dynoing the auto tranny - The Saab Link Forums
Old 09-07-2006, 11:13 AM   #1
Trollerator
abdukted1456's Avatar
there is a sensor you can disconnect to keep the car in limp home and it will stay locked in 3rd.
i forget where it is...
anyone?
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 09-07-2006, 11:21 AM   #2
stevehayes01's Avatar
Not sure on that but when I did mine we put it in Winter mode and it starts and stays in 3rd gear as long as the car is put in 3 and not D. I will look up in the WIS to see if I can find it for you though.
stevehayes01 is offline
Old 09-07-2006, 11:37 AM   #3
Trollerator
yeah i am not sure that worked for me last time...
Nick T mentioned you can force it into LHM I just want to be sure to unplug the right thing
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-07-2006, 11:39 AM   #4
Just pull all the plugs and you will surely get the right one with one of them.
Actually I always though you should have gotten more power than what your car put out being that Ricot put down 218 with no software. If I find the sensor I will let you know.
Old 09-07-2006, 11:54 AM   #5
Trollerator
yes i think I am going to try again soon... now that I have the IC and I am getting my ECU re-flashed, it should be a bit better... although for the lower HP than i expected, i have to say the car is like a rocket on the highway
I put 215HP/240ft-lbs maptun stage 1ECU + cone intake
then 201 HP/199ft-lbs same setup, different dyno
I put 231 HP 255Ft-lbs down last time nordic stage 3 (but that ECU was not my final tune)
unless i have something wrong HW wise wth my car that has not manifested as a major issue yet.
I do hope to get some more ponies... TQ is nice and flat curve and probably plenty for this tranny
also want to check the A/F again
also i have to mention I don't think they really got a good solid run last time cause the tranny kept shifting
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-07-2006, 12:02 PM   #6
PaulH's Avatar
its amazing how much power can vary from dyno to dyno, and even day to day. the SOC dynos were a great example, last year people were getting like 20-30hp more than they were this year from what i saw, and that was even the same dyno! best bet if you want to compare when you make changes is to use the same exact dyno, and with weather thats at least fairly uniform. also have to keep in mind that different dyno manufacturers give quite different readings, mustang dynos usually read lower than dynojets. lots and lots of variables, always gotta take dyno #'s with a grain of salt.
Paul
PaulH is offline
Old 09-08-2006, 07:03 AM   #7
Abdukted check page 7 of this PDF and there is a reference to the LHM relay.
Limp Home Relay
Old 09-08-2006, 07:13 AM   #8
Trollerator
thanks Steve
1990 900 turbo vert
2004 9-5 aero sedan
Old 09-08-2006, 08:32 AM   #9
dip
dip's Avatar
Send a message via Skype™ to dip
If you want to prevent the ECU from fiddling with the throttle plate and lock it to the throttle cable, you can just push the limp home rod on the side of the TB, and it will lock itself. All you need is a screwdriver or a pocket knife. However, I recall reading in the WIS that the limp home mode does not allow the throttle to be fully opened - there's not enough arm travel, so it can be opened further by the motor only. If this is true, you might not get full power.
I dynoed my stage1 '99 9-5 Linear in winter mode a while ago, and it remained in 3rd all the way. The numbers were 170 whp / 230 wtq on a hot summer day with a crappy fan, sounds reasonable for conditions.
dip is offline
Old 09-08-2006, 08:40 AM   #10
I did mine in Winter mode as well and it was in 3rd the whole time too.
