***Boost gauge where headlight switch is - The Saab Link Forums
Old 07-26-2006, 12:24 PM   #1
griffen nut's Avatar
Send a message via AIM to griffen nut
Ok, I have a boost gauge and a ricer gauge pod which sits on my dash. I hate it. I want to clean my interior up and put the boost gauge where the headlight switch is.
#1) Will my gauge fit there. Here are the specs on it...
2 inch Gauge Holes; Gauge face is 2 1/16
#2) How hard is this? And any directions?
I searched this, but could only find that it was possible to do this, no instructions or specs on the gauge needed.
Thanks guys!
griffen nut is offline
Old 07-26-2006, 12:28 PM   #2
VAGGEN's Avatar
If you put your boost gauge where your headlight switch is, you wont be able to read your gauge too well. The switch is partially hidden by the steering wheel.
2004 9-5 Aero Wagon - SOLD - and missing it
2004 S2000 - 31,000 miles and counting much more slowly
VAGGEN is offline
Old 07-26-2006, 12:40 PM   #3
Saab93cse's Avatar
You need to do a little dremel work...
Saab93cse is offline
Old 07-26-2006, 12:48 PM   #4
Cpenning623's Avatar
Send a message via AIM to Cpenning623
just pull the headlight switch out, and test fit the guage.
I really think the one of the saab manufacturers should come out with the boost guage pod in the air vents like aud'i's
Cpenning623 is offline
Old 07-26-2006, 12:49 PM   #5
stromer's Avatar
Then the vent wouldn't work as well though.
No more "***" in front of every thread tittle, please.
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 07-26-2006, 12:54 PM   #6
mg_td's Avatar
i can see one half of the center vent used like that, but it probably wouldnt look so hot.
238.8 whp 272.1 wtq
mg_td is offline
Old 07-26-2006, 01:22 PM   #7
Voodoo's Avatar
Send a message via AIM to Voodoo Send a message via Yahoo to Voodoo
I've thought about putting a boost gauge in the light switch, but as others mentioned it's partially obstructed. You could turn the gauge so it sat at an angle where the important part (peak boost) was visible, but then that just messes with my whole "everything must be aligned and balanced" OCD and won't work for me.
Do the 9-3's have an a-pillar airbag?
2010 Mustang GT/2000 Saab 9-5 SE sportwagen
Voodoo is offline
Old 07-26-2006, 01:25 PM   #8
JK
JK's Avatar
No...but that is a funny thought - cruising along and *BLAMO* your gauge pod goes shooting out the passenger side window, or into your face
always a SAAB guy at heart
JK is offline
Old 07-26-2006, 01:25 PM   #9
AeroDynamic's Avatar
Send a message via AIM to AeroDynamic
yours shouldnt
WHATS YOUR ALTITUDE?
510whp @18psi @5600rpm's "600HP or parts on the floor"
AeroDynamic is offline
Old 07-26-2006, 01:30 PM   #10
Voodoo's Avatar
My Golf 1.8T had it and I put an a-pillar pod on anyway. Yeah... I'm smrt.
So I could just get a pod for it if I wanted to. Good to know, thanks.
Voodoo is offline
Old 07-26-2006, 01:31 PM   #11
does anyone have a picture of the audi boost gauge? That sounds kind of cool.
fieldsc is offline
Old 07-26-2006, 01:32 PM   #12
quattro's Avatar
I haven't had visibility problems but its distracting keeping an eye on both the gauge and road at the same time. Also, did anyone else have to remove the screw inside the dash just to the left of the lightswitch location? My gauge wouldn't fit flush without taking that screw out (I think its used to mount the vent).
But its an easy job, and 2/16 inch is 52mm, the same size gauge from speedparts sold by genuinesaab/elkparts.com. Just need a dremel tool to get it fitting snugly.
quattro is offline
Old 07-26-2006, 01:44 PM   #13
Does anyone have a DIY? I dont mind that it will be behind the wheel....i dont use the gauge that much anymore anyways and am going to keep my car fairly stock so monitoring boost isnt a priority, the clean look is more important to me...my pod looks so ricer right now
Old 07-26-2006, 02:16 PM   #14
Voodoo's Avatar
Clicky me.
AWE Tuning gauges are the shit. My ex has one in her GTI.
Voodoo is offline
Old 07-26-2006, 04:51 PM   #15
Does anyone know how to start this?
1.) Do you disconnect the wires that are attatched to the actual headlight switch?
2.) How do you get the wiring for the boost gauge BEHIND the headlight switch.
Old 07-26-2006, 05:01 PM   #16
Redfoxx's Avatar
Send a message via AIM to Redfoxx
they have stuff like that? you should provide picks so i can see exactly what you mean (if you can find any).
Redfoxx is offline
Old 07-26-2006, 05:04 PM   #17
rage22's Avatar
Clicky me.
thats pretty cool, i want one now
rage22 is offline
Old 07-26-2006, 05:53 PM   #18
its too hard, cuase of the shape of the air grille, and the way that it directs air, it has all those plates that align in a certian direction to direct the air.
it would be sweet though. I dont like a pillar guages as much as i did when i first got into cars, i think as factory as possible would be nice though, or a Digital boost guage in the dash, in place of the fake one.
or just have calibration, psi or BAR on the stock guage would be nice
Old 07-27-2006, 06:42 AM   #19
I did it, doesn't look bad, you can see it easy enough.
You should remove the dash to get the gauge bracket on properly. And plan on your lights being on all the time.
Old 07-27-2006, 08:55 AM   #20
I had to demel the opening so the switch won't ever fit back. You leave the light switch in the on position and cover it with some cloth (no rattles) and zip tie it inside/behind the dash. I also had to demel out the screw mount that is normally behind the light switch to get it to fit flush.
nbndtrain is offline
