Saab 9000 Recall List - 1986 -1998 - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > General 9000 Posts and Information
General 9000 Posts and Information Please post general information pertaining to the Saab 9000.
Old 10-27-2010, 05:28 AM   #1
BurnsSide42's Avatar
Post Saab 9000 Recall List - 1986 -1998
1986 Saab 9000 Recalls:
Item Affected: ELECTRICAL SYSTEM:WIRING:INTERIOR/UNDER DASH
Date Announced: 10/29/1986
Description of Recall:
THE WIRING HARNESS MAY CHAFE AGAINST THE WINDSHIELD WIPER MOTOR BRACKET. CONSEQUENCE OF DEFECT: IF A SHORT CIRCUIT DEVELOPS, IT COULD RESULT IN A FIRE.
Action Needed To Fix It:
AFFIX TWO RUBBER STRIPS TO THE VERTICAL EDGES OF THE WINDSHIELD WIPER MOTOR BRACKET.
Item Affected: ELECTRICAL SYSTEM:IGNITION:SWITCH
Date Announced: 1/16/1990
ABRASION ON THE PRINTED CIRCUIT CARD IN THE COMBINATION NEUTRAL SAFETY/BACKUP LAMP SWITCH OPERATED BY THE AUTOMATIC TRANSMISSION GEAR SELECTOR MAY CAUSE RESIDUE TO COLLECT IN ELECTRICAL AREA ON THE CIRCUIT CARD.
ADD AN ELECTRICAL CIRCUIT, INCLUDING A RELAY, TO THE BACKUP LAMP CIRCUIT TO REDUCE THE CURRENT THAT CAN FLOW THROUGH THE COMBINATION SWITCH.
1987 Saab 9000 Recall:
1988 Saab 9000 Recalls:
Item Affected: VEHICLE SPEED CONTROL
Date Announced: 4/12/1988
THE BALL CHAIN BETWEEN THE CRUISE CONTROL VACUUM REGULATOR AND THE ACCELERATOR PEDAL ARM MAY CATCH ON THE VACUUM REGULATOR ATTACHMENT CLIP.
A PLASTIC CAP WILL BE INSTALLED OVER THE VACUUM REGULATOR CLIP TO COVER THE OPENINGS.
Item Affected: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS
Date Announced: 11/28/1989
THE ROUTING OF THE THROTTLE KICKDOWN CABLE COULD ALLOW CHAFING TO OCCUR BETWEEN THE CABLE AND ANY ONE OF THREE STEEL BRAKE FLUID LINES NEAR THE VALVE BLOCK OF THE HYDRAULIC BRAKE UNIT.
CHANGE CABLE ROUTING AND INSTALL NEW ATTACHMENT BRACKET TO PREVENT CHAFING.
1989 Saab 9000 Recalls:
Item Affected: FUEL SYSTEM, GASOLINEELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Date Announced: 12/6/1988
FUEL FILTER MAY NOT MEET THE SPECIFICATION CONCERNING LEAKAGE CRITERIA DUE TO LOW TEMPERATURE DURING THE GLUING PROCESS.
REPLACE FUEL FILTER.
1990 Saab 9000 Recall:
1991 Saab 9000 Recall:
Item Affected: POWER TRAIN:AUTOMATIC TRANSMISSION
Date Announced: 1/15/1991
IMPROPER ASSEMBLY COULD CAUSE THE BALL OF THE GEAR SELECTOR ARM NOT TO BE PROPERLY FIXED TO THE SOCKET ON THE END OF THE GEAR SELECTOR CABLE; GEAR SELECTOR ARM COULD SEPARATE FROM THE GEAR SELECTOR CABLE AT THE BALL SOCKET JOINT.
PROPERLY SEAT GEAR SELECTOR ARM BALL IN THE SELECTOR CABLE SOCKET AND SECURE BY A LOCK RING INSIDE THE SOCKET.
1992 Saab 9000 Recalls:
Item Affected: AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Date Announced: 5/12/1999
VEHICLE DESCRIPTION: PASSENGER VEHICLES. MOISTURE CAN ENTER THE AIR BAG INFLATABLE RESTRAINT ELECTRONIC CONTROL MODULE (ECM) AND CAUSE CORROSION ON PORTIONS OF THE ECM PRINTER CIRCUIT BOARDS.
DEALERS WILL INSPECT THE EXTERIOR OF THE ECM. IF THERE IS NO INDICATION OF MOISTURE, A COVER WILL BE INSTALLED OVER THE ECM. IF THERE IS INDICATION OF MOISTURE, THE DEALER WILL REPLACE THE ECM AND INSTALL A COVER OVER THE NEW ECM.
