Front Spring Removal - The Saab Link Forums
Old 08-04-2017, 08:07 AM   #1
ninehundredt's Avatar
My front driver's side spring is cracked. I'm planning on pulling the wheel off and removing it this weekend. Are there any caveats to this, or can I just compress it and remove? Thanks.
Sent from my Pixel using Tapatalk
1987 900 SPG
1991 900 Vert
2002 9-3SE
ninehundredt is offline
Old 08-04-2017, 10:16 AM   #2
WSW
WSW's Avatar
10.02.2005: Saab NG900 Front Suspension - photo.platonoff.com
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 08-04-2017, 11:34 AM   #3
Ah fack this is gonna be fun.
Old 08-04-2017, 07:54 PM   #4
srp
srp's Avatar
Send a message via AIM to srp
Compress and remove in the car is going to be tough, if possible at all.
srp is offline
Old 08-05-2017, 09:33 PM   #5
Yep. I'm just going to pull the entire assembly off of a donor and replace. It's not too difficult.
1987 900 SPG
1991 900 Vert
2002 9-3SE
Old 08-11-2017, 09:49 AM   #6
So I got to the wrecker a bit too late, and they crushed the 9-3 I was previously pulling parts from.
I'm just going to go ahead and purchase a replacement spring. Browsing on eeuro I see that there are a couple of aftermarket options, as well as genuine SAAB parts.
Does anyone on here know what "Vehicle Note: Code=AV, Marked yellow/red" means?
Old 08-11-2017, 03:49 PM   #7
Saab fitted suspensions with different springs and bars depending on model and perhaps equipment levels (weight). The codes for your car are on a stamped aluminum plate on the radiator top support, passenger side (USA).
See this: Suspension codes - SaabCentral Forums
At this point, you're not going to find springs for every option. I believe Saab is down to selling one, if any. I would NOT install one spring in your car, I'd do both sides. Uneven is a bad idea. Also, your strut cartridges may be very worn... you will find out when you get the strut disassembled. If they are weak, now would be the time to replace them. Mounts may also be bad, but if they are factory and not giving any issues, keep them.
You need a number of parts that are one time use and/or likely to be badly corroded. I can list them if you are interested.
BobSabbert is offline
Old 08-11-2017, 04:50 PM   #8
Bob,
Thanks for the help! I'm planning on pulling the struts this weekend to see what's worn out. Definitely interested in seeing your list and any other suggestions you have.
Old 08-12-2017, 08:08 AM   #9
Parts to replace
The following nuts are supposed to be one time use since they are lock nuts that won't necessarily relock: tie rod end nuts, ball joint nuts, and axle nuts.
There's a thin zinc ring under the spring that's labelled as a "spacer" in the diagrams. They are designed to corrode over time and keep the spring from corroding (so it doesn't break . You need to replace those.
I mentioned the mounts already... there's a bearing under the mount that might be good or bad. If money is a concern, you can try to reuse it. But, this is a fairly long and annoying job to do so if you can, replace them.
The bolts that hold the ABS sensor in the holder are usually beat at this point. You can replace them with stainless from the local hardware store.
You can leave the ABS holder on the strut as long as you are very careful with it. It's plastic and easily breaks. You'll have a 50# strut to move around and a quarter ounce plastic bracket on the back. You can remove it (the bolt comes out easily most of the time). But it has a little plastic stud that fits into the hub to position it that most always breaks off. You either have to get a new ABS bracket, or figure out how to make a replacement stud, or just position it visually and hope it stays there.
Factory or aftermarket nuts are available. Factory costs a chunck more. Aftermarket zinc spacers are OK. SKF is the factory original bearing and is probably the best choice as you can get it aftermarket.
If you need mounts, there's really only aftermarket now and none are great. The ones Saab sells are from Pro-parts Sweden and cost 4x as much as the exact same aftermarket part. You can get Meyle (which is also Pro-parts) from FCP Euro and get a lifetime warranty if you prefer. For a stock suspension, they will probably last.
For struts, you can get cheap stuff like Monroe, or slightly more expensive stuff like KYB. Neither will be equal to the factory damping level but will serve. Factory level is Sachs / BOGE which is OEM. For additional money, you can get Bilstein or Koni (adjustable) which will upgrade the handling and ride. Konis set soft with stock springs are a nice ride but it will cost you some $$.
If you want to upgrade handling more seriously, you can install some lowering springs all around with Koni's or Bilsteins. But, your total cost will be in the $1000 range for the springs and shocks. The good news is that the rear shocks and springs are an easy change. You still need the nuts, spaces, and maybe mounts and bearings.
Old 08-12-2017, 03:41 PM   #10
Thanks this is really helpful. I'm going to have to look around for some of those zinc spacers. The nuts are relatively easy to obtain though. I'm really just looking to do this as cost effective as possible, so I'll steer clear of the performance options.
Old 08-13-2017, 07:41 PM   #11
srp
srp's Avatar
x2! Excellent information! Thanks for taking the time to write it up and share it!
srp is offline
Old 08-13-2017, 07:43 PM   #12
srp
srp's Avatar
I do remember putting that zinc spacer on mine. My stock ones were not worn out, but I bought absolutely everything ahead of time so I could assemble them on an extra pair of knuckles.
Looks like they are still readily available:
https://www.eeuroparts.com/Parts/290...Lower-4689378/
srp is offline
