Blown Turbo - The Saab Link Forums
Old 06-05-2009, 10:41 PM   #1
Blown Turbo
Ok so tonight I was going down the highway racing a New Charger SRT-8 and I got him. Yay win for me. But it wasnt. All of a sudden I lose all boost pressure and lots of smoke like clouds so thick you cant see through it behind me. I pull over and I look underneath hood my turbo exhaust side and manifold are glowing RED! lol. So im sitting there thinking hope I diddnt blow my head gasket but then I checked all my plugs normal colors and checked my oil, normal not milky. Soo hmmmm ok Start car up runs fine. Smoking alot little bit of oil shooting out my exhaust tip and a gawddd awful sound that almost sounded like it was coming from the head?!?! But im hoping its coming from turbo. It sounds almost as somebody threw a matchbox car in my turbo and its making clinging noises and stuff. Motor revs all the way up fine minus smoke and no knocks or nothing and does not build boost. So does this sound like a blown turbo?
1998TurboSaab is offline
Old 06-06-2009, 04:48 AM   #2
lms
Could be, mine idled fine when it let loose, but had zero power/boost-duh! And it smoked like a bitch, but made no noise as that shaft snapped. Pull DP off to side and check for shat play, etc
lms is offline
Old 06-06-2009, 05:39 AM   #3
Do you have a downpipe?
What are some of the specs on what parts and tunes and stuff your car has.
Old 06-06-2009, 06:39 AM   #4
thaedge's Avatar
Hey, sorry about your turbo. To me it sounds like the turbine has become unbalanced and begun hitting the exhaust housing. Usually they are still driveable for a while after this happens with just some clinging sounds, but it sounds like yours has been on the way out for a while. There also may be an oil flow issue that caused this. If you are replacing with a known good turbo I would clean out the oil lines really well by spraying some degreaser through them and letting them sit like that over night to loosen up any sludge that may slow oil flow. I know we were chatting a couple weeks ago about my blown TD04, I still have it, its probably in the same boat as your tubro, but if you want it to do a tdo4 upgrade it will be more worthit to put the repair money into a TDO4 than the turbo you have.
thaedge is offline
Old 06-06-2009, 07:46 AM   #5
I have a Nordic Stage 4 Tune
It was a viggen TD04 Turbo
No downpipe as i took it off due to it broke one of the welds now its fixed but figures my turbo blew up.
Rest of exhaust is 3" Cat back.
GS Intake Kit with Shield
HKS SSQV
Viggen Front Mount Intercooler-Ebay one is on way as of 4 days ago.
Old 06-06-2009, 04:43 PM   #6
Red DIC's Avatar
You can drive stage 4 without an exhaust. If you beat on it with the Downpipe removed, you're heating things up and likely to cause damage.
Red DIC is offline
Old 06-06-2009, 05:14 PM   #7
saabkid37's Avatar
no dp = you overheated everything and fried all the seals.
saabkid37 is offline
Old 06-06-2009, 05:39 PM   #8
Sleepy7666's Avatar
Fail....
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 06-06-2009, 06:23 PM   #9
saabkid37's Avatar
huh?
he blew this turbo up because of a stock dp end of story. coolant lines are not effected.
Old 06-06-2009, 11:07 PM   #10
Well I got the turbo off today and the shaft inside it broke right in half. I could shake the turbo and it makes clinging noises because the compressor wheel just moves around in there everywhere lol. Well im hopefully getting a turbo on Turbo9Three or something like that. A nice 18T.
Old 06-07-2009, 07:02 PM   #11
Bummer, sorry to hear about the turbo going out on you like that. Just make sure to run that 18t with your down pipe - if not, you're asking for another broken shaft. Those things generate more heat than the stock 15T.
2002BlackViggen is offline
