Turbojohnny's build thread? - The Saab Link Forums
Old 03-04-2009, 04:18 PM   #1
turbojohnny's Avatar
seeing as how i have a spare motor and tdo4 sitting in my garage i've decided to rebuild them. i'll eventually ship the tdo4 to chadwick to let him do his thing but i'll assemble everything myself.
i've already built myself an engine stand and torn down the motor. soon enough i'll take things to get machined and i'll put it all back together.
now for the pictures...
toorrow i'm planning on cleaning up the block, and probably going to the local speed shop to see what they'll charge for the machine work.
turbojohnny is offline
Old 03-04-2009, 04:19 PM   #2
Moreboost's Avatar
slow down for my sake craigs gona have field day when he sees this, on a side note you took off the oil injectors or what ever their called right, is that necessary?
Moreboost is offline
Old 03-04-2009, 04:20 PM   #3
yes i did take out the piston squirters, and yes that is necessary.
Old 03-04-2009, 04:48 PM   #4
how many miles were on that engine?
I want a spare engine to tear apart....
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 03-04-2009, 04:55 PM   #5
189k miles, but the previous owner beat the piss out of it, and then i got a hold of it too.
Edit: the bearings in the motor don't look bad because i had just replaced them before i had swapped motors.
i put new bearings in hopes that it would solve my knocking problem, but the rod bearing on cyl #4 had spun and worn on the crank journal. the new bearings didn't solve the problem, but the used motor that i dropped in did.
Old 03-04-2009, 04:59 PM   #6
viggenkid's Avatar
absolutely dieing over here.
turbojohnny > moreboost.
it appears johnny will have a new running motor for his ng900 by carlisle. inram will be there in his mom's 9-5.
viggenkid is offline
Old 03-04-2009, 05:07 PM   #7
Moreboost's Avatar
iMran get it right
Old 03-04-2009, 05:08 PM   #8
viggenkid's Avatar
as soon as you get sonett right imran
Old 03-04-2009, 05:36 PM   #9
if by some chance this motor is done before carlisle i won't drop it in before the show. i'd rather have an old motor in the car to mess around with while i have a brand new one waiting in my garage.
you can't have any fun when your motor still hasn't been broken in yet.
Old 03-05-2009, 09:25 AM   #10
i stopped by the speed shop a little bit ago and got some prices, $135 to cut the crank and about $350 to balance the roatating assembly, and then another $325 for a valve job on the cylinder head. so that's about $810 for all the machine work i need done. Turnaround time was estimated to be about a month, because this is the time of year everyone is having their motors built.
i'll probably drop the stuff off next weekend.
ad the shop i'm having the work done at is Jan-Cen racing.
they're responsible for this...
Old 03-05-2009, 09:27 AM   #11
viggenkid's Avatar
nice. are you gonna use stock internals?
Old 03-05-2009, 09:32 AM   #12
yeah, no need for forged internals. i may do a thing or two here and there, but this will be a pretty stock rebuild other than the oversized bearings.
Old 03-05-2009, 09:46 AM   #13
viggenkid's Avatar
you should find a t7 head to bolt on instead of having your t5 head refurbished.
Old 03-05-2009, 10:00 AM   #14
i've been looking at that thread, that also means frankensteining a t7-t5 hybrid intake manifold so i can use my t5 tb. or at least making a t7-t5 tb adapter plate. that's a little more involved than i want to get.
Old 03-05-2009, 10:04 AM   #15
viggenkid's Avatar
go big or go home.
i like how this thread has productive updates. have the flywheel shaved too, or get the spec one.
Old 03-05-2009, 10:14 AM   #16
we'll see what the budget allows.
remember, this is going to be a winter car once i get the '77 280z from my uncle this summer.
Old 03-05-2009, 11:35 AM   #17
drop this motor in the 280z*
2012 VW Golf TDI
Old 03-05-2009, 12:25 PM   #18
hah yeah, if that car gets a motor swap it'll get the vortec 350 sitting in my trans am.
Old 03-05-2009, 02:25 PM   #19
i picked at the motor a little more today, started cleaning and degreasing the block...
from my inspection, this block is just fine. i can still see the cross-hatching in each cylinder, and i can still see the marks the hone left in the main caps too.
Old 03-05-2009, 03:32 PM   #20
Let me know if you go the T7 head route. I used to run a B205R with the T5 throttle body and made a phenolic adapter plate....
