professional parts sweden DI - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > General 9000 Posts and Information
General 9000 Posts and Information Please post general information pertaining to the Saab 9000.
Old 08-31-2012, 10:02 AM   #1
bergie's Avatar
Saab Direct Ignition Cassette (Red) | Professional Parts Sweden Part Number 28341132 | Free Shipping
anybody try one of these out ?? whats the feedback..?
bergie is offline
Old 08-31-2012, 10:09 AM   #2
dan-the-kid's Avatar
I spoke with someone from RallyHo Motorsport(Mike, Dave? sorry I forgot his name) at SCD.
They have been using one of these DI's in their T5 c900 rally car. I had asked about its "aftermarket" DI and how it was doing. I was told it has all siemens electronics, just assembled in Asia somewhere. Their rally car has put a few thousand miles(IIRC) on the DI and was told was working great.
dan-the-kid is offline
Old 08-31-2012, 10:13 AM   #3
bergie's Avatar
ohh yeah i saw that car, pretty sweet.
but good to know, i just ordered one. I have been running a DI from 06 that is just starting to go on me.
bergie is offline
Old 09-11-2012, 06:57 AM   #4
bergie's Avatar
Be weary of these DI's. This is what happened to mine after pulling it off one time to re-gap my plugs after a week of it being installed.
I have owned saab's for nearly 10 year's now and have never seen anything like this to any DI I have ever owned. Regardless how you pull them off this should not happen, only if you were blatently trying to do so and even that would be hard to do on oem DI's. If your service plug change is an interval of 15k mile's I dont see these lasting to long, nevermind other service that needs to be done to the car.
somebody at eeuro at first wanted me to glue the cover's back on. this is a big no no. The cover has a lot to do with how the ecu detects knock and its sensitivity and accuracy towards it.
I was told that there haven't been any problems with these DI's at all. Which may be true, but i just want you guys to know that these DI cover's should be good for years and years before you see anything like this.
Eeuro agreed to swap me out for a new one and stood behind there one year warrenty. However, I didn't like that they needed to hold another $175.00 from my account for a couple of weeks.
if you look at the 2 good coil plugs you can see just how bad the plastic joint is that meets the 2 parts. These 2 were also nearly on there way out.
I think someone's best bet if they go this route is two swap there cover off there oem DI, and replace it to the new aftermarket PPS DI. This should not affect your warrenty at all i would assume, and if it does it is a big problem.
bergie is offline
Old 09-11-2012, 07:04 AM   #5
Cark's Avatar
holy shit, that is ridiculous!
I'd rather spend $75 for a known good used DI from Steve @ SAAB specific
I love how they want to hold $ from you as well... unless you need it immediately, I'd box it up right away and send it to them, and as soon as it gets to them hopefully they can send you out a NEW one. Save the $175 and then who knows how long it would take for them to refund you that $.
Glen won a T7 DI at SCD, and I took a quick look at it and was very dissatisfied at least with how the finish looked on it. It literally looked like someone just sprayed it with a rattle can...
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 09-11-2012, 07:08 AM   #6
Wagon Shaggin'
Saabeh's Avatar
When you get the new one, will you be putting an OEM plastic cover on it?
Saabeh is offline
Old 09-11-2012, 10:01 AM   #7
mike d's Avatar
Sadly after this even happened, i called one other person i knew who was putting a china-di though a trial run. And the news that came back was not good at all.
As of now i know two people who have tried these DIs, both of them have not ended well. Spend the extra money on a genuine saab DI. I hate it when manufacturers dont produce quality aftermarket products
MikeDTuning.com
mike d is offline
Old 09-11-2012, 11:52 AM   #8
Supporting Vendor
Hello valued Saablink members.
The DI subject has always been a hot topic with Saab customers. Here are the facts.
Proparts aftermarket DI cassettes have a lower failure rate then Genuine DI cassettes. We have sold hundreds of each.
