Viggen wheel well cutouts. - The Saab Link Forums
Old 09-14-2006, 01:02 PM   #1
CooperS7777's Avatar
Does anyone with an updated EPC have the part number for the rear wheel well cutouts for the Viggen?
Im talking about the peice you have to hack out if you put 17's on a NG or 9-3, right in front of the rear tires, below the rear quarter panel. Id like to put the Viggen peice in when I get my car re-painted/body work done for a cleaner look.
CooperS7777 is offline
Old 09-14-2006, 02:08 PM   #2
iwantaviggen's Avatar
i didnt have to hack anything out...
i think i know what yur talking about tho..
i saw it on my EPC.. at home..
iwantaviggen is offline
Old 09-14-2006, 03:10 PM   #3
Powar's Avatar
Send a message via AIM to Powar
No problems here with the 17x7 9-5 Aero wheels.
Powar is offline
Old 09-14-2006, 04:38 PM   #4
I think my issue comes with running 17x8's I allready have my wheel wells cut out as not to destroy my new tires but its a hack job - maybe Ill just go back sometime and clean it up real nice.
Old 09-14-2006, 04:43 PM   #5
i got 18x8s 225 40
still no hacking.. trim maybe and roll but thats do to the 18"s not th 8"s
Old 09-14-2006, 04:58 PM   #6
swdmus's Avatar
Send a message via AIM to swdmus
I think your talking about the stone gaurd right in front of the wheel on 3 door models. The thing that needs to be trimed is the plastic bolt that holds the back of the side skirt on. Is the stone gaurd what you want a number for?
PRC Installations
1994 900SE 2.0L Turbo
1991 900S 2.1L
1998 Jeep XJ
swdmus is offline
Old 09-14-2006, 05:04 PM   #7
ahhh 3 doors yur right
Old 09-14-2006, 05:17 PM   #8
Makeyousaab's Avatar
yeah my convt. has that. it has a few mm of room that can be shaved off. In the WIS it gives instructions for fitting the larger wheels.
~Dave
Makeyousaab is offline
Old 09-14-2006, 05:37 PM   #9
swdmus's Avatar
Those panels aren’t any different on a Viggen there just painted the color of the car
PRC Installations
1991 900S 2.1L
1998 Jeep XJ
swdmus is offline
Old 09-15-2006, 03:51 AM   #10
I painted my stockers, and didn't think any hacking was needed to fit bigger tires. Ced had a big set of wheels on. See if he did anything.
Check the EPC. I think the 17 equipted cars have a diff bump stop. (I know actually)
Old 09-15-2006, 06:36 AM   #11
Yea, trouble is my EPC only goes to 98 which doesnt include the vigs or 17 equiped cars for the best of my knowledge. I know Im not out of my mind on this, Ill snap a pic of mine sometime today, and I also know 100% for sure that the VIG has a different cutout AND that I DID have to cut out my wheel well to get my wheels to fit, as did Wyldsaabman to get his RKII's to fit - maybe its just the offset of certain wheels or maybe the SE 9-3's came with the cutout wheel wells.
Old 09-15-2006, 07:09 AM   #12
marky373's Avatar
Send a message via AIM to marky373
Coop, I know what you are talking about. I have a 4 door with the Vig Wheels mounted with 17 x 8's. The issue isn't so much of them not fitting in but more of the shitty suspension. Its too spongy and if you hit a large bump the wheels rub. Its twn times worse when you have a loaded car. I belive the only real solution is to upgrade your suspension completely. I say completely because I have GR-2s and KYB's and there is still rubbing. Another factor is the tirewall height. I have 45's in nitto rubber but nitto 45 is more like 50 in normal rubber. Awesome tires but im trimming the sidewalls off slowly with each bump. Another problem that could compound the issue is that if you do upgrade the suspension then you are lowering the car and providing less clearance height wise. Yes you get a stiffer ride but is it stiff enough to prevent rubbing?
Simply, The Saab
marky373 is offline
Old 09-15-2006, 02:03 PM   #13
WyldSaabMan's Avatar
hey coop get it right i have the Rk1's...anyway yea I hacked mine out after carlisle cause my new tires were rubbing quite baddly.
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
