the larger glass window in the back someone would've attempted to do a swap...and again i was hoping to pull them out of the woodwork to post about having done so
nomadtw is offline
Old 07-03-2009, 07:50 AM   #9
Ah, sorry about that haha. Anyways, I just looked at my car and then at a 01' 9-3 vert and the mounting points and mechanics look the same. I measured the hydraulic and electric actuators and they are mounted at the same point and therefore have the same travel so they should be interchangeable. The only problem would be the wiring, Im sure that is different given the completely different actuator systems.
The roof design is slightly different, but Im almost definate there is not a single person here who has done the swap. There is always a first time for everything, might as well try it out!
Old 07-03-2009, 07:39 PM   #10
i very well might
it'd be a really nice thing to know, especially if it's doable. the window would be bigger...
from what you say it sounds like they're at least physically compatible
i wonder if the shape change is more just for aesthetics and for that larger rear window, but not actually a functional change in the way it works
[edit] seems like i was unknowingly reading in the og900 forum or something...
nomadtw is offline
Old 07-04-2009, 02:08 AM   #11
bobg450's Avatar
NG900 vert top
"there's an otherwise awesome looking 900 on ebay right now but with a bad top. "
And I have an awesome top w/motors that I removed from a vert I bought for the engine (V6). Has to be a replacement top because the car itself was not pretty. I have everything but the tonneau cover motor (sold that). Cables, limit switches, tonneau, etc.
There's like 3 bolts on each side behind the rear seat side panels. My vig vert mounting looks the same, but has weeping hydraulics. Sad.
Once the 8 or so electrical connectors were undone, it only took 15 min. to unbolt and lift out. Got to be the easiest removal I've ever seen.
bobg450 is offline
Old 07-04-2009, 06:22 AM   #12
wow i need to wake up before i post
nomadtw is offline
