Thermostat on a 99 Turbo . . . - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Vintage Forum > General 99 and 90 Posts and Information
General 99 and 90 Posts and Information Please post general and technical information pertaining to the Saab 99 and 90.
Old 06-27-2009, 11:30 AM   #1
GA
GA's Avatar
. . . please school me.
(It's gotta be the thermostat, temp gets very high in less than 6 blocks of driving, but I can touch the radiator and it doesn't feel all that hot to me).
GA is offline
Old 06-27-2009, 11:43 AM   #2
Rudedog's Avatar
Yup.
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 06-27-2009, 12:02 PM   #3
PaulH's Avatar
You probably need a new one of those.
Paul
PaulH is offline
Old 06-27-2009, 02:30 PM   #4
GA
GA's Avatar
Any replacement tricks, or is it just like doing a c900? I noticed that the part number for the turbo's seems to go all the way from '77 to '93.
GA is offline
Old 06-27-2009, 05:02 PM   #5
DrewP's Avatar
Is the upper radiator hose (downstream of the thermostat) hot, are you sure the water pump is pumping?
Do you have the early B engine with the jackshaft driven pump, or a later C900 engine with the belt driven pump?
Best,
Drew
DrewP is offline
Old 06-27-2009, 07:22 PM   #6
GA
GA's Avatar
It's a B engine originally out of a '79 900 turbo - with about 130,000 miles on it. Edit -- I will have check on the hose.
GA is offline
Old 06-27-2009, 09:46 PM   #7
DrewP's Avatar
I only asked because with the shaft drive water pumps on the B engines (under the cover on top of the block) it's not out of the questions that the impeller shaft seized, and the gear teeth on the jackshaft and impeller shaft got ripped off and the pump impeller just isn't spinning.
If it's spinning and pumping some coolant you should at least feel a little heat in the hose just downstream of the T-stat, if it stays completely cold when the coolant temp is reading on the hot side, it might be worth popping the cover off and varifying that the impeller turns when you rock the car with it in gear to rotate the engine a little bit. If the engine turns and the impeller doesn't move then it's water pump.
Hopefully it's just a stuck t-stat.
Best,
Drew
DrewP is offline
Old 07-26-2009, 11:51 AM   #8
GA
GA's Avatar
Yep, it was the thermostat.
Pulled out the old one and it had stringy stuff wrapped around it. It was like pulling hair out of a drain. Not a ton of it but more than enough to go Hmmm.
Put the new one in, let it idle for 30 minutes, everything was fine.
GA is offline
Old 07-27-2009, 05:19 AM   #9
Moonracer's Avatar
Good to hear Greg, After making the trip from Meyer to the Cities the shaft should have failed by then.
Moonracer is offline
