Cleaning MAF - The Saab Link Forums
Old 04-21-2009, 11:21 PM   #1
MONSTAMUNCH's Avatar
Cleaning MAF
Hi guys what do u use to clean the MAF? Heard that u just take it off and spray it with something
Ex 2000 VIGGEN [email protected]
2006 93 2.8T AERO auto [email protected]
MONSTAMUNCH is offline
Old 04-22-2009, 03:33 AM   #2
nowhereman's Avatar
compressed air?
2008 9-3 SS: Stg 1
nowhereman is offline
Old 04-22-2009, 03:55 AM   #3
CRC makes a MAF cleaner. I used it on my 9-3 and Trans AM.
2004 Silverado 2500HD Crew cab LT 6.0 LQ4, K+N intake, Magnaflow dual exhaust. Diablosport tuner.
2000 Viggen Vert *Gone - buy/enjoy my parts!
2010 Corolla S I dig it.
Marksy is offline
Old 04-22-2009, 06:51 AM   #4
Nick Taliaferro
GenuineSaab's Avatar
Brake cleaner or an evaporative solvent like Benzene will work great.
Nicholas Taliaferro
GenuineSaab is offline
Old 04-22-2009, 07:20 AM   #5
Deez Nutz
Palmer's Avatar
I would not use compressed air.
S55/LC100/KL
Palmer is offline
Old 04-22-2009, 08:09 AM   #6
Electrical contact/parts cleaner works just fine, and it's 100% safe for all MAF components. Available at Home Depot or Vato-Zone.
Gryphon is offline
Old 04-22-2009, 12:05 PM   #7
nowhereman's Avatar
out of curiosity... why?
2008 9-3 SS: Stg 1
Old 04-22-2009, 12:08 PM   #8
The little elements (wires) are a bit fragile.
Gryphon is offline
Old 04-22-2009, 01:19 PM   #9
Harvey's Autohaus's Avatar
Can somebody explain to me this Theory of "CLEANING A MAF" Why Does it need to be Cleaned? What is this Accomplishing "IN THEORY" What Are People Trying to fix? how is a Thermistor Contaminated? By anything other than WATER? Compressed AIR? Solvents? Thermistors are Quite Delicate and I try to do as little at possible to avoid SHOCKING a Precision Electronic Device.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 04-22-2009, 01:36 PM   #10
mvadenais's Avatar
The oil from open air fiters ie K&Ns can coat the small sensors in the MAF. It happened to my friends 00MCY Viggen. The result was a faulty reading from the MAF. The car ran fast as hell, yet threw a CEL. A saab delership took the car in for a full diagnotsic. Cleared it saying no issues...Long story, short: The motor went bang 1/4 mile after he left the dealership. Most things pointed to the MAF. Also Paul @ Automotion (SQR) recommends a fresh MAF when tuning high-output tunes
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 04-22-2009, 01:47 PM   #11
Wow that Sucks, I'm sorry to hear that, I've replaced Tons of Mafs Mostly T7 cars due to thermister failure and have never seen a failure due to some sort of contamination that could be corrected by cleaning. Adding Solvent to a Thermister Knowing how it works Sounds Rediculous. Mafs Fail Due to HEAT, Moisture, And Lead to Thermister/processorBoard Failure.
HakbarSAABzzz
Old 04-22-2009, 02:49 PM   #12
Nick Taliaferro
Have you ever looked at airmass actual vs calculated? there is even a calculation of this called Airmass Deviation in a % shown on tech2. This along with fuel trims can diagnose it quite quick. Most BAD airmass meters are not failed just have drifted signals. You have to be in steady state constant throttle to read it. If the turbo is packing air then it will read wrong.
One day I collected like 10 AMM (Some known bad, some new off shelf others out of our cars in the lot.) and tied one of my cars on the dyno resetting the ecu each time so that we could get actual readings. There was a 50whp variance between them! I even tested A > B > A to make sure it was good data. T7 will adapt somewhat with fuel trims but they will never throw a fault. This is why saab gave a special page F6 in the T7menu of tech2 to quickly! This is what kills most T7 motors.
Nicholas Taliaferro
Old 04-22-2009, 03:18 PM   #13
I use airmass deviation alot for those Not so obvious leaks, Hav you ever hooked a classic 900 to a Smoke macheine to look for leaks? HAHAHA if you got the Joke, Quite alot of smoke to be found, I've Found that customers HEARD the DEATH RATTLE DETONATION When the Airmass Meter Failed but Never thought anything of it till the Big BANG theory took Full Effect and the Consequence of ignoring that Rattle under boost.
HakbarSAABzzz
Old 04-23-2009, 01:02 PM   #14
A little bit after first getting my car, it was feeling a bit doggy. Simply cleaning the MAF made a difference. This is something I have done since back in the GM TPI and Ford HO 5.0 days. It works, and causes no damage that isn't already there. The key is to use a high quality "Electrical Parts Cleaner". Not sure if "MAF Cleaner" is the same formulation, but I would trust Any Electro-Motive type electrical parts cleaner.
It isn't always the remedy, but it's worth a shot. Mine was giving some borderline questionable readings on my Viggen, but was immediately replaced under warranty. That was about 15k miles ago. It just got douched when I changed the air filter.
Gryphon is offline
Old 04-24-2009, 10:40 AM   #15
perkj's Avatar
you gotta watch those electric cleaners and ensure you don't get one the puts down a thin silicone coat along with it as a number of them do.
I've always used the CRC MAF Clearer twice a year with success....still have my orgional MAF on my 2000 Vig and have Nordic Stage 4.
My calculated and actual air mass numbers are nearly dead on now that I can see them in the SID with the SID Sensor function enabled.
2000 Viggen
x-VWer:
perkj is offline
Old 05-30-2009, 01:13 PM   #16
This thread just saved me $300. I picked up the CRC MAF cleaner at a local napa, with awesome results. My viggen was kind of slow to get on boost, a little abrupt when it did, and was having trouble reaching end of the yellow on the stock gauge. Nothing dramatic, and no cel, but not quite right. After a quick 15 minute cleaning, boost comes on quick and smooth, and sits rock steady at the edge of the red in 3d gear and up. Just like new.
I replaced my maf at 60K miles, and was about to do the same when I saw this thread. Thanks!
edit - My second maf now has about 55K miles on it. I'm going to start cleaning it a lot more regularly.
stevbd is offline
Old 05-31-2009, 05:26 AM   #17
mvadenais's Avatar
what was your cleaning process? Just spray and reinstall?
88 900 SPG Black
95 9000 Aero Green
Old 05-31-2009, 08:23 AM   #18
Yup, that's pretty much it. Just be careful not to touch the wires themselves. The cleaner dries in a few minutes.
By the way, I have a stock intake. As with your friend's Viggen, I'm sure the problem is a lot worse with open air / k&n filters.
stevbd is offline
Old 05-31-2009, 01:19 PM   #19
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
When I clean mine I usually hit it with something a bit harder first, like a brake parts cleaner to remove the really stuck on crap, and then hit it with the CRC to wash away the residue left by the brake parts cleaner. The CRC stuff works really good but by itself it is kind of weak and it would leave stuff behind.
1995 900 S Eucalyptus Green
2.3l 5spd
Stage: Zombie
mlemorie is offline
Old 06-01-2009, 01:54 PM   #20
mvadenais's Avatar
The K&N's have a lot (seems excess) of oil from the factory
88 900 SPG Black
95 9000 Aero Green
