Cel Blink Code?? - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > General 9000 Posts and Information
General 9000 Posts and Information Please post general information pertaining to the Saab 9000.
Old 05-11-2007, 09:08 PM   #1
Cel Blink Code??
Anyone know what my car is trying to tell me??
If I turn the key on and leave it for a few seconds the Cel starts to blink...It blinks 4 times. I know this isnt a true Diagnostic tool. And it is more than likely just a starting point.
PhatDaddy is offline
Old 05-11-2007, 09:25 PM   #2
mcrowley's Avatar
2 flashes - Manifold Absolute Pressure sensor
3 flashes - Intake Air Temperature sensor
4 flashes - Coolant Temperature Sensor
5 flashes - Throttle Position Sensor
6 flashes - O2 Sensor
7 flashes - Adaptation
8 flashes - Purge valve
9 flashes - ECM fault
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 05-12-2007, 07:53 AM   #3
Is that clearable with disconnecting the battery? I fixed all the fans and such. The temp gauge seems to work correctly.
And thanks Mike...Maybe this could be made a stickey....It isnt anywhere in the 9000 forums....Till now that is.
Old 05-12-2007, 09:14 AM   #4
mcrowley's Avatar
I don't know if its clearable just by disconnecting the battery. You might need an isat/tech2 to clear the code....or a new coolant temp sensor.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 05-12-2007, 09:15 AM   #5
NahumCC's Avatar
I thought the flashing codes only applied to the OBD I cars. Phat what year is you 9k.
2013 FR-S
NahumCC is offline
Old 05-12-2007, 09:16 AM   #6
mcrowley's Avatar
Its a 1990
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 05-12-2007, 03:19 PM   #7
Newf9000's Avatar
From saab9000.com....
Procedure (DI/APC)
To obtain a fault code reading:
1. Turn the ignition switch to the Drive position without starting the engine.
2. In about two seconds the CHECK ENGINE light will go out for about 2 seconds. It will then begin flashing the fault code.
Fault codes (DI/APC)
Fault code/ Fault
2 Internal memory check failed
3 Watchdog (control module fault).
May also be caused by a defective spark plug or ignition module.
4 Knock sensor
5 Engine load signal from LH or MAP sensor incorrect
Newf9000 is offline
Old 07-01-2011, 12:40 PM   #8
Galvas's Avatar
This tread is helping me right now...
Mine is trowing the 4 cel ( DI/APC )
he synthoms appears to be the knock sensor...
( its the crankshaft positioning sensor that does the knock sensor right?? )
Galvas is offline
