Intermediate Shaft Bracket Question - The Saab Link Forums
Old 07-28-2015, 03:36 AM   #1
The bracket on the middle shaft is what I am talking about.
1) I have developed a terrible vibration/shimmy at speed and judging by the grease flung everywhere, BOTH the axle and the bearing in that bracket have failed.
2) What is the p/n for that bracket and does the bearing within it press out? Do these fail frequently and is the grease a reliable indicator of failure? The axles don't seem to have any play when the car is on a lift if that means anything...
Thanks,
-Cm
Cm452 is offline
Old 07-30-2015, 07:28 PM   #2
srp
srp's Avatar
Send a message via AIM to srp
I replaced the bearing on my NG's intermediate shaft. It was held in with a circlip and required a little force on a press if I remember correctly. I replaced it as part of an entire front end over haul, so I'm not sure if it was bad or not.
Edit:
This appear to be them:
Carrier bearing: 12785906
http://www.eeuroparts.com/Parts/5976...ring-12785906/
Callout 23: http://www.thesaabsite.com/catalog/s...ont#cellgroups
Carrier bearing circlip: 12788653
http://www.eeuroparts.com/Parts/1206...-Ring-7973738/
Callout 24: http://www.thesaabsite.com/catalog/s...ont#cellgroups
srp is offline
Old 07-30-2015, 07:34 PM   #3
I've tapped the bearing in the intermediate shaft out after removing the circlip. It should come out even without a press. Just a hammer and tap all around so it moves evenly.
It is a sealed bearing so there won't be enough grease in it to fling. You can tell if it is bad by rotating it. It should be smooth. They are cheap and so since it was out I would replace it as preventative anyhow. If the bearing is loose in the bracket or on the shaft you need to replace the bearing and the bracket or the intermediate shaft (whichever it is loose on).
Tboy is offline
Old 07-31-2015, 04:24 AM   #4
Thanks gents! Good to see there are still some people hangin around these boards...
-Cm
Cm452 is offline
Old 07-31-2015, 04:50 AM   #5
bogan's Avatar
-Cm
yeah..its quiet these days !
bogan is offline
