Rod bearings for NG900 - The Saab Link Forums
Old 06-10-2009, 05:10 PM   #1
Does anyone know a vendor or seller on ebay who sells rod bearings for my car. 1998 Saab 900 SE Turbo. 2.0. I need a set now because the car just started knocking today before I showed up to help out Dan F. with his tranny.
1998TurboSaab is offline
Old 06-10-2009, 05:13 PM   #2
Harvey's Autohaus's Avatar
Rock Auto.com sells them
42 bucks Cheap!
http://www.rockauto.com/catalog/x,ca...,parttype,5212
HakbarSAABzzz
Harvey's Autohaus is offline
Old 06-10-2009, 05:14 PM   #3
saabkid37's Avatar
http://www.lmgtfy.com/?q=%22saab+900+rod+bearings%22
second and third ones up from the bottom
saabkid37 is offline
Old 06-10-2009, 05:20 PM   #4
Anyone who deals directly with payment through paypal? is mainly what im looking for as I have money in my account and it takes like 3 days to transfer into bank and want to try and get them tonight to fix asap.
Old 06-10-2009, 06:00 PM   #5
Castor Troy's Avatar
dude, you cant simply pop the motor out and swap the bearings, ESPECIALLY if you spun one and have possibly caused damage to the crank. you need to check clearances, etc, probably have a machine shop go over the crank. it's going to take a few days, regardless of what you do.
Castor Troy is offline
Old 06-10-2009, 06:05 PM   #6
saabkid37's Avatar
saab only sells one set of bearings, so unless he really toasted the crank, it is kinda just slap in bearings.
Old 06-10-2009, 06:11 PM   #7
no. you can buy standard size, or one step oversized bearings. the crank needs to be measured, and if he spun a bearing, i'd be willing to bet the crank is scored and needs to be machined.
Old 06-10-2009, 06:12 PM   #8
standard size: http://www.eeuroparts.com/Main/PartD...spx?id=0269308
oversized: http://www.eeuroparts.com/Main/PartD...spx?id=0269316
the reason i suspect that the crank is scored is because, from what i understand, this is believed to be an oil related bearing failure, correct? lack of lubrication = metal on metal = physical damage that must be machined out.
Old 06-10-2009, 06:27 PM   #9
saabkid37's Avatar
my bad i was thinking of something else.
but yes most likely the crank is trashed, since you would most likely have to take off either just too little or just too much to properly fit either set of bearings so your better off getting a new crank somewhere.
Old 06-10-2009, 06:38 PM   #10
assuming he doesnt drive it anymore, the crank is most likely salvageable. just needs to take the motor apart, and determine whether it was a rod bearing or a main bearing that spun, and whether the crank was scored, and how much.
from there, he can take the disassembled block and crank to a machine shop. let them determine if the crank is salvageable, and what bearings to buy.
Old 06-10-2009, 06:59 PM   #11
saabkid37's Avatar
well from the other three threads that lead to this, he probably drove it, the crank is most likely toast, and he was probably going to drop the pan and replace bearings. just a guess tho.
