Tire Tread Wearing Unusually Fast - The Saab Link Forums
Old 02-27-2014, 10:08 AM   #1
My Saab friends,
Tread on new front tires wears extremely fast on my 06 9-3 2.0T, especially on the outside of the tire. Traction control error code is on but I'm not sure it would cause it to happen in the manner and rate of which it is. Any ideas? Thanks
L
logdeezylax6 is offline
Old 02-27-2014, 10:12 AM   #2
Wagon Shaggin'
Saabeh's Avatar
Worn suspension component or bad alignment.
Saabeh is offline
Old 02-27-2014, 11:53 AM   #3
This will be the second time you have helped me, thanks!
When I purchased the car 3 years ago, my mechanic made mention that the rack-n-pinion(sp) may need to be replaced in the future but it wasn't an issue at the time. Could it be this? Furthermore, recently had alignment done and put new tires on it 3 days after; went back got it realigned with new and still the same thing.
I have found suspension kits on eeuroparts for a decent price. Is it hard to replace by yourself?
Your help is much obliged
L
Old 02-27-2014, 11:55 AM   #4
Wagon Shaggin'
Saabeh's Avatar
You dont need to replace the entire suspension, just the parts that are worn. Is the steering sloppy?
Saabeh is offline
Old 02-27-2014, 05:13 PM   #5
gm
gm's Avatar
Fast wearing even tread is more the result of a soft tread compound, which tires do you have?
Since it sounds like your tires are also wearing unevenly on the outside like stated possibly a suspension problem or so imply just a alignment issue. To much toe in as well as the wrong camber can cause this.
Or like stated it could be worn suspension compoents
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 02-28-2014, 06:31 AM   #6
Well I have ruled out the bad alignment. It drives as straight as an arrow; I live in TX so we have long straight roads. Well I can let go of the wheel and it won't start out of the lane until I move it or there is a corner.
If I'm going to have to replace parts within suspension wouldn't it be a good idea to replace the whole thing?
L
Old 02-28-2014, 07:29 AM   #7
gm
gm's Avatar
There can be to much toe in or toe out and it can still drive straight as a arrow
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 02-28-2014, 10:15 AM   #8
Agreed, driving straight as an arrow doesn't help you very much in identifying the problem.
You have wear on the outside of the tire - not even wear like GM mentioned. You have an alignment issue which could be caused by a broken/bent part, or just improper alignment.
BuHuSPG is offline
Old 02-28-2014, 10:41 AM   #9
Toe in is what makes the car track in a straight line. Soft tires, hard cornering and failure to rotate are the most likely factors/causes in my experience.
kdurl is offline
Tags
suspension, tires, tread, wear
