93 900s starter mount problem - The Saab Link Forums
Old 12-21-2011, 02:43 PM   #1
I just got an 93 900s convert. Starter wouldn't engauge to turn over the motor so while checking it, I found the large plate is broken where the starter mounts to. My question is, can I, weld it, replace it, or rig up another plate to hold the starter rigid? One of the mounting holes is fine, but the other one is on the "broken off" piece. If the plate is a replacement part, where do I get one and how do I go about getting to it? I would imagine I would have to take off clutch, flywheel, etc. Thant correct? Thanks for any/all help you can give.
I have posted this in the "car problems" post as well.
khartman is offline
Old 12-21-2011, 03:11 PM   #2
turbocon86's Avatar
By plate, I'm assuming you mean the engine front cover. If so, I won't even ask how that got broke. I think your best course of action right now would definitely be to try and weld it in situ. It is aluminum, so you'll have to have that welding talent to do it.
To replace it, you may have to pull the motor and separate the motor from the tranny. I can't recall at the moment weather there is an alignment pin at the bottom that won't allow you to just unbolt it and pop it off. with the motor and tranny together.
EDIT: just looked at my Bentley Service manual. There is no alignment pins, so it looks like you could take it off with the motor in the car. You will certainly have to remove the clutch and flywheel though.
Can you post a picture of said breakage?
1993 900T Comm Ed #3
1993 900T Comm Ed #249
1994 900T Comm Ed #363
turbocon86 is offline
Old 12-21-2011, 03:33 PM   #3
Yes it is the plate between the engine block and the fly wheel, in my searches seems they call it the "engine back plate". The previous owner had a new starter put on and I guess the guy that did it broke the plate. Unfortunately, the guy I got if from failed to mention that little problem. It was JB Welded but it wasn't holding. I will try to post a pic of it tomorrow as it is night here now. BTW, how do you post pics on here? Thanks.
khartman is offline
Old 12-21-2011, 03:49 PM   #4
turbocon86's Avatar
You have to have the image hosed online somewhere like one of the free image hosting sites (Photobucket or Flickr or ImageShack for ex.) Then, when you make a new post, click the little square mountain and sun "insert an image" icon. Then paste the url of the individual image in the entry field. Don't post the url of the page it's on, you need the actual image url.
Or you can just put the image's url between image tags --[img]--before the url, and --[/img]-- after (only without the dashes).
Old 12-22-2011, 02:55 PM   #5
I will give it a try. Do you or anyone else on here have an idea if I can find one of these plates? Thanks.
khartman is offline
