Red line MTF - The Saab Link Forums
Old 04-17-2009, 12:45 PM   #1
mvadenais's Avatar
Red line MTF
First off I want to change the fluid in my tranny Is a 2000 Viggen. I heard that Red Line is real good. ANy advise wold be great. How much do I need, what is the best, can I order it soon? Thanks -Matt
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 04-17-2009, 12:59 PM   #2
gm
gm's Avatar
I used saab's 0063 trans fluid in my 2K viggen. The MTL/MT-90 I threw in my SPG, zero experience with how it works in a viggens trans.
If you do decide to use it I have some I would like to sell since I do not use it anymore in my SPG.
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 04-17-2009, 01:26 PM   #3
Rudedog's Avatar
Do you have MTL or MT 90?
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 04-17-2009, 01:38 PM   #4
Saab9-3se's Avatar
I currently have MTL in my tranny, works great, shifting seems smoother. I have had it in there for almost a year now, and will get it analysed when I change it.
Saab9-3se is offline
Old 04-17-2009, 02:30 PM   #5
gm
gm's Avatar
I have MTL
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 04-17-2009, 02:38 PM   #6
Rudedog's Avatar
PM'd
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 04-17-2009, 02:39 PM   #7
Rudedog's Avatar
1.8 Quartz I believe. I just go ahead and use two bottles.
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 04-17-2009, 03:10 PM   #8
Saab9-3se's Avatar
I just threw in 2 qts as well, its fine.
Old 04-17-2009, 06:11 PM   #9
mcrowley's Avatar
2 quarts will do fine.
I used MTL in my 900 (when it had the 900 trans) and it didn't really hold up too well to the abuse the motor dished out. The Saab MTF0063 I used in the 9-3 box thats in it now has been much better in my opinion.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-17-2009, 07:36 PM   #10
Saab9-3se's Avatar
How did it not hold up, lab results showed that? Tranny blew? please elaborate.
Old 04-17-2009, 08:51 PM   #11
sab
sab's Avatar
I think the MTL is too light for a 9-3 gearbox, so it might be better to use the MT90. Double check the specs of the gearbox against what redline recommend.
FWIW I run MTL in my 1988 900 Aero and it is great, but it might be too light for the 9-3. Another friend down here ran MT90 in his 1992 900 Aero S gearbox.
sab
sab is offline
Old 04-17-2009, 10:42 PM   #12
MTL is compatible with Saab's earlier synthetic transmission oil, so it would make sense to me that MTF-0063 would be somewhat of an improvement. I've had Redline MTL in my transmission for a few years now and it's been fine, at least as good as the earlier synthetic, which was better than the plain old motor oil my '97 had from the factory. If or when I change it again, I might go for MTF-0063 since the price seems to have come down over the last few years.
Jeremy R. is offline
Old 04-18-2009, 03:34 AM   #13
Saab9-3se's Avatar
sab
MTL has a CST of 10.9 and Saab 0063 has a CST of 10.3 if I recall correctly. CST (centistokes) is a unit of measurement of how thick oil is. The MTL is actually thicker than the Saab OEM stuff. What are you basing that MTL is too light for the 9-3 gearbox ? Links? Articles ?
Old 04-18-2009, 06:28 AM   #14
mcrowley's Avatar
I can't say for sure if it was the oil itself, but shifting became progressively more difficult till I swapped transmissions. Judging by the large amount of metal shavings in there though...
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-18-2009, 06:52 AM   #15
daveship's Avatar
I've tried them all.....go with the 0063.
Dave
daveship is offline
Old 04-18-2009, 11:25 AM   #16
Saab9-3se's Avatar
I would say you had a worn tranny that you added more power to, and at the same time put MTL in. Not to say the MTL could have caused this, but I would lean on the side that you had a worn tranny.
Ill have a oil analysis later this summer with MTL so we'll actually see how its showing up from the Lab. Not just people saying its good or bad.
Old 04-18-2009, 04:16 PM   #17
mcrowley's Avatar
No doubt I had a trans that was a ticking time bomb. MTL only made the shifting worse... Just saying, I'd never use it again. The 0063 cost me less money and seems to work better!
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-18-2009, 04:45 PM   #18
christian900se's Avatar
Yeah I remember that Mcrowley... Its funny how it transitions from a slightly more positive shift only getting rougher.
I think its best just to flush and throw in some good old saab fluid.
christian900se is offline
Old 04-18-2009, 05:38 PM   #19
Paul Campagna's Avatar
Just drained saab synthetic tranny fluid after 60,000 miles. Had a little "roughness" i didn't like. Flushed and used Pennsoil syncromesh and it shifts very nicely... It was definitely worth the change...
Paul Campagna is offline
Old 04-18-2009, 10:27 PM   #20
bsuarmy's Avatar
Dave
So this one tastes the best?
Did you consume it in soup form or use it as a dipping sauce?
bsuarmy is offline
