I'm new to 9-5's - The Saab Link Forums
Old 12-19-2014, 04:58 PM   #1
I'm new to 9-5's
I bought my first 9-5 today for super cheap. What am I looking for in terms of reliability? Its an 00-02 5 speed with all original parts. 203k on the clock.
SS929k is offline
Old 12-19-2014, 10:18 PM   #2
DrewP's Avatar
Mine is almost 290k with solid service record and still going strong, it's all about how they were treated.
DrewP is offline
Old 12-20-2014, 06:37 AM   #3
The people I got it from seem like they took really great care of it and when I took it for a spin it seemed pretty solid. It needs a little work here and there though but thats pretty inevitable when your in New England.
SS929k is offline
Old 12-20-2014, 06:43 AM   #4
You might wanna drop the oil pan to check for sludge but if its lasted this long it's probably ok
Where in New England are you? There's a lot of us on here
Snowcat77 is offline
Old 12-20-2014, 10:49 PM   #5
I'm in MA and the oil pan was the first thing I was going to drop. I have been reading a lot about that on the forums. Seems like that is a huge issue on these cars. When I bring it home later today I'm going to give it another look over. I spent a great amount of time at the owners house looking for fluid leaks defects and all that good stuff mechanically. I was listeing for misfires and exhaust leaks. I checked suspension and drove it around seeing if the gears were smooth and all. My main consern was the car running terribly and the check engine light being on. I lucked out, it passed inspection last month and all the electricals worked accept the screen for the ac controls but that doesn't bother me.
SS929k is offline
Old 12-21-2014, 02:43 AM   #6
Cark's Avatar
230k on my 02 and it's running strong. I agree 100% with Drew, it's all about how they were treated.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 12-21-2014, 12:08 PM   #7
spanknut's Avatar
You can tell alot by seeing how much varnish is under and on the inside of valve cover . Gives you an idea . If its nasty pull the pan if its nice you shold be ok
spanknut is offline
Old 12-21-2014, 03:54 PM   #8
I brought the car home today. Drove smooth. A little shake in the steering wheel going 75-80mph. Wind screen is cracked at the bottom, theres a little rattle coming from somwhere near the glove compartment (nothing compared to the rattle in my 9000 though) and the exhaust has a little leak. Other than that the car is pretty good. No check engine light (drive back to my house was less than 70 miles), turbo spools up nice, cruise control works. The heater control display is dim in some areas, speakers will definetly be replaced and I think an in-dash head unit will be swapped in. I havent made up my mind yet on that. I have a few plans but I think I will keep it simple because I want this to be a daily driver while I restore my 9000 (transmission went boom so why not go t5 now). I have been looking at a couple transmission jobs on the forums and I havent really seen one that wasn't short. Is it really that big of a pain doing such a job on the 95's? I wouldn't have thought it would be more terrifying than the NG 900 or 9000's.
SS929k is offline
Old 12-21-2014, 04:08 PM   #9
I need to give it a full detail but other than that I'm happy with it.
SS929k is offline
Old 12-23-2014, 10:38 PM   #10
Okay I've been reading a lot on this forum and one thing that makes me nervouse is the Tech II scanner. Can I only use a Tech II in order to program certain things in the car or can I get away with a snap on scan tool?
SS929k is offline
Old 12-24-2014, 05:29 AM   #11
Looks like a nice car. All the issues you mention sound common for all older cars in general: exhaust leaks, rattles, wheels out of balance. Nothing major.
You do need a TechII for some things, but what exactly are you trying to program?
BuHuSPG is offline
Old 12-27-2014, 09:23 AM   #12
I have a TD04 from a 95 and I want to swap it. I'm reading that I would need a tech II t marry parts and I would assume you would need to marry the ECU from a TD04 ECU to the car. Unless a tune of the stock ECU is better?
SS929k is offline
Old 12-28-2014, 06:37 AM   #13
Wagon Shaggin'
Saabeh's Avatar
Fortunately for you, Mike D lives in MA. He has a Tech II and is a good tuner. Guy is a one stop shop ESPECIALLY for 9-5s.
Saabeh is offline
Old 12-28-2014, 07:54 PM   #14
I have spoken to mike earlier this year. Seems like a cool dude. If he lives in my area I should treat him to some brew while doing tech II stuff. I hope he still has the same number, I was originally going to see if he could sort out wiring for T5 on my 9K but why not get a little extra easy power from the 95 for a daily driver. So back to the oil pan/ sludge thing. If I find a lot of sludge in the oil pan, would it be wise to change the pcv system as well as cleaning the screen of the oil pan.
SS929k is offline
Old 03-20-2015, 07:35 PM   #15
So I have a little concern. I just got done doing the oil pan cleaning thing. I put everything back together nice and tight, I put oil in the car, then I started the car and I got the sweet sound of caution light and my oil light is on. I let the car run for a bit but it did not go away. I checked for leaks and I did not see any.
SS929k is offline
Old 03-21-2015, 03:39 AM   #16
Drew in Houston's Avatar
Did you replace the o-ring on the feeder tube? There's only 2 places to leak internally for the pump pickup, at that o-ring and the area where the pan meets the block at the pump.
Sounds like you should pull it back apart before running it more.
Drew in Houston is offline
Old 03-21-2015, 06:14 AM   #17
I did not replace the o-ring at the tube. I am going to have to do that Monday night. Since I'm doing all this extra stuff I might just pop in my td04 since my exhaust is going to be off again.
SS929k is offline
Old 03-24-2015, 11:09 PM   #18
OK so I took the pan off again and when I did, that pipe that goes across the block fell out with it. That worries me a little since I ran the car for a bit after the first time I cleaned the pan. Moving forward, I did not need to replace any o-rings and thank the Saab gods that the weird oil feed pipe didn't get damaged. While on the hunt for the locktite 518 or permatex 51817 I came up negative in my area which was a real bummer so I'm going to reuse the oil pan gasket I purchased for the initial job (I'm not a fan of reusing gaskets due to past experiences) and I'm praying to the Saab gods that I'll be fine especially since Carlisle is right around the corner.
SS929k is offline
Old 03-25-2015, 05:23 AM   #19
oliversexpedition's Avatar
Order off Amazon or similar site, its worth it.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 04-11-2015, 03:12 PM   #20
I bought a double din in-dash receiver for my car the other day and it states "OEM wired remote" for steering control buttons. So when I do more research it basically says I would be able to use my steering wheel controls. Now my question is, do I still need a steering wheel control module or do I just need to find that specific wire for the steering control?
SS929k is offline
