Radiator Issues // Application of Stop Leak - The Saab Link Forums
Old 04-17-2014, 09:04 AM   #1
My fellow Saab lovers,
A mechanic has identified a small leak in the radiator causing the coolant reservoir to be used. Before I straight up replace the radiator I went and bought radiator stop leak to see if it could be a simple fix.
(2006 9-3 2.oT)
My question is where do I put the stop leak? I'm assuming directly into the radiator as the instructions state? Where on the radiator do I pour it into?
THANKS AS ALWAYS
L
logdeezylax6 is offline
Old 04-17-2014, 09:36 AM   #2
Dear lord, do NOT use stop-leak.
All that crap ends up in your cooling system forever, and diminishes performance for a lifetime.
If you MUST use it, you have to completely flush your cooling system so that it's 100% water. not 97%, not 99.99999%
100% water.
You then run the junk through until the water heats and the pressure pushes the stuff through the leak, and it seals the hole. After, you drain the water/junk and flush again, and re-fill with fresh coolant.
If your radiator is leaking where it's crimped, you can get some vice grips and re-clamp it. it's worked for me a couple times in a pinch, but you run the risk of doing damage if you're too aggressive.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 04-17-2014, 12:22 PM   #3
DrewP's Avatar
If the coolant is leaking into the automatic transmission cooling loop (a common problem on the earlier 9-3's, but no unheard of) the stopleak will destroy the transmission if it gets in there.
DrewP is offline
Old 04-17-2014, 01:20 PM   #4
oliversexpedition's Avatar
Probably better to know where the leak is and fix it. Might be able to fix radiator - stop-leak stays in the system forever.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 05-05-2014, 03:26 PM   #5
100% water.
Thanks for the words of advice. Decided against it, going to find leak and most likely replace radiator. OEM recommended? Or aftermarket okay here?
Tags
coolant, diy, radiator, stop leak
