225/50/16 will it rub? - The Saab Link Forums
Old 03-01-2009, 08:14 AM   #1
liketheword's Avatar
I am considering putting this size tire on 16"x7" wide wheels w/ a 40mm offset.
I know 225/45 should be fine.
I can just get a great deal on the 225/50.
Anyone know the offset on the delta's?
Thanks.
Vitamin SAAB
liketheword is offline
Old 03-01-2009, 08:28 AM   #2
IX III's Avatar
i had 225/45/16's and they rubbed- stock suspension & whatever offset the vikings are(37mm iirc)
so i am going to say that 225/50's would rub alot.
IX III is offline
Old 03-01-2009, 08:34 AM   #3
I have 15" delta's now. I assume the offset is 37.
I was considering 16" borbet that has an offset of 40.
I will lose 9mm inner clearance but get an extra 3mm outer clearance.
Do you know where they rubbed?
Vitamin SAAB
Old 03-01-2009, 08:40 AM   #4
IX III's Avatar
front rubbed holes in the plastics-
Passenger side- rubbed a hole through the plastics onto the crank pulley when turning left and a hole into the wheel arch when turning right.
Driver side was similar- holes in the wheel arches from rubbing.
Rear had more issues-
Driver side was okay from what i can remember.
Passenger side was not.-- there is a rollover fuel shut off valve in that wheel well. so if your car flips it cuts fuel. anyways i wore a hole through it... not too excited about that one.
I'd stick to 215's if you can.
IX III is offline
Old 03-01-2009, 08:59 AM   #5
Thanks for the info!
I will pass on the 225/50/16's then.
Vitamin SAAB
Old 03-01-2009, 10:27 AM   #6
i had 215/45/17 on ronal's with a 40mm offset with no rubbing. the car was lowered on koni springs. the rims were 8x17 i think.
i had 225/40/17 on the same rims and they rubbed bad in the back.
jonny72888 is offline
Old 03-01-2009, 10:54 AM   #7
JK
JK's Avatar
The 40mm offest is the problem. I have 224/45 17 on my summer wheels, but i believe they are a 7.5" wheel with et35 offset.
et40 on a 7" wide wheel is fairly inwardly set. Ish.
always a SAAB guy at heart
JK is offline
Old 03-01-2009, 01:32 PM   #8
I figured the offset would be the issue here.
The other thing I was concerned about that 225/50/16 would be a fairly tall tire for the car. Thus I worried about rubbing in the lower spring perch.
Sounds like less offset would be more ideal. I heard tail of a NG900 with I think a 30 or 35 offset running 235's... I guess my search continues for some 17" or light 16" wheels...
Vitamin SAAB
Old 03-01-2009, 05:00 PM   #9
Drew in Houston's Avatar
I'm running 225/50/16's on the stock rims.
Seems to be working well...of course I had already rubbed through running 17's so they may rub a little.
Drew in Houston is offline
