front oil seal not staying in... - The Saab Link Forums
Old 05-17-2009, 07:19 PM   #1
replaced my oil seal oil ring and my front seal on the oil pump..
button it up.. torque on the crankshaft pulley etc..
start car ..
car would run and idle no leaks.. rev & hold at 2000 rpm.. leak would start from under crankshaft again..
i take everything apart to find the oil seal pushed out and loose..
repeat process twice.. same result..
1. too much oil pressure?
2. bad seal ?
--Hayden--
'99 9'3 Coupe
'87 BMW E30 Track Rat
'92 Integra GS-R
Haydende is offline
Old 05-17-2009, 07:22 PM   #2
Harvey's Autohaus's Avatar
You Need to Have an ELRING seal there the Best, Its the OEM Original, I've seen those aftermarket bright Orange ones Pop out.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 05-17-2009, 07:34 PM   #3
always on duty !!!
guess i'm driving cross town to the dealer tomorrow
--Hayden--
'99 9'3 Coupe
'92 Integra GS-R
Haydende is offline
Old 05-17-2009, 07:37 PM   #4
Originally Posted by Haydende View Post
always on duty !!!
My "AT work" Load Has Become Painfully Slow, Glad to be of service, I'm getting really Bored lately.
HakbarSAABzzz
Old 05-28-2009, 09:33 PM   #5
UPDATE !!!!
so:
with new eEuroparts seals (o-ring & oil cover) fitted..
new oil gears
cleaned the oil pressure relief,
replaced the oil filter
fresh 5w30 Quaker State (Dino)
swapped in the new magnetic drain plug..
turned the key and started up..
idles perfect with no leaks..
let it run for awhile..4-5 mins
held the revs @ 3000..no leaks..
got to operating temp...fans clicked on.. no leaks
cleaned myself up a bit..(don't want to dirty the leather!)
took her down to the Chevron..put in 4 gals of 93octane..
set tire pressures..
checked for my AAA card..
set out for my maiden voyage..
drove around .. I put about 20 miles on her..stopping & checking for leaks every so often... hit full boost a few times .. no leaks..
nice!!! i'm happy
--Hayden--
'99 9'3 Coupe
'92 Integra GS-R
Haydende is offline
Old 02-02-2012, 06:49 AM   #6
Is this oil seal an easy DIY? All of the sudden I have a pretty wicked oil leak pass side near the crank I'm guessing hoping its an easy repair. My ng900 has 274k and I want her to keep rolling!!
thirstygreek is offline
Old 02-04-2012, 06:48 AM   #7
Drew in Houston's Avatar
It's pretty easy.
1. Jack up, take passenger wheel off
2. Remove passenger side wheelwell liner
3. Remove serpentine belt
4. Remove main pulley, single center bolt (you may have to loosen passenger side engine mount to allow engine to sag enough to remove the pulley)
5. Remove big honkin' circlip on oil cover face
6. Pull off oil pump front cover
7. Reinstall in reverse
Drew in Houston is offline
