coolant temp sensor different sizes? - The Saab Link Forums
Old 03-21-2009, 07:49 PM   #1
spanky's Avatar
Send a message via AIM to spanky
i am doing an engine swap 204r to a 234r and the coolant sensor is different sizes. does anyone have any info on this?
-Derek
97-900se blk/blk 5speed, 2.3 aero motor, td04 18t......SOLD
92 dodge w250 cummins.....SOLD
97 900SE blk/blk, 5speed, TD04, upgraded fmic-----Back in the game
03 f250 CCSB Lariat 6.0
spanky is offline
Old 03-21-2009, 08:10 PM   #2
NahumCC's Avatar
Well what I'm finding is it depends more on the engine number. Engines leading up through V002172 used part number 91 82 270. Engine starting V002173 used 91 82 205.
Thats what I've got from EPC for motors in 1996-1998.
2013 FR-S
NahumCC is offline
Old 03-24-2009, 06:20 AM   #3
Harvey's Autohaus's Avatar
Unmarked In the Saab Parts Catalogue For Years,"untill 2000" The Gauge Sender By the Tstat up to 97 was A PIPE thread.. Halfway in 97 it Became a Stanadard Pitch with the Aluminum washer. Not intershangable But Both Function the Same. You just Need the Correct One for You specific Model year Head.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 03-24-2009, 06:24 AM   #4
stromer's Avatar
We ran into this when doing my headgasket because the head I was putting on was from a 94 9000. As my car's factory temp sensor was from a 99, it was too big to fit in the hole in the head from the 9000. We ended up using a brass fitting as a reducer and it has been fine now for 10k miles and about 5 months.
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 03-24-2009, 06:26 AM   #5
Or Just Use the Old Sender It only operates the Dash Gauge. On the 9k. not so on T7 Cars though
HakbarSAABzzz
Old 03-24-2009, 06:27 AM   #6
stromer's Avatar
In our situation the original sensor wire had been cut when the engine was taken out. In our search for one of these from eEuro, etc we couldn't fine one.
stromer is offline
Old 03-24-2009, 06:39 AM   #7
Thait Sucks. Does Any body Use the Dealer on here? A good Parts Guy is Worth his Weight in gold
HakbarSAABzzz
Old 03-24-2009, 06:41 AM   #8
stromer's Avatar
They don't usually stock anything older than 1999.
stromer is offline
Old 03-24-2009, 06:43 AM   #9
I still Call up My OLD retired Or PUSHED out Parts Guys Because they can still pull those Obscure Part Numbers off their Heads Like MAGIC! The Car Bizz is Starting to Get Ugly again
HakbarSAABzzz
Old 03-24-2009, 11:50 AM   #10
spanky's Avatar
so would i be able to just use a reducer? what is the thread size on the head?
spanky is offline
Old 03-24-2009, 12:01 PM   #11
stromer's Avatar
We went to an industrial hydraulic shop with the two temp sensors. I do remember we could only get something in a standard size, but with a good amount of thread sealer it is holding just fine.
stromer is offline
Old 03-24-2009, 12:11 PM   #12
KChrist's Avatar
Send a message via AIM to KChrist
went to the same shop today because the sender on the '95 9000 is different than the '99 head i just put on my car. they had a metric converter, the gauge reads a little low but it still reads which was my biggest concern. the thread on a 98+ 4cyl head is actually identical to the wheel bolts. random coincidence. so take one of those and the sensor to a hydraulics shop and they should be able to set you up with something.
237.5hp and 283.4 lb/ft
KChrist is offline
Old 03-24-2009, 12:13 PM   #13
Whats Wrong with the Old sensor? If functions Exactly the same
HakbarSAABzzz
Old 03-24-2009, 02:31 PM   #14
spanky's Avatar
The old sensor is too big For the hole on the 95 9000 head. I need to find the size of the smaller hole.
spanky is offline
Old 03-24-2009, 04:53 PM   #15
KChrist's Avatar
the thread on the 9000 is nearly 1/8" so close that with teflon tape it'll work.
KChrist is offline
Old 03-24-2009, 05:48 PM   #16
Just Go get A 9000 Sender. The One that Fitts the 9000 Head. The Properties Of Both sensors are IDENTICAL... And It Looks right Without some "RIG" Because it is right.
HakbarSAABzzz
Old 03-25-2009, 06:13 AM   #17
KChrist's Avatar
http://www.eeuroparts.com/Main/PartD...px?id=90490017
thats the sender for the 9000. Best price you'll find.
KChrist is offline
Old 07-06-2009, 06:22 AM   #18
Boosted Coops's Avatar
nope, i paid like $30 from a local saab shop, no discount but yea, i had the same problem when i did a head swap, the threads on the older temp sensor was smaller... held me up for another week cause the shop had to order it...
Your signature was too big.
480x70px or smaller please.
Boosted Coops is offline
