Difference between RFL bov and the forge - The Saab Link Forums
Old 05-17-2009, 08:23 AM   #1
Send a message via AIM to PAsaab900
i have a rfl bov and a forge.. which do u guys think is the better out of the 2... the rfl bov i son the car n i like it cause it seems louder than the forge.. just trying to see which one is better over all.. thanks matt
f**k you topher
PAsaab900 is offline
Old 05-17-2009, 08:36 AM   #2
mcrowley's Avatar
Forge. The one in my 9000 is going on 7 years old.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 05-17-2009, 08:50 AM   #3
okay i have all the springs.. like the diff color ones.. do they do anything different...
f**k you topher
Old 05-17-2009, 09:12 AM   #4
Yeah diff. ratings of psi per spring. Like how much they can hold up to.
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
1998TurboSaab is offline
Old 05-17-2009, 12:08 PM   #5
christian900se's Avatar
Use the green spring. Thats what some high hp cars are running (if they are running a forge) and it holds boost perfectly.
christian900se is offline
Old 05-17-2009, 12:18 PM   #6
Castor Troy's Avatar
yes. use the green spring the heavier springs are a good way to get compressor surge and blow up your turbo
Castor Troy is offline
Old 05-17-2009, 12:34 PM   #7
Wagon Shaggin'
Saabeh's Avatar
I don't understand the use of heavier springs. The vacuum line should have equal pressure to what the other side of the piston has from the back side, so there should be no issues. The spring is only there to hold the initial inequality in pressure I guess.
Saabeh is offline
Old 05-17-2009, 03:33 PM   #8
well im only running a stock tune with a mbc+a... so ill keep the spring thats in it... i like the rfl cause it is louder.... but ill will end up putting the forge on since it is a better bov...
f**k you topher
