what is the electronic module on the filler neck? - The Saab Link Forums
Old 08-16-2016, 05:54 PM   #1
1997 900 se turbo. Viewed from behind/underneath the car, there are wires going to ABS sensors on both back wheels, but also one of the saab/amp locking connectors with 3 wires. These 3 go to some module on top of the fuel filler neck.
What is this module? It's not the pump or level sender, those four wires go on top of the fuel tank to their own pair of 2-pin AMP connectors and are accounted for. All the evap stuff I'm aware of is in the passenger front fender. I don't see anything like it in the fuel system catalog on eeuro. I'm not even sure it's fuel-related, but it'd be an odd place to put this thing if it wasn't.
jerrit is offline
Old 08-16-2016, 08:00 PM   #2
WSW
WSW's Avatar
Probably the shut-off valve
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 08-16-2016, 09:11 PM   #3
srp
srp's Avatar
Send a message via AIM to srp
Yup. https://www.esaabparts.com/viewparts...ction=11219673
srp is offline
Old 08-17-2016, 01:57 AM   #4
I understand the ecu shuts off the fuel pump whenever the engine isn't running, so as not to spray gasoline all over after a crash. The ecu would stop grounding the fuel pump relay.
This is the closest thing to an explanation I could find.
http://www.teacher.starenvirotech.co..._WKBK_10-03-02[1].pdf
It describes a valve that closes in a rollover, and I'm assuming that's a simple gravity mechanism. Is the electronic component simply to inform the ecu when the valve is closed, so it knows the car is upside down? Or is there actually some electromechanical mechanism in this valve that the ecu is controlling?
jerrit is offline
Old 08-17-2016, 09:12 AM   #5
srp
srp's Avatar
I don't think its to shut of fuel, I wonder if it has something to do with emissions? Maybe even CA emissions.
My 97 NG900 doesn't have this.
What engine/body style do you have?
srp is offline
Old 08-18-2016, 01:28 PM   #6
1997 900 SE Turbo, 4 door hatch, 2.0 liter b204, trionic 5, etc. Don't think there's anything special about it.
The car runs with it unplugged. I do have the fuel pump wired to a switch panel and the rest of the evap system is gone (Because Racecar). It's probably not possible to determine what the original function of this thing was by unplugging it and seeing what stops working or what codes it throws, which is what I'd try if it was stock.
This is literally one of the only pieces of the stock wiring harness I haven't dissected, identified, trimmed and re-wrapped. I'm basically trying to determine whether I need to keep these wires.
jerrit is offline
Old 08-18-2016, 01:48 PM   #7
srp
srp's Avatar
Genuine SAAB ELCD Purge Valve (Fuel Tank) 4966826 -Free Shipping Available
Called a purge valve at eEuro.
srp is offline
Old 08-22-2016, 11:39 PM   #8
Says it fits SAAB 9-3 1999-2003, SAAB 9-5 1999-2005, "This part does not fit your [1997 saab 900 se turbo]"
Based on the limited number of things it could be I suspect you're right. I just need to find a picture of the ng900 equivalent part this superseded to confirm.
The 9-3 part is the right number of wires (3), so if the old version also has 3 wires then I'll be confident.
This diagram of the ng900 evap system shows two purge valves eventually leading to different ports on the front charcoal canister.
One I'm familiar with, it's in the passenger side of the engine bay by the firewall and wheel arch. I did not know there were two. Maybe I'm looking at the second one?
Saab 4442471 maps to Bosch 0280142301
Saab 4442489 maps to Bosch 0280142300
Argh, these both only have two pins on the connector. So they're not it.
Approaching this from another angle, the wires from it go to the big gray plug in the footwell by the ECU. The smaller, more sparsely populated of the two.
Do we have wiring diagrams that identify the contents of that plug? Wiring diagrams would be a huge help to me in general, I've been flying blind for years with this thing.
jerrit is offline