Item Affected: ENGINE AND ENGINE COOLING:COOLING SYSTEM
Date Announced: 7/13/1994
DURING LOW ENERGY FRONTAL IMPACT COLLISIONS, THE FRONT CROSSMEMBER CAN CONTACT THE METAL TUBING PORTION OF THE COOLER HOSE ASSEMBLY; AND/OR THE HOSE ASSEMBLY CAN BREAK AND LEAK OIL ONTO THE HOT EXHAUST MANIFOLD OR THE TURBOCHARGER.
DEALERS WILL INSTALL A PROTECTIVE COVER WHICH WILL PROTECT THE COOLER AND HOSES FROM OTHER STRUCTURAL COMPONENTS IN LOW ENERGY FRONT IMPACTS.
Item Affected: SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE
Date Announced: 4/4/1995
MOISTURE CAN FOLLOW THE ELECTRICAL HARNESS AND ENTER THE PRESSURE SWITCH CONNECTOR CAUSING CORROSION AND MALFUNCTION OF THE SWITCH.
DEALERS WILL INSPECT THE ELECTRICAL CONNECTIONS TO THE ABS PRESSURE SWITCH TERMINALS FOR CORROSION AND INSTALL A SHRINK HOSE TO THE WIRING HARNESS TO AVOID MOISTURE ENTERING THE CONNECTION. PRESSURE SWITCHES WITH CORRODED CONNECTORS WILL BE REPLACED.
Date Announced: 2/17/1994
THE FUEL FILLER AND TANK VENTILATION HOSES MAY DEVELOP CRACKS UNDER THE SECURING HOSE CLAMPS, RESULTING IN FUEL LEAKAGE.
THE FUEL FILLER AND FUEL VENTILATION HOSES WILL BE REPLACED WITH NEW HOSES. THE FIVE SECURING HOSE CLAMPS WILL BE REPLACED BY A NEW TYPE WITH A SHIELD THAT PREVENTS DAMAGE TO THE HOSE WHEN TIGHTENED.
REF: http://www.dealerrater.com/recalls/Saab/9000/
BurnsSide42 is offline
Old 10-27-2010, 05:29 AM   #2
Post Part 2
1993 Saab 9000 Recalls:
Item Affected: EXTERIOR LIGHTING:BRAKE LIGHTS:SWITCH
Date Announced: 6/22/1994
A NUMBER OF BRAKE LIGHT SWITCHES HAVE AN OVAL-SHAPED PISTON WHICH CAN GET STUCK UNDER CERTAIN CONDITIONS. OTHER SWITCHES WERE MOUNTED SO THAT BOTH LOCKING TABS ARE NOT COMPLETELY ENGAGED IN THE MOUNTING BRACKET. IF ONE SIDE IS NOT ENGAGED, THE SWITCH IS MISALIGNED WITH THE PEDAL MECHANISM AND CAN BIND THE PISTON MOVEMENT, WHICH CAN CAUSE THE BRAKE LIGHT SWITCH TO STICK IN THE "OFF" OR "ON" POSITION.
DEALERS WILL INSPECT BRAKE LIGHT SWITCHES. FOR VEHICLES WITH THE OVAL-SHAPED PISTON AND FOR VEHICLES WITH MISALIGNED BRAKE LIGHT SWITCHES, THE BRAKE LIGHT SWITCH WILL BE REPLACED.
1994 Saab 9000 Recalls:
Date Announced: 5/20/1994
ONE OF THE BULBS IN EACH OF THE BRAKE LIGHT LOWER OUTBOARD LAMP ASSEMBLIES MAY NOT HAVE BEEN PROPERLY WIRED, RESULTING IN IMPROPER TAIL LIGHT ILLUMINATION ON BRAKE APPLICATION. THIS DOES NOT CONFORM TO THE REQUIREMENTS OF FMVSS NO 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT."
DEALERS WILL MODIFY THE BRAKE LIGHT OUTBOARD LAMP ASSEMBLIES TO MEET FMVSS REQUIREMENTS.
1997 Saab 9000 Recall:
Item Affected: EQUIPMENT:OTHER:LABELS
Date Announced: 6/30/1998
VEHICLE DESCRIPTION: PASSENGER VEHICLES. THE AIR BAG ALERT LABEL ON THE DRIVER SIDE VISOR WAS OMITTED. THIS DOES NOT CONFORM TO THE REQUIREMENTS OF FMVSS NO. 208, "OCCUPANT CRASH PROTECTION."
OWNERS WILL BE PROVIDED WITH AN ALERT LABEL TO BE INSTALLED ON THE VISIBLE SIDE OF THE DRIVER'S SUN VISOR. IF AN OWNER SO DESIRES, THEIR DEALER CAN INSTALL THE LABEL FOR THEM.
1998 Saab 9000 Recall:
