changing ecus via tech 2 process? - The Saab Link Forums
Old 04-18-2011, 02:17 PM   #1
GreySPG's Avatar
Can someone please post the process on how to change out an ecu via tech 2? I have access to one but dont know the step by step process.
thanks
AeRoTK2
GreySPG is offline
Old 04-18-2011, 02:55 PM   #2
Chadwick's Avatar
You need a CANdi module and security access.
Go to year, model, diagnostics, all, get security access.
Disconnect the battery and install the new module. It really isn't necessary to actually go through the "remove" process on the Tech 2.
With the new module installed you'll probably have to go in to the Service screen under the ALL menu and force the key unlock to continue since the new ECU will lock out the ignition switch and give you an immobilizer failure.
then go to the All menu, Add/Remove, Control Modules, then ECM. Just follow the instructions on the screen. The final step is to clear DTC's.
Make sure its on a battery charger when you do all this. If it dies it will brick the ECU. Also, if you're adding a performance ECU, never SPS update the ECM software as it will overwrite it.
-Chad
Chad Lowers
'00 9-5 Aero
Chadwick is offline
Old 04-18-2011, 03:03 PM   #3
GreySPG's Avatar
also can i unlock the sid via tech 2?
thanks
AeRoTK2
GreySPG is offline
Old 04-18-2011, 04:29 PM   #4
StX221's Avatar
Cant unlock the SID with Tech 2.
The way that I have always married a new T7 ECU is this:
Go to TWICE and divorce the radio.
Then shut the car off and swap ECU's.
With the new ECU in, go back to TWICE and "Program Immobilizer". You will have to wait the 270(?) seconds before it will program it.
Then re-marry the radio and all should work just fine.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 04-18-2011, 04:34 PM   #5
GreySPG's Avatar
lol so theres more than one way to do this? and it is an aftermarket ecu. whats the difference? just a different way thats easier?
AeRoTK2
GreySPG is offline
Old 04-18-2011, 04:38 PM   #6
StX221's Avatar
Kind of sounds to me like chadwick is giving the steps to swap ECU's with a sports sedan, because I have never heard of what he is talking about with a t7 ecu...
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 04-18-2011, 04:43 PM   #7
GreySPG's Avatar
pete vella said something like needing the vin number &immobilizer number off the female ecu plug or something.
AeRoTK2
GreySPG is offline
Old 04-18-2011, 04:46 PM   #8
StX221's Avatar
Wait a second. I have been assuming you are talking about your viggen. Am I incorrect?
I should probably have looked at the section this was in...
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 04-18-2011, 04:55 PM   #9
GreySPG's Avatar
yeah my 2000 viggen
AeRoTK2
GreySPG is offline
Old 04-18-2011, 04:57 PM   #10
StX221's Avatar
Then go with the steps I said, it should work just fine. Like I said before, I am pretty sure that Chadwick was talking about a sports sedan.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 04-18-2011, 04:57 PM   #11
GreySPG's Avatar
great. now i learned how to read i fucked up and posted in the wrong section. i should just sick to my spg.
AeRoTK2
GreySPG is offline
Old 04-18-2011, 07:53 PM   #12
Chadwick's Avatar
Yes that was for a 9-3SS. All you need to do on T7 is program the immobilizer. Easy.
Chad Lowers
'00 9-5 Aero
Chadwick is offline
Old 04-19-2011, 04:41 AM   #13
Chadwick's Avatar
Oh, you also need to clear DTC's when you're done. Still easy.
Chad Lowers
'00 9-5 Aero
Chadwick is offline
