How many lines on turbo - The Saab Link Forums
Old 06-06-2009, 12:42 PM   #1
I took all the manifold bolts out and the downpipe bolts off the turbo to remove the blown turbo. Now I see 3 lines on the turbo oil feed? oil return and coolant? and how do I go about taking these off i try a 12mm wrench cause i cant get a ratchet in there. And had no luck budging them diddnt wanna strip them either.
1998TurboSaab is offline
Old 06-06-2009, 02:12 PM   #2
no one else knows?
Old 06-06-2009, 03:01 PM   #3
christian900se's Avatar
4 lines:
Oil in (banjo bolt)
Oil drain (drain tube to pan)
Coolant in (banjo bolt)
Coolant drain (banjo bolt)
Those small (short length) wrenches with flexible head work well, thats what I used. Apart from that, everything else is just a matter of finding the right angle to get at the bolt.
christian900se is offline
Old 06-06-2009, 07:00 PM   #4
NahumCC's Avatar
Originally Posted by christian900se View Post
4 lines:
Oil in (banjo bolt)
X2.
Your also better off leaving the turbo tight on the manifold while trying to get those banjo's to break loose. Keeping the turbo in one place and not moving is key to success.
2013 FR-S
NahumCC is offline
Old 06-06-2009, 10:58 PM   #5
I got all the bolts except for the two bolts to the oil drain on the bottom of the turbo how do I access them under the car?
Old 06-07-2009, 08:36 AM   #6
thaedge's Avatar
just remove the rubber hose which goes from the oil drain to the sump, and then there will just be a small knob on the turbo and you can take the rest off if you need to when you remove the entire turbo.
thaedge is offline
Old 06-07-2009, 08:39 AM   #7
Will a 2000 Saab 9-5 Turbo bolt right up to my saab?
It's a TD04HL-15T and the part number is 9172180
Old 06-07-2009, 08:44 AM   #8
Castor Troy's Avatar
yes it will, as long as you have the cobra pipe already (which i believe you do)
Castor Troy is offline
Old 06-07-2009, 09:00 AM   #9
Yes. I do. ok then awesome I will be ripping a turbo off a 92 9000cse to use for now.
