chillcast 4-spd transmissions - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Vintage Forum > General 99 and 90 Posts and Information
General 99 and 90 Posts and Information Please post general and technical information pertaining to the Saab 99 and 90.
Old 10-22-2006, 10:09 PM   #1
c900's Avatar
What years did the 'chillcast' 4-spd transmissions get fitted to 99's? Or where they always just a factory option?
Craig.
Craig Dewick - Tronno, NSW, .au -
c900 is offline
Old 10-23-2006, 07:14 AM   #2
PaulH's Avatar
well its really hard to get that info, from what i can tell it was mostly 78 99t's, but definitely not all of em, cause at least one of the 3 99t's i have, didnt have a chillcast box in it.
Paul
PaulH is offline
Old 10-23-2006, 07:12 PM   #3
saabsbreakdown's Avatar
Send a message via AIM to saabsbreakdown
No one told me if i can put semi truck parts in a 99 box yet and have it work or not. I WANT A MILLION HP TRANS
Car 178 - 1975 Saab 99 EMS
saabsbreakdown is offline
Old 10-23-2006, 07:27 PM   #4
GA
GA's Avatar
Flying cars. We were supposed to have flying cars by now. Where are my flying cars?
GA is offline
Old 10-23-2006, 07:37 PM   #5
your not taking me seriously. no one is.
I want to have a 4 speed with semi truck gears in it. we all need one. research must be done!
Old 10-23-2006, 08:21 PM   #6
PaulH's Avatar
i havent tried it yet, but im gonna go out on a limb here and say that the semi gears wont work. just guessing....and yeah, flying cars, what the hell happened to that? its all the damn Jetsons fault for getting our hopes up!
Paul
PaulH is offline
Old 10-24-2006, 06:01 PM   #7
spgproject's Avatar
fuckin jetsons.........
dammit
-Sir William Lyons
spgproject is offline
Old 10-24-2006, 07:18 PM   #8
Deez Nutz
Palmer's Avatar
That shit folded up into a suitcase too.
WTF?
S55/LC100/KL
Palmer is offline
Old 10-24-2006, 07:56 PM   #9
PaulH's Avatar
total bullshit, i want one of those houses on a stick too.
Paul
PaulH is offline
Old 10-24-2006, 08:01 PM   #10
Deez Nutz
Palmer's Avatar
You could change the height of the house too, if the weather sucked.
S55/LC100/KL
Palmer is offline
Old 10-24-2006, 10:00 PM   #11
i want my fuckin semi gears you douche nozzles
Old 10-24-2006, 10:04 PM   #12
Deez Nutz
Palmer's Avatar
Cram your gears.
S55/LC100/KL
Palmer is offline
Old 10-25-2006, 06:42 AM   #13
JK
JK's Avatar
Originally Posted by Palmer View Post
Cram your gears.
That is exactly what he wants to do...cram them inside a 4 speed case. Yes, cram them.
always a SAAB guy at heart
JK is offline
Old 10-25-2006, 06:58 AM   #14
If this thread starts to make sense again, I'm curios in finding out how you determine what tranny is chilcast. like a casting number or something.
Old 10-25-2006, 07:00 AM   #15
PaulH's Avatar
i think there is a casting number, but more reliably, the cases physically look different, ill try and dig up some photos.
Paul
PaulH is offline
Old 10-25-2006, 07:17 AM   #16
PaulH's Avatar
allright here we go, found this on 900aero.com, they have some good info on there.
these are pics of a chillcast box:
heres one thats not chillcast, this is what the one we pulled out of one of my 99t parts cars looked like.
if you look at the two cases, the chillcast one has more ribbing, and the three ribs in the oilpan area are at an angle rather than straight up and down as on the no chillcast one.
Paul
PaulH is offline
Old 10-25-2006, 07:27 AM   #17
PaulH's Avatar
allright some more info from SC
1. The cast number is supposed to be 870423 or 871239. Of these numbers there are many casts of different strength. You can say that all these housings are very strong, but if you want the strongest it is the one with 3 diagonal ribs on the forward right corner in the oilpan.
2. How to se if it is a strong cast is to look at the ribs on the right side of the transhousing. They are horisontal. This is the easiest way to be sure.
3. The primary housing should have 3 strengthening ribs under the slave sylinder that is 1cm wide and with a distance of 3cm between each. If it is 3cm wide ribs with 1cm between each it is wrong! You can take a look at the 5speed gearbox to see what it should not look like.
so in the pics above, the top one is the strongest cast, the other one is apparently one of the weakest casts, but still stronger than the 5spd since you have thicker gears to start out with.
Paul
PaulH is offline
Old 10-25-2006, 10:21 AM   #18
gm
gm's Avatar
how to make stronger C900 trans
Cryo & shotpeen gears/lay shaft
trans oil cooler
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 10-25-2006, 10:35 AM   #19
PaulH's Avatar
dead on, thats my plan for the next box, but starting out with a better case (chillcast 4spd) is always a good thing.
Paul
PaulH is offline
Old 10-25-2006, 10:49 AM   #20
StX221's Avatar
i think the trans oil cooler might be the key to this one...
but then again, i dont know my c900's like you guys do.
but my thought, if you can keep the gears cooler, then maybe the chance of stripping teeth off any gear is less?
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
