Check engine light goin on and off window rolling half-way up and back down. - The Saab Link Forums
Old 12-27-2018, 09:08 PM   #1
Doubtful the two are related however they did both start at approx same time. The window will roll fully up only when i begin driving the car. If i am in park and I put the window down it will only roll a third of the way back up before automatically going back down. Extremely perplexing. Idk where to start. Any hints advice or whatever greatly appreciated. 2006 9-5 aero w 82kmi. V6 & MANUAL TRANS.
Sent from my SM-S327VL using Tapatalk
briank3nney is offline
Old 01-05-2019, 08:38 AM   #2
My 2008 93 linear had the same problem in that sometimes the window would roll down on it's own when I tried to raise the window.
Dealer said to: key off, unplug the wiring harness for the drivers door at the hinge pillar, turn the key to start, turn the key off and re-connect the harness.
Don't know if this applies to your 95 but it is worth a try.
brown is offline
Old 03-29-2019, 08:12 PM   #3
Just seeing this.
Thank you.
Will be trying it in the a.m.
Old 04-04-2019, 01:20 AM   #4
You may want to check for:
> a bad/lose fitting connector at the pillar. Saabs connectors are always suspect as they get older.
> The connector plastic shells last a long time, but the soft male/female PVC/whatever material wire socket insulation dries out and crumbles allowing for intermittent connection
> bad oxidized/corroded ground point in the circuit
> an open or intermittent break in one of the wires to/from the door wire harness
> a short or intermittent short in one of the wires to/from the door wire harness
> bad user switch or relay (if relays are used in circuit)
warrens50 is offline
