Idler pulley/S-belt questions. Plus 'what is this part' - The Saab Link Forums
Old 03-30-2009, 08:34 PM   #1
Ero
Idler pulley/S-belt questions. Plus 'what is this part' -- UPDATED SEE LAST POST
1)
The rusted thing in the middle of the pic.
It seems awefully rusted compared to everything else around it.
2) How do you tell if your idler pulley is on the verge of failing completely? My car has been making a scraping noise for a month or two that i've narrowed down to probably being one of the pulleys.
How can I test which one is bad, and how hard is it to change a pulley and the s-belt? I'm taking a trip to VA in a few weeks and would really hate to get stranded on I-95, so i wanna know for sure if its the pulley, and to install a new pulley and belt.
How long do you guys think a loud pulley can go for before blowing up and stranding me?
Any tutorials for it online? And what's a good place to buy the pulleys from?
Ero is offline
Old 03-30-2009, 08:49 PM   #2
Moreboost's Avatar
lol the rusted thing is your wastegate, google it, its apart of the turbo system. A lot of wastegates are rusty its alright,
As far as the pulley is concerned, you never know it can go 2morrow or it may go in a month, the best thing to do is, take off the belt and rotate each pulley by hand, the idler pulley should spin freely, make sure none of the other pulleys are binding
Here is the step by step guide, i recently changed the idler pulley and belt on my sisters 9-3, really easy and straight forward
Originally Posted by Thesaabsite
1. Remove the Air Cleaner and slide it to the side
2. Relieve belt tensioner by prying in the tensioner hole with a long ratchet extension.
3. Once the tension is removed insert a 6 mm drill bit in the tensioner holder hole.
4. Remove the belt making notes on how the belt is routed!
5. Remove the right front wheel and remove the inner fender and remove the drive belt
6. Reinstall in reverse of 1-5. Crank car and check belt to be sure belt is positioned correctly!
EDIT:
Its actually your wastegate ACTUATOR
thanks Palmer <3
Moreboost is offline
Old 03-31-2009, 03:15 AM   #3
Moreboost's Avatar
Here is the diagram of how the belt is run
This is what happens when the idler pulley seizes and breaks, notice the melted rubber lol
You dont want this to happen on your trip, i say replace it now before it breaks and leaves you stranded
Order your stuff from Eeuro, youll have it the next day, 2 days max
Old 03-31-2009, 01:08 PM   #4
If you do shit out on I95 in VA, let me know.
When my Tensioner idler went, it made a high pitched screach, louder louder and then went away. Thats when it gave up.
I would loosen the belt, and see if the pulley has a little bit of resistance (good) vs no resistance at all (bad).
Old 03-31-2009, 04:11 PM   #5
Ero
Would broken pulleys rattle? I spoke to my indie and he said they generally squeak. I wanna be sure before I go taking it all apart.
Ero is offline
Old 03-31-2009, 04:13 PM   #6
Moreboost's Avatar
they squeak or make a whining noise, rattle may just be something loose, try to spray some silicone belt dressing if the noise goes away, its could then possibly be a pulley that needs to be replaced
Old 03-31-2009, 07:07 PM   #7
Ero
Whats interesting is that some are saying they squeak, and others are saying they don't, but sound more like a "bag or rocks".
The sound I get can closely be described as plasticy -- closest analogy I can get is tapping your fingernails on the steering wheel cover repeatedly.
Sound increases with revs, even in neutral and park, which makes me look at idler pulleys.
Ero is offline
Old 03-31-2009, 07:11 PM   #8
srp
srp's Avatar
Send a message via AIM to srp
When my alternator went it sounded like sand paper or "bag of rocks".
I'd think any rotating object that uses bearings can fail either way. ball bearings wear down and the tolerances open up, thus they bounce around. Or the grease leaks out and they begin to seize so they squeal.
srp is offline
Old 03-31-2009, 07:31 PM   #9
Ero
Would these be the parts I need?
http://www.eeuroparts.com/Main/PartD...px?id=4968590A
http://www.eeuroparts.com/Main/PartD...px?id=5172309A
http://www.eeuroparts.com/Main/PartD...spx?id=4961066
I don't need to get the tensioner, right? This one:
http://www.eeuroparts.com/Main/PartD...spx?id=4898755
Ero is offline
Old 03-31-2009, 07:33 PM   #10
Moreboost's Avatar
yes bag of small rocks getting thrown around everywhere
Old 03-31-2009, 07:37 PM   #11
srp
srp's Avatar
Yeah that's what you need. The two pulleys and the belt.
If your original belt and pulleys are still "ok" then throw them in a bag and throw it in the spare tire well
As for the tensioner... How many miles on the current one?
srp is offline
Old 03-31-2009, 07:41 PM   #12
beardedmayhem's Avatar
Can't the idler pulley be bypassed completely, and the Audi belt used? I thought I read that somewhere. Mine is starting to make noise, so I was looking into it. Any thoughts on whether this is a good idea?
beardedmayhem is offline
Old 03-31-2009, 07:42 PM   #13
Moreboost's Avatar
i believe thats the center pulley, ill try to find a link for yah
edit: here you go
http://www.thesaabsite.com/900new/NG...eplacement.htm
Old 03-31-2009, 07:43 PM   #14
srp
srp's Avatar
Yah. NG's have a center idler pulley. 9-3's don't have this setup.
srp is offline
Old 03-31-2009, 07:43 PM   #15
Ero
I think 9-3's came from the factory bypassing the center pulley (short-belt modded)...maybe it was post-2000 9-3's.
89K
Ero is offline
Old 03-31-2009, 07:45 PM   #16
I have a 1999 9-3, and I am pretty sure it has one. I just replaced my third DI cassette. Almost to 200k miles! Going to check the pulleys tomorrow.
Old 03-31-2009, 07:46 PM   #17
aireeca's Avatar
Yes. You are correct - there is no center idler on the later 9-3s. You can bypass the ac compressor on your car, should it decide to poop the bed. I highly recommend keeping a Tweek around. He shortbelted my 2001 9-3 car more than a year ago when the compressor pulley started screaming like a banshee.
aireeca is offline
Old 04-01-2009, 09:06 AM   #18
Ero
I bought a stethoscope thingy...
listened to my pulleys... to the best of my ability....pulleys sounded fine to me, so i dunno, now i'm lost.
I suppose the car wasn't making the scraping sound though, so maybe i'll drive around with my stethoscope and do it in my college parking lot if it does it again (wont i look like an idiot!)
If not, I guess i'll take off the s-belt and listen to em by spinning them manually.
So much for this being an easy diagnosis =/
Ero is offline
Old 04-01-2009, 09:39 AM   #19
Ero
http://www.thesaabsite.com/shop/cati...ysetup4cyl.jpg
In that picture, can someone tell me what the unlableled pulleys are?
Ero is offline
Old 04-01-2009, 09:43 AM   #20
srp
srp's Avatar
Top Right: Power Steering Pump
Then Water Pump.
A/C Compressor should be below the water pump but does not exist in this picture.
Alternator directly below #3
srp is offline
