Error Code P0303 Cylinder 3 misfire - The Saab Link Forums
Old 01-27-2014, 12:05 PM   #1
Exclamation Error Code P0303 Cylinder 3 misfire
Hi Saab friends,
Check engine light came on and produced a "P0303" error code which according to this forum here
OBD codes! - SaabCentral Forums
Is a cylinder 3 misfire. Anyone have any prior experience with a similar problem? Is this something I can fix myself(novice mechanic, changed spark plugs by myself) or if it is not any general amounts for cost? Thank you all so much
L
06' 9-3 2.oT
logdeezylax6 is offline
Old 01-27-2014, 12:39 PM   #2
Wagon Shaggin'
Saabeh's Avatar
Well, I am assuming it could be a coil pack, failing spark plug or bad plug gap. Try swapping the coil pack on cyl 3 with the cyl 1 pack, resetting the code and waiting for the code to reappear. If it comes back as a cyl 1 misfire, I believe you need a new coil pack. If it returns on cyl 3 then you need to do some more digging.
Saabeh is offline
Old 01-27-2014, 02:13 PM   #3
When was the last time that you did the Spark plugs? Thats normally what causes the misfire. I would pull the plug and check it make sure its not dark or looks burned. If the blug looks good then I would go with what Saabeh said. If you haven't changed your plugs in like 6K to 9K miles that could be the issue.
Owning a Saab is like dating a super Model. It might cost more to keep around and it might need a lot of your time, But its well worth it.
Spartan81001 is offline
Old 01-28-2014, 11:37 AM   #4
Picture of Cyl 3 spark plug
Old 01-28-2014, 11:39 AM   #5
Wagon Shaggin'
Saabeh's Avatar
Looks pretty fucky.
Saabeh is offline
Old 01-28-2014, 11:41 AM   #6
So the last time I replaced the plugs was about 1,500 miles ago. As opposed to using the NGK plugs the guy at autozone recommended the Denso Iridium Power plugs. I went with these (I should note that the problem had begun prior to changing the plugs, so to try and fix it I did this). I used the Di electric grease and checked all of the covers to the spark plugs(sic) and everything appeared to be okay. This it only seems to happen when max psi is being applied to the turbo and when the engine has already been running and is at the half way mark of the temperature gauge
Old 01-28-2014, 11:43 AM   #7
Originally Posted by Saabeh View Post
Looks pretty fucky.
yeah I agree lol. The problem has persisted even after putting in new plugs
Old 01-28-2014, 11:44 AM   #8
Wagon Shaggin'
Saabeh's Avatar
Swap coils around and see if the code changes.
Saabeh is offline
Old 01-28-2014, 11:53 AM   #9
going to try this. Thanks for the help. Does having a bad coil pack make the engine susceptible to further damage? Do all 4 have to be replaced or can it be replaced individually?
Old 01-28-2014, 11:58 AM   #10
Wagon Shaggin'
Saabeh's Avatar
You should be able to replace them individually. Just need to figure out if its the problem. Could be a few other things, but lets rule out the coil pack by testing it first.
Saabeh is offline
Old 01-28-2014, 12:39 PM   #11
The first problem here is you listened to the Autozone guy! those guys are normally stupid when it comes to anything that has to do the a Saab. If you get more make sure you get the OE replacement ones. They sold my buddy ones that where like a 3 heat when they should've been 7 I believe and his car ran like crap.
Old 01-30-2014, 09:29 AM   #12
I have since changed the coil packs from cyl 3 to cyl 1, the check engine light has since turned off however the problem still persists. I do believe it is the coil pack for certain, as when I removed all 4 plugs and packs the plug on cyl 3 looked very worned and used when these just got replaced a mere 3 months ago; the other three looked brand new. Will post a picture when possible
Old 02-01-2014, 04:04 PM   #13
anyone have a recommendation on where to buy a coil pack from?
Old 02-02-2014, 12:04 PM   #14
DrewP's Avatar
Local dealer, eEuroparts, RockAuto, even O'Reilly's. Don't get aftermarket parts, the OEM coils should be made by Bosch.
DrewP is offline
Old 02-07-2014, 02:46 PM   #15
I have since replaced the coil and also the spark plugs back to the NGK 10G. The NGK part number is 5542 for anyone who would like to know for future reference. The difference with the new coil and OEM plugs is night and day!!!!
Old 02-10-2014, 11:55 AM   #16
Admin, interested in a sticky for changing plugs/coils? I have pictures
Old 03-04-2020, 11:20 AM   #17
Talking Autozone workers are idiots
Took my saab in to autozone with P0303 he told me my engine was bad. complete tools!
saabygirl is offline
Old 03-07-2020, 01:57 PM   #18
jssaab's Avatar
Make sure you only buy recommended spark pugs not the "ones that will ""fit"" that autozone will sell you. I have seen wrong threads, longer reach, pugs offered as "correct" by those "tools"
jssaab is offline
Tags
check engine, engine, error code
