problems after jump start - The Saab Link Forums
Old 12-24-2012, 10:08 AM   #1
2003 saab 9-3 vector
Well I knew my battery was taking a dive and it got down to -5 last night so needless to say it was dead this morning... tried jump starting it, wouldn't go... threw the charger on it, waited for a bit and fired it up...
Nooowww... I turn the radio on and the only sound comes out of the front right door speaker... and all it is is a very high pitch of whatever is playing on the radio with a lot of squiggles...
Checked all fuses... nothing is bad... pressed the on star button, that all comes through flawlessly!!! Any suggestions??
zep40man is offline
Old 12-29-2012, 09:54 PM   #2
Anyone??? ICM or AMP1? Thinking amp if all my displays still work fine, just not getting any sound other than distorted crap out passenger front door... and my blinker noise is fine
zep40man is offline
Old 12-30-2012, 08:42 AM   #3
SPG-GASM's Avatar
Have you installed a new battery?
SPG-GASM is offline
Old 12-30-2012, 10:29 AM   #4
DrewP's Avatar
Could conceivably be anything in the audio system loop, in addition to AMP1 and ICM the EHU (electronic head unit, it's stacked on top of the CD player/changer behind the climate control panel) sometimes goes bad too.
But - usually when any of those goes bad everything stops working and you get no sound at all. New battery and try re-setting everything like SPG-GASM suggested. At the very least, shut the car off, wait at least a minute, then disconnect the battery terminals and touch the + and (-) cables to each other to discharge all the computer modules. Then re-connect the battery and see if it's any different.
DrewP is offline
Old 12-30-2012, 12:23 PM   #5
Yeah new battery... I've left the battery cables off over night in hopes something would reset, nothing happened... but I didn't touch the cables together. Any other resets I can try?
I spent a good three hours last night trying to search for causes online but none fit mine exactly, especially since my turn signal sound still works.
Anything else I can check? Thanks
zep40man is offline
Old 12-30-2012, 12:49 PM   #6
DrewP's Avatar
Not really, time to get it to a shop with a Tech2 and see if they can tell what might actually be fried.
DrewP is offline
Old 12-30-2012, 12:50 PM   #7
Disconnected battery... touched both cables to a steel pry bar... no change.. curious, if amp controls door speakers and center speaker.. why do they replace it if a person isn't getting indicator sounds out of the left DASH speaker.. that's where my indicators are?
Still only have noise... yes, noise, nothing good, out of the right front door speaker
zep40man is offline
Old 12-30-2012, 12:52 PM   #8
How would they know? Will the tech2 just not be able to communicate with it? I live a good three hours from any dealer that will actually know how to work on a gm other than a chevy so I'm trying to get as much info as I can before I just bring it to someone around here.
zep40man is offline
Old 12-30-2012, 01:00 PM   #9
DrewP's Avatar
If something is fried completely it won't communicate, but it sounds like yours is doing something inbetween. Not something I have seen before, probably why you haven't found anyone post with similar symptoms.
DrewP is offline
Old 12-30-2012, 01:17 PM   #10
pretty sure if you check the owner's manual they list a handful of fuses to pull before you jump start (almost all related to audio system). Not much help now though
Also pretty sure you've cooked amp 1
seriks1 is offline
Old 12-30-2012, 01:31 PM   #11
Was just curious what unit would be the more probable cause? The amp1 since all my displays and stuff still work??
zep40man is offline
Old 01-06-2013, 04:00 PM   #12
Where can I get a new amp? I can't find one anywhere... and this wasyl guy from saabradio just seems shady and I haven't heard much good stuff in my searches... until I can find one, does anyone know where I can go to get some sort of bypass to maybe just plug in? I don't think I'm smart enough to figure the bypass out on my own and make it work lol
zep40man is offline
Old 01-06-2013, 06:45 PM   #13
nowhereman's Avatar
you need to be careful jump starting these. you can easily fry lots of things.
in this case it sounds like you toasted part of the amp. onstar doesnt go through the amp which is why it works fine.
grab the part number and go to ebay or SAABPARTSUSA.COM they should have it
2008 9-3 SS: Stg 1
nowhereman is offline
Old 01-07-2013, 06:10 PM   #14
hey check this site out:
Bus and diagnostics communication - Saab 9-3 (2003-2006)
cardiac.traumarn@gmail.co is offline
Old 01-14-2013, 05:53 PM   #15
Finally took my amp out today and found white ooz coming from one of the capacitors, I see someone else had the same problem,? Replaced the capacitor but never updated if it worked or not... I don't mind sending it in and getting refurbished unless its not the problem. I guess I'm confused why my blinker noises still work as when every other amp I see fried on Google, all the warning sounds go away too. Does anyone else have feedback? Send er in and get refurbished or could it be something else thBns
zep40man is offline
