1970 99 coupe GT3 - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Vintage Forum > General 99 and 90 Posts and Information
General 99 and 90 Posts and Information Please post general and technical information pertaining to the Saab 99 and 90.
Old 08-23-2011, 01:24 PM   #1
Send a message via AIM to Boosted Shoe Send a message via MSN to Boosted Shoe Send a message via Yahoo to Boosted Shoe
1970 99 coupe GT3
Resuming work on my race car project, had a post on here way back in the day but figured I'd give a little more history on it. This car was a sister to Jack's car from MSS in NY, Jack's car has long since been gone and as far as I know this is the only one left in the nation set up like this (I could be wrong). I have SCCA logbooks dating back to 1978 when it was first raced, my father purchased it in 1982 and towed it back from NY in a 1976(?) Saab 99 EMS. Has been in my family basically since '82. Somewhere along the line my dad sold the car to a friend of his. At the time of sale the car had only two small dents at the bottom of the drivers door, I will be posting pictures very soon hopefully and you'll see what has happened when it left our hands. The car was last raced in 1995 where a roll pin in the trans broke leaving us with only 3rd and 4th gear, car still finished on the podium.
More about the car itself. Front fender flares are brazed on (talk about old school) rear flares are fiberglass. Wheels are magnesium 15x7 wheels. Front brakes have ventilated rotors adapted from some sort of Chrysler product, rears are all stock. 4-piston front calipers. Dual brake master cylinders, MSS swirl tank for the cooling system, Accu-sump, Brake arrestors mounted for front and rear brakes. 4-2-1 header built by MSS, MSS cam, twin weber DCOE-45 side draft carburators, Stock saab performance catalog rear shocks, adjustable pan hard bar, koni adjustables front (red).
Now for the best part, transmission has Straight cut Saab rally gears with interchangeable ratios (lost all of those when my dads barn burnt down). Can get stock turbo ratios and drawings and whatever Jack from MSS has left, will be buying those as I doubt anyone else has a trans that would acept them. Trans is also equipped with an LSD.
I acquired this car in 2008 and started working on it in 2009 when I lost my job, sat since then, and now that I'm working at the family Saab shop I'll be pulling some longer hours to get it back into race trim and fix the body work. Pictures will be posted soon. Car is not for sale, nor are any of the vintage speed parts. Just want to restore this car and preserve some Saab racing history.
Beater: 92 900T 5spd
Wifes DD: 00 9-5 wagon 5spd Aero engine swap Stg 1 tune
Toy: 1970 Saab 99 coupe GT3/GTU
Boosted Shoe is offline
Old 08-23-2011, 02:23 PM   #2
DrewP's Avatar
Originally Posted by Boosted Shoe View Post
Front fender flares are brazed on (talk about old school) rear flares are fiberglass....... Wheels are magnesium 15x7 .......Accu-sump, ....... 4-2-1 header built by MSS, MSS cam, twin weber DCOE-45 side draft carburators, ......... Straight cut Saab rally gears ...... LSD.......
Perfect. This will be fierce.
DrewP is offline
Old 08-23-2011, 03:29 PM   #3
jk88's Avatar
Sounds epic. Can't wait to see pics.
jk88 is offline
Old 08-23-2011, 06:09 PM   #4
Pictures the day I picked up, oh so long ago
Old 08-23-2011, 06:13 PM   #5
More pictures of the car day I got it and when I started tearing it down, note dead rat in upper radiator outlet
Old 08-23-2011, 06:18 PM   #6
Body work resumed, very very many dents do be rid of and I need some more tools to do so yet
Old 08-24-2011, 06:31 AM   #7
Aikmanson's Avatar
wow, keep it up.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Aikmanson is offline
Old 08-24-2011, 07:49 AM   #8
Thanks, I'll keep posting up progress. hoping to retrieve the engine and carbs this weekend and start tearing that down.
Old 08-24-2011, 07:55 AM   #9
DrewP's Avatar
Did you already sand all the old paint off? Was it sanded before? The 99's all had cold-dipped zinc plating on the entire steel shell after it was welded together before it went for paint, if you use a chemical stripper to take the paint off rather than abrasive it leaves the rust-protecting zinc layer intact.
There's some good shots and explanation in this build thread of Luke's on the Rally forum:
• View topic - '75 99 Rally Car Restoration
This door is not painted, that's the bare zinc coating over the bare metal.
DrewP is offline
Old 08-24-2011, 08:01 AM   #10
I did not know that, i went after it with a wire brush, I had to get through the bondo that it had to see what i was working with, the paint stripper I was using didn't work so well so I got a little over zealous perhaps. Wish I had known that and what stripper would work.
Old 08-24-2011, 08:22 AM   #11
Green9kAERO's Avatar
That is a bad ass Automobile! I wanna see some vids of a Carb'd 99 driving around
Green9kAERO is offline
Old 08-24-2011, 09:45 AM   #12
Rest assured I might try and put some plates on it and drive to mcdonalds or something on the slicks and order from the drive through, hoping i don't get pulled over first haha
Old 08-24-2011, 02:42 PM   #13
Geoff's Avatar
Wow, awesome! I hope you re-do some of the graphics like the very '70s "99"
Those gears that Jack had are for the primary drive gears of a gear-drive transmission (like you have). Most people use the chain drive because they're stronger. I have two friends who have S&R gearsets for the earlier gear-driven primary boxes but you can modify a shaft from a chain-drive box so you can use that gearset in a chain-drive box. You can swap out the chain-drive ratios too, but most of what is available is stock #4, #5, #6, #7 primary ratios. I seem to remember Jack's custom primary gear ratios being shorter than a #4 chain drive set.
Have you checked out the SAABRALLY.COM forums? There are some other 99 & 900 race cars in various states of disrepair. Your car would fit right in
Geoff is offline
Old 08-25-2011, 05:51 AM   #14
I did check them out, and then I thought, wait I think I'm a member there, and sure enough it turns out I still had my membership there. My last post was in 2008 but it was still there haha. I did talk to Jack not too long ago (on Tuesday I think) and he had some miscellaneous primary gears still there, so I think I will buy those from him and see if he won't sell me the drawings too. Not many people are using the gear drive transmissions so if I get the gears made for me I don't think that would be an issue.
I do plan on recreating as much of the graphics on there as possible, would love to have those numbers painted on the doors again. If not I suppose vinyl would work in a pinch :\
Old 08-26-2011, 06:05 AM   #15
tuner4life's Avatar
I love this project!!
-Jason
1992 Saab 9000 Turbo - Cirrus White
1986 Saab 900 Turbo SPG Clone - Admiral Blue
1992 Saab 900 Base - Talladega Red
tuner4life is offline
Old 09-12-2011, 05:09 AM   #16
Just keeping the thread alive, not much for updates so far :/
Old 10-03-2011, 08:55 AM   #17
Bumpin it to keep it alive, plan on doing the body work with tax return come tax time
Old 10-05-2011, 08:08 AM   #18
are you going to do scca with this car once it is done?
im in your area and a scca member as well as a fellow 1970 saab 99 owner.
pm me if youd want any more information.
saab99 is offline
