Headgasket retorque - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > General 9000 Posts and Information
General 9000 Posts and Information Please post general information pertaining to the Saab 9000.
Old 02-16-2006, 11:37 AM   #1
BluAero's Avatar
Send a message via AIM to BluAero
Headgasket retorque
Hey guys I was wondering if anyone could help me out with instructions to retorque the head gasket.
Btw, this summer I want to do a new headgasket so maybe sometime when the weather is better I would take a road trip somewhere and some of you guys could help me out.
BluAero is offline
Old 02-16-2006, 12:06 PM   #2
Nick Taliaferro
GenuineSaab's Avatar
This should help. Start at 1 and only one at a time.
http://www.genuinesaab.com/psi/files/headretorque.htm
For more info:
Nicholas Taliaferro
GenuineSaab is offline
Old 02-16-2006, 12:06 PM   #3
Editor
There's a tutorial on this somewhere. It's really easy. Someone sent me the PDF, but obviously you do it once and really never need to do it again. I will tell you that it's not THAT difficult and takes like 30-40 minutes. Hardest part is making the new gasket stick on the valve cover so you can put the valve cover back on.
Les Bouquins is offline
Old 02-16-2006, 01:28 PM   #4
BluAero's Avatar
Thanks guys.
So you've already done it mr. unkept?
Do I need to buy a new gasket for the valve cover then?
BluAero is offline
Old 02-16-2006, 08:25 PM   #5
JK
JK's Avatar
I'm not convinced you'd need to replace the valve cover gasket...but they're only $10-20, and they dry out/flatten out and start leaking eventually, so I'd advise replacing it.
always a SAAB guy at heart
JK is offline
Old 02-17-2006, 04:08 AM   #6
Editor
It's not always absolutely necessary, but considering they're only like 12 bucks from eeuroparts, it can't hurt. The re-torque is not hard. I just did it my first time about a month ago - should be the last time, too.
Old 08-16-2006, 07:49 PM   #7
Always replace gaskets if your doing this. Ive taken the head off my car 3 times now and I can whip the thing off in just under 2 hours without air tools. If you want to know some tricks to make it EZ, let me know. The trick for remembering the re-torque method is start in the middle top to bottom then move in a circle (or box) clockwise starting on the top right. Okay a little more complicated to remember, but you get my point its how I remember it!
Guteman is offline
Old 04-02-2007, 07:55 PM   #8
burt estep's Avatar
bluaero,use a haynesor saab shop man. 4 the basic stuff torque bolt seq. etc.main points for a sucessful job 1. use new head bolts as they are torque to yield[1 time use only] torque in order 3 stage & use a torque 2 yield guage 4 the last 90 degree pull. lube bolts w/ moly coat grease under the washer & on the bolt threads. use a nut splitter on the exh. manifold nuts - so you don't break studs.
burt estep is offline
Old 04-02-2007, 08:06 PM   #9
JZW
That is what has always confused me, they are supposed to be one time stretch bolts, but they recommend a re-torque after doing a new head-gasket. How can it be a one time stretch bolt and it be recommended to retorque after you have warmed the engine up at least once??? That makes it a two time stretch bolt???
My engine builders book said when replacing head gasket to warm engine up to operating temp, let completely cool and then retorque head bolts. Good for life.... That is twice in my book, so do you do it once and let it go with new bolts or do you do it twice and hope they stretch correctly twice....
John
JZW is offline
Old 04-03-2007, 03:10 PM   #10
burt estep's Avatar
jzw/bluaero,yeh i know what you mean-lots of messed info on h/g's out there. early cars [2.0ltr.] used the cold/hot torque. later cars-don't do it.read my previous posts-under burt estep- on that other saab site-you will see what i mean. clean out the threaded bolt holes[in block] no crud so that you get a good pull
Old 01-13-2008, 03:21 PM   #11
Green9kAERO's Avatar
the sad part is i remember the torque sequence......
60 nm, 80 Nm, 90 degree turn... i do this shit alot
JP
Green9kAERO is offline
Old 01-14-2009, 03:28 PM   #12
93cdeaero's Avatar
Send a message via AIM to 93cdeaero
ypu you do Jp !!!! between home and when we can get your backside to show up at the shop ! lol !!!
93 cde full aero swap in - t5 engine, 5spd trans, interior, susp.and skirts, sas bars 3" turbo to tail, gauges and more to go !!!
93cdeaero is offline
Old 01-14-2009, 04:11 PM   #13
tuner4life's Avatar
Just get arp studs and dont worry about it.
-Jason
1986 Saab 900 Turbo & 1992 Saab 9000 Turbo
tuner4life is offline
Old 01-18-2009, 08:22 AM   #14
ohh yea, where do we buy them i definatly need a set
JP
Old 01-18-2009, 10:10 AM   #15
tuner4life's Avatar
Genuinesaab.com
http://www.genuinesaab.com/catalog/p...f2995121484621
-Jason
Old 07-11-2017, 05:57 PM   #16
you guys always provide helpful advice. thanks
doug knoll is offline
