B235r Engine Build - The Saab Link Forums
Old 10-27-2016, 11:24 PM   #1
Elyk's Avatar
B235r Engine Build
Hey all,
I have a 2000 9-3 Viggen with 153k on it. I am about to run a Stage3 BioPower Maptun tune on her: 3" down, 60lb injectors, intake pipe upgrade, charge pipe upgrade, Racetronix Fuel Pump, front mount Mishimoto J-line intercooler...
I am coming to crossroads as I would like to build a B235R engine outside of the engine in the car to upgrade internals and work on the transmission with little or no downtime.
I am wondering about the compatibility of the 9-5 B235r T7 engine in the Viggen?
My local junk yard has quiet a few 9-5 t7's to choose from but before dropping the money and pulling the engine I wanted to run the idea by y'all... if possible I would really like to know if the engine fits according to the engine Mounts, axels, to the Viggen. I do know that the Strut assembly format and knuckles are a little different from 9-5 -9-3 b235r
I am just wanting to have an engine to learn more and enhance performance while learning and tuning via T7 Suite after maxing out with Maptun.
Thanks
Elyk is offline
Old 10-28-2016, 04:56 PM   #2
Drew In Houston
Sweet, welcome. The engine itself will work. I put a 2001 9-5 Aero short block into a 2001 Viggen convertible for my lady a few years back. No problem.
Between the Viggen and 9-5 Aero's the transmission cases are different, and the brackets/mounts and such--but you can definitely build up a 9-5 B235R and then swap the rest over.
If you're wanting to build a transmission, you need a T7 9-3 box with a 9-5 differential. Or a Viggen specific unit. You'd still need to install a 9-5 differential but maybe one of the later NG-900s might work too for a case, I think there may have been some overlap there for compatibility with the last of the 900's. Someone will chime in I'm sure. There are quite a few special tools needed to set the preload correctly when you're assembling.
If you're new to building things, I wouldn't start with one of these transmissions. Many transmission shops won't even touch them and some parts are just NLA, so you need donor boxes, in addition to the special tools. If you do try it, the Cobalt SS/Ion GM factory manual is better in some areas than the Saab WIS.
Trionic3000 is offline