The issue illustrated here has been documented and resolved in the latest batch of cassettes being shipped to us right now. The lower connector extension can be reinstalled with or without epoxy and maintain complete integrity. I completely agree that the original lower housings were one molded piece and you could pull as hard as you like from one end and remove the DI without issue. IF you don’t pull up evenly on the Proparts unit you can indeed separate the lower terminal extensions from the end opposite of where you pull upward on. This does not render the unit defective. You simply reinstall the terminal end and reinstall the unit….I personally guarantee that it will function correctly and will warrantee any unit that does not.
Proparts will warrantee defective DI cassettes for a full year….Saab won’t warrantee them at all.
Proparts has and will continue to accept feedback on ANY product….they do care about making quality products that represent a value to Swedish car enthusiast and we are proud to offer their products.
eEuroparts.com will warrantee Genuine Saab or Proparts DI units for a full year. There are two methods of exchange….we will write a new order and a include a no charge fed ex label (US customers) for the return and give %100 refund once the defective unit is returned or we will email you a FedEx label to return the unit for a no charge exchange once the item is returned.
The eEuroparts.com team truly appreciates the opportunity to serve Saablink members and values the feedback that can only come from our friends and customers that use our products. Please keep us informed of any issues and we will continue to strive to earn your business.
Dean Bergeron
Customer Service
eEuroparts is offline
Old 09-11-2012, 12:03 PM   #9
mike d's Avatar
Isnt that saab NA? I.E. it will never see boost? so the chances of it misfireing are quite low?
MikeDTuning.com
mike d is offline
Old 09-11-2012, 12:10 PM   #10
Cark's Avatar
correct.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 09-11-2012, 01:55 PM   #11
bergie's Avatar
Has anyone else run one of these DI's yet ? is there any short use failure's.(besides the bottom shield) I am tempted to just return the new DI and put my credit towards an OEM one.
Mike what was the new's you heard from that other person giving one of these a go ?
bergie is offline
Old 09-11-2012, 07:01 PM   #12
132417SAAB's Avatar
my best guess would be a customer with a tuned car who managed to kill one these di's very soon
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 09-12-2012, 09:46 AM   #13
bergie's Avatar
the DI seemed to work well on my car, I just have had issues with the lower section. If i get misfiring I'll be sure to let people know.
I am currently running my OEM right now however.
bergie is offline
Old 09-26-2015, 05:32 PM   #14
ninehundredt's Avatar
I'm getting ready to purchase a red DI for my Trionic 5 conversion on the SPG. Has anyone had any more bad experiences with these aftermarket units? The OEM SAAB ones are still around $400 new. Bleh.
ninehundredt is offline
Old 09-26-2015, 07:10 PM   #15
Send a message via AIM to jgg54
Maybe I'm one of Mike's experiences with a ProParts DI. Mike did a T5 conversion on my 93 Turborag using the new PP DI that I provided. The results were less than satisfying but only because of the PP DI
Eeuro swapped out the PP DI for an SEM with a full $ exchange and the result of swapping an OEM DI made all the difference in performance and even surprisingly corrected an iffy tach to a rock solid reading.
I will only go OEM when the need arises.
jgg54 is offline
Old 11-04-2015, 05:09 PM   #16
jssaab's Avatar
I just got a new SEM DI from Car Quest for 180 with a coupon
jssaab is offline
Old 11-05-2015, 10:08 AM   #17
soccerrplyr's Avatar
is rockauto's shipped to your door for around 154 with 5% off coupon not available anymore
1999 9³ Stage 18t
2000 9³ Stage 19t
2005 CRV
soccerrplyr is offline
Old 11-05-2015, 10:12 AM   #18
Wagon Shaggin'
Saabeh's Avatar
Still around, search for: AIRTEX / WELLS 5C1762
Saabeh is offline
Old 11-05-2015, 01:17 PM   #19
mike d's Avatar
Reds tend to be more money, Red Di's are still 3-400$ just about anywhere, whereas blacks can be found 150-200 pretty easly
MikeDTuning.com
mike d is offline
Old 11-06-2015, 05:39 AM   #20
There are airtex/wells T5 cassetts, but like Mike said, they're not as cheap.
Although I think advance sells them, and there's always coupon codes you can add.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
