40k service. oh noes! - The Saab Link Forums
Old 08-17-2006, 12:35 PM   #1
guru's Avatar
I got my "Hey, it's almost time for your 40k service!" letter today from my ever-concerned dealership today moneymoneymoney. Right now it's looking like it's going to be more of a 42k service (I have put 10k miles on the car in a little over four months holy CRAP). The letter didn't tell me what the service entailed, and there is no service book with the car-- just a printout of what was replaced under warranty and the dates of previous "milestone" services.
Soooo... what should I expect? The oil is due for a change (already), I know that much. But I know the trans fluid was replaced when I took delivery of the car. Are we talking, like, belt changes, things along that line? Is it anything urgent that can't wait until when I go back to work? I've been putting much fewer miles on the car now that I don't go anywhere, but I may make it to 45k before this is done.
Oh, and what should I expect to shell out to have the service done?
For the record, it's a 2002 9-3SE with an auto trans. Runs fine.
guru is offline
Old 08-17-2006, 12:37 PM   #2
AeroDynamic's Avatar
Send a message via AIM to AeroDynamic
shouldnt it be under warranty?
WHATS YOUR ALTITUDE?
510whp @18psi @5600rpm's "600HP or parts on the floor"
AeroDynamic is offline
Old 08-17-2006, 12:38 PM   #3
guru's Avatar
Warranty went up at the end of May. I don't think maintainence is covered under warranty anyhow... or if it is, it wasn't transferrable. Either way, car's OOW.
guru is offline
Old 08-17-2006, 12:39 PM   #4
stevehayes01's Avatar
Warranty does not cover service visits for wear items. I believe that this service is Oil change and plugs with a software update if available. I will check my book when I get home.
stevehayes01 is offline
Old 08-17-2006, 12:58 PM   #5
Trollerator
abdukted1456's Avatar
you might try a reputable indy.
the dealer would not even tell me the cost of a 50K service on the phone my indy did it for 40 bucks.
the dealer charges like 795 for 60K service, my indy charges 400 something.
the dealer charges 150+ to flush the tranny fluid.
my indy charges 9.95 or so (cost of new fluid)
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 08-17-2006, 06:57 PM   #6
VWSAABVT's Avatar
flush vs. change is a very different procedure. a 9.95 flush would be exellent.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 08-17-2006, 08:04 PM   #7
on this same subject if i have over 110k on mine and i bought it used (obviously) at about that what should i have done? what should i check to make sure that everything like that is kosher?
nowhereman1223 is offline
Old 08-18-2006, 06:11 AM   #8
Trollerator
no you're right it was just a drain and refill not flush but still they do everything for a much more reasonable price
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-18-2006, 10:50 AM   #9
stromer's Avatar
I'd ask in a new thread.
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 08-18-2006, 10:50 AM   #10
stromer's Avatar
Ali, you should be able to call up and see. I don't remember any of my servies being less than $75. I only did a couple though.
If I were you I would have an indy do an oil and filter change and call it good. Shouldn't be more than $25 for regular oil.
stromer is offline
Old 08-18-2006, 11:03 AM   #11
Trollerator
for my 50 K service they basically looked around and then changed the oil/filter and I had them replace the tranny fluid for 10 bucks more.
I think I padi 45 bucks for the 50K service
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-19-2006, 05:39 AM   #12
I would recomend an oil change and belts if they look bad. It is also time to learn some DIY to try and save as much money as possible.
Old 08-19-2006, 06:20 AM   #13
guru's Avatar
I do my own oil unless I'm heniously pressed for time So far I'm not totally comfortable DIY'ing belts though.
guru is offline
Old 08-24-2006, 12:24 PM   #14
The 40K is nothing. Personally I would just change the oil and move on.
The 40K is change oil, check this, check that. The 35, 70, and 90 are the major ones. For Mr. "110K" I would suggest doing the 90K major service.
Peregrine is offline
Old 08-24-2006, 01:01 PM   #15
guru's Avatar
Uh oh, there was a 35k?! I didn't get that memo! Fucking stealership
guru is offline
Old 08-24-2006, 01:04 PM   #16
Trollerator
at 1K there is a checkup to be sure everything is OK
then it is every 10K "checkup" plus oil
major service at 30, 60, 90, 120 etc
1990 900 turbo vert
2004 9-5 aero sedan
Old 08-24-2006, 01:39 PM   #17
guru's Avatar
I'm so confused, I'm used to driving cars that are older than I am that don't stick to any particular regimes, just "when it breaks, fix it"
guru is offline
Old 08-24-2006, 02:36 PM   #18
mg_td's Avatar
i think 40k isnt anything but an oil change. 60k gets you bigger ones. serp belt, fuel filter, brake fluid, coolant etc.
238.8 whp 272.1 wtq
mg_td is offline
