How wide is a 99? And what heads will work. - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Vintage Forum > General 99 and 90 Posts and Information
General 99 and 90 Posts and Information Please post general and technical information pertaining to the Saab 99 and 90.
Old 11-08-2011, 05:56 AM   #1
I may have a place in doors at my nearby other work to work on this car. The door seems 5.5 feet wide. But outside there may be a staircase in the way.
Also I can snag an 85ish N.A. 8 Valve head, will this work on the 78 B motor turbo?
I also plan on snagging the spindles and calipers from it, these bolt right up without much hassle?
Old 11-08-2011, 06:10 AM   #2
Sedan's Avatar
Send a message via AIM to Sedan
It's as wide as a 900, I don't know how wide that is. Wider than a 96, narrower than a 9000.
An 8-valve H-motor head would not work without a lot of modification and I don't think there would be much benefit to it. There's a guy who put a 16-valve H-motor head on a B-motor block in his really nice red 99 sedan and it took quite a bit of modification, I remember seeing it at SOC10. You'd be better off going with either a complete H- or B- motor. Keep in mind that if you do the H-motor you'll need to put a dimple in the firewall to accommodate the water pump pulley.
Also, yes, '87 and early 900 front spindles and brakes will bolt right on. This is a good modification as it makes the front rotors on a 99 much easier to change. This is one of the first mods I did to my long departed '76 99 EMS that I drove in college.
'64 96/'72 96/'86 9000 Turbo/'89 900S/'01 9-5 Aero
The Saab enthusiast formerly known as Notchback.
Sedan is offline
Old 11-08-2011, 07:06 AM   #3
PaulH's Avatar
66" according to the internet, or exactly 5.5 feet! sounds a little tight to me.
Paul
PaulH is offline
Old 11-08-2011, 07:35 AM   #4
Moonracer's Avatar
Years back when I had my 99 Turbo I liked using the very early B engine head. They seemed less prone to cracking. The easy way to tell them was that the exhaust studs/bolts used a 17 mm socket instead of the more common 13mm socket.
Moonracer is offline
Old 11-08-2011, 09:03 AM   #5
spgproject's Avatar
Paul
a good coat of wax should help.
-Sir William Lyons
spgproject is offline
Old 11-08-2011, 01:03 PM   #6
Ok, so no on the head, I will hope nothing is tragically wrong with the one it's got.
I will definately grab the spindles and clippers off the 85 sitting at the Mt. Airy yard.
Old 11-08-2011, 01:07 PM   #7
BurnsSide42's Avatar
I MAY have a one of a kind 99 brake setup for sale if I upgrade them to the proper ones the car was intended to have... gives you later 9000 front brakes
Check out
for your repair needs
BurnsSide42 is offline
Old 11-08-2011, 03:30 PM   #8
PaulH's Avatar
You should shoot for vented front rotors, the hubs are specific, should be all 86 turbos, and 87 turbos and S models. You should hold off and go to new ringgold with us, there are at least 4 of those cars there with good hubs, and that place is gonna be way cheaper than crazy ray's.
Paul
PaulH is offline
Old 11-09-2011, 03:27 AM   #9
plasticfoodwrap's Avatar
has anyone thought of a tape measure. or maybe looking up the specs for a 99. just a thought.
Plasticfoodwrap SE Pennsylvania Saab Club
Cars
72 Sonnet
72 96
90 miata
plasticfoodwrap is offline
Old 11-09-2011, 09:00 AM   #10
Paul
Hmmmm - Yes?
Check out
Old 11-09-2011, 09:57 AM   #11
I looked hi and low for a tape measure at the funeral home, no luck. Also when I have a tape measure, there doesn't seem to be a 99 around.
Old 11-09-2011, 11:14 AM   #12
DrewP's Avatar
They're the same width as a C900.
DrewP is offline
Old 11-09-2011, 04:10 PM   #13
oliversexpedition's Avatar
Yea just measured the second garage bay, just under 8ft wide with enough room for C900, hopefully will have enough room so that I won't have to do the Dukes of Hazzard
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 11-09-2011, 10:58 PM   #14
Leif 78T's Avatar
I might be wrong but shouldn't you stick to heads that came off a turbo due to them having sodium filled valves?
Leif 78T is offline
Old 11-10-2011, 05:13 AM   #15
According to thesaabsite, the exhaust valves are the same all the way up to 88. It's the intake valves that are NLA and car specific. But I don't yet know that I need them. Have to get the head off the car and take it to my machine shop.
As for New Ringold, I may head up in 2 weekends. I'm working my days off this week so that I can finally have kiss my ass money.
Old 11-10-2011, 06:15 AM   #16
Stripper Money?
Check out
Old 11-10-2011, 05:43 PM   #17
Yea going to pick up a head at Fairfax, they wanted too much money to replace 4 exhaust valves on an 88.
99 9-5 Wagon
01 9-5 Sedan
94 C900 Vert - Sold
94 325i Vert
Tags
saab 99 girth
