help with boost in viggen - The Saab Link Forums
Old 06-29-2009, 05:19 AM   #1
thaedge's Avatar
I am only getting about 12 psi of boost max out of my tdo4. The turbo was pulled from a car with 40k on it and was boosting to 20-22 before. I have a new boost control valve, and all vacuum lines are plugged. I have been playing with the wastegate and adjusted it to WIS specs. It said put it on the escape door and then turn it in 3.5 turns and then reconnect it, and this was about the same as before, so I turned it another half turn and it helped a little. The question is how many turns can I safely use before I start affecting the application of the wastegate. Any other ideas of where I am loosing boost. If I plug the hose going to the compressor housing it will spike to about 20, and if I remove the wastegate hose it will spike up. So this would make me think it is the BCV but I have a brand new one on there. Thanks
thaedge is offline
Old 06-29-2009, 06:04 AM   #2
lms
Since you have a boost gauge, what is your base boost as it should be 6.5 give or take a tad? Once you know this value, you can go from there. Where do you live as the ave. stock viggen will boost to 12 psi at sea level. Do you have a staged tune?
What do mean by all the vacuum lines are plugged, and what was boosting to 20 before, your old turbo, or the used one you just pulled? What was wrong with your old turbo that made you replace it?
lms is offline
Old 06-29-2009, 06:32 AM   #3
Subscribed. I have 15psi at the peak then goes down to 11-12. I adjusted the wastegate multiple times, no help here. Before plugging the top bpc hose off, there were only 7psis.
Still waiting for friends to get a smoke test detector in their shop. Hopefully this will show the flaws.
rafal is offline
Old 06-29-2009, 07:56 AM   #4
thaedge's Avatar
the td04 that I pulled and installed was boosting around 20psi on an spg. How do I check base boost? I have a stock tune. By plugging the vacuum lines I mean that if I pull the lines going to the bpc an plug either the wastegate or compressor lines I will get up to 20psi. I am at about 5000 feet above sea level. I replaced the turbo because the exhaust turbine was torn up, and have also rebuilt the engine.
thaedge is offline
Old 06-29-2009, 08:14 AM   #5
Champ's Avatar
Oh this is a new one!
Champ is offline
Old 06-29-2009, 08:37 AM   #6
Sleepy7666's Avatar
Isn't stock ecu tune boost set at 12 psi regardless of hardware? So you'd need an ECU retune in order to use the hardware to its full potential...
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 06-29-2009, 10:16 AM   #7
lms
Boosting 20 psi on an spg (I had one) and boosting on a viggen are 2 different things. Since the viggen is stock, you want BB set at 6.5 max. An easy, but not super accurate way to check BB on a T7 is to unplug the BPC as this will give you a ball park figure. Best way is to connect the C and W hose together.
lms is offline
Old 06-29-2009, 10:36 AM   #8
thaedge's Avatar
for clarification. When you use the above method to determine bb you will see a max boost of about 6.5psi? If it is lower you shorten the wastegate rod, and if higher you lengthen it, correct? Thanks for your help.
thaedge is offline
Old 06-29-2009, 11:14 AM   #9
lms
Yes.
lms is offline
Old 06-29-2009, 11:31 AM   #10
Castor Troy's Avatar
no.
T7 is a torque request system. % throttle determines how much torque is being "requested". from there, the ecu (based on several factors and maps) determines how much fuel and boost is needed to give the requested amount of torque.
this is why a T7 car that makes 10psi at sea level will make 15psi or more at 5000 feet, but feel basically the same.
Castor Troy is offline
Old 06-29-2009, 05:45 PM   #11
Sleepy7666's Avatar
is that at least correct on a T5?
I lurk.
99 and 01 Saab 9-3
96 Escort LX
Old 06-29-2009, 05:50 PM   #12
saabkid37's Avatar
so lemme get this straight...
20 psi with bpc unhooked
12 psi when hooked up normally...
sounds like a stock viggen to me...
saabkid37 is offline
Old 06-29-2009, 05:58 PM   #13
christian900se's Avatar
More or less, thats how T-5 works. However, t5 can still pull or increase boost based on environmental and driver inputs to compensate.
I normally just drive in a relaxed manner (otherwise I chew through gas) and on the first 2 or 3 pulls, the car doesnt pull to its max potential. Then it starts 'waking' up and after those initial accelerations pulls like it should.
christian900se is offline
Old 06-29-2009, 06:53 PM   #14
NahumCC's Avatar
No T5 does not work in a similar fashion to T7.
T5 is literally programed as a boost target system but runs in speed density to determine fueling.
If you give x% of throttle in T5 read out by the TPS at the throttle it will then seek out that boost target by comparing the TPS readout to an RPM readout and then that will be the boost pressure request figure. It's that plain and simple.
Fueling is then determined by taking the reading from the MAP and IAT and plugging in the variables to determine airmass from PV=nRT and some tweeking via the front O2 sensor basically except at WOT where it is a pre-programed amount.
So to re-cap T5. If your ECU is set to run 12psi at 4000 RPM at 100% throttle at sea level then you'll see 12psi at 4000 RPM at 100% throttle at 5000 ft.
2013 FR-S
NahumCC is offline
