EBC Brake Pads for Viggen - The Saab Link Forums
Old 05-20-2009, 03:40 AM   #1
Champ's Avatar
Anyone gotten any?
I know the caliper is supposed to be the same as the regular 9-3's, but EBC specifies a different pad on the Viggen (front) than the non-Viggen models.
Same pad? Different pad?
Champ is offline
Old 05-20-2009, 04:49 AM   #2
JK
JK's Avatar
Look up the part number on a set of stock pads, if that part number interchanges with non-viggens then they SHOULD be the same pad, no clue why they would have a different part number. Sometimes aftermarket/non-OEM companies get screwy with interchanges.
always a SAAB guy at heart
JK is offline
Old 05-20-2009, 05:12 AM   #3
Champ's Avatar
Blah same part # on eeuro... Hopefully I'm not effed when I change them!
Champ is offline
Old 05-20-2009, 06:18 AM   #4
Bullseye's Avatar
I've had greenstuffs on the front for some time. Low dust, real good stopping power and easy on the rotors.
"If guns cause crime, all of mine are defective." T. Nugent
Bullseye is offline
Old 05-20-2009, 06:21 AM   #5
Castor Troy's Avatar
looking at the EBC catalog, this is what i've come up with:
the pads are an identical shape, but the regular 9-3 pad has a slightly different style clamp for attaching to the caliper, than the viggen. but, looking at the picture, they are basically identical and should be interchangeable?? pads are shaped the same, 156x74x19mm.
it's very confusing that they'd offer different styles for the reg 9-3 and the viggen, since nobody else that i have looked at does...
Castor Troy is offline
Old 05-20-2009, 06:22 AM   #6
bullseye, FYI that is the ONLY positive review of the green stuffs i have ever read. i had greenstuff pads + ebc rotors on my ng900 before I put the brembo kit on. that shit was TERRIBLE
Old 05-20-2009, 06:35 AM   #7
christian900se's Avatar
The redstuff is pretty good. I will change to yellowstuff pads next time, is that what you are going with?
christian900se is offline
Old 05-20-2009, 06:45 AM   #8
I have greenstuffs on all 4 corners, Viggen up front and Aero in the back. I just ordered the regular 9-3 ones. The calipers are the same, the carrier is the only diff part.
Old 05-20-2009, 07:15 AM   #9
JK
JK's Avatar
I hate my greenstuffs I have on my 9-3, even for street use. They turn the front wheels black within a week (does not constitute low dust in my opinion), and I got them to fade out during rallycross on a 30 degree day. I know of a former member here who had theirs fade out after minimal lapping on track days.
They are easy on the rotors, but at this point I'd rather have a pad that helps the car stay on par with my Aero and BMW when braking. I'm sure the added leverage of having the viggen setup makes them more tolerable, but I am still very unimpressed with them.
Conversely, I am on my second set of Redstuffs on my Aero and I think they are great!
JK is offline
Old 05-20-2009, 07:23 AM   #10
Champ's Avatar
Yellowstuffs up front, red stuffs in back. OEM Viggen rotors.
Champ is offline
Old 05-20-2009, 07:23 AM   #11
the greenstuff pads i had werent even enough to keep up with spirited driving through the mountains in montana. they're absolutely terrible if you do any kind of performance driving at all, and care about not dying.
Old 05-20-2009, 07:24 AM   #12
Champ's Avatar
Thanks Ben!
I was just worried I'd have all the shit ready to go and then the pads don't fit and I'd have to put it all back together with the old stuff and be sad.
Champ is offline
Old 05-20-2009, 08:07 AM   #13
I found treating my wheels with embalming fluid helped greatly in reducing the amount of brake dust the wheels retained
Old 05-20-2009, 08:14 AM   #14
Even back when I was running stock early 900 brakes with zimmerman cross drilled rotors the responses on the combo were mixed.
Old 05-20-2009, 09:35 AM   #15
Champ's Avatar
What combo?
Champ is offline
Old 05-20-2009, 10:12 AM   #16
I've used a handful of pads, and now that I use hawk HPS, I'm NEVER going back.
The only pads I haven't used that I have heard are good, are porterfields.
It's likely that EBC has different pads listed, beause the viggens are slotted.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 05-20-2009, 10:37 AM   #17
JK
JK's Avatar
The HPS is still a pretty tame street pad, fine for most people, but probably not the best on a summer only car that sees track time. Hawk does have a great lineup of other more agressive pads as well. I'll have to wrestle between some of their more agressive pads or the yellowstuffs for my next set.
JK is offline
Old 05-20-2009, 10:43 AM   #18
Apparently, the new yellowstuff compound is superior in every way to the redstuff pads... My redstuff pads can be a little hairy when they are dead cold, the new yellowstuff compound solves this issue while gaining even an even higher friction co-efficient when warm. Kind of a win-win if you ask me.
Old 05-20-2009, 10:47 AM   #19
i have hps's in the brembos for regular driving; they have a good initial bite, but i wouldnt track them. i'm contemplating getting a set of the carbotech XP10™ or XP12™ pads that feffman recommended. 250 to 2000 degree working temp is a pretty wide range
Old 05-20-2009, 10:52 AM   #20
mvadenais's Avatar
Why go to the yellows?
Green stuff on my 9000 aero are garbage. I need new pads because I feel its dangerous driving fast w/ them. Ive heard good things about the porterfield pads.
-jk, you like the red stuff enough to use them again?
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
