Buying new rotors, need advice. - The Saab Link Forums
Old 07-21-2014, 09:44 AM   #1
It's new rotor time! I only know of Eeuroparts, FCP and GS for buying parts but I have no idea what's comparable to the Aero rotors I've got on there. (Nor do I know how thick they are..) Myle is clearly the cheapest but I'm looking for something more performance oriented. (Not a track car, just stop light racer..) Drilled would be preferable.
I found these too but they seem awfully cheap.. Saab 9 5 2001 Brake Kits - Drilled & Slotted Rotors
'01 Aero Wagon.
Slabonator is offline
Old 07-21-2014, 09:55 AM   #2
B202nut-2.0's Avatar
I never known any rotor, simple or fancied ( useless slots or foolish drilled holes)
That didn't stop a car.
Prolly not worth much brain power mate.
Skip on over to autozone and get what you need
B202nut-2.0 is offline
Old 07-21-2014, 10:25 AM   #3
G-Thanks? So vented rotors are foolish.. I'm just curious as to what others have used. Typically discussion is encouraged on forums, and being new to SAAB (and wrenching in general) I like asking questions.
Old 07-21-2014, 10:32 AM   #4
Well maybe not foolish, but not necessary.
Old 07-21-2014, 11:26 AM   #5
DrewP's Avatar
There is a difference between vented / cross-drilled / slotted. Your 9-5 has vented rotors, the slotted ones meant for a Viggen will fit if you have Aero caliper brackets (they are slightly larger diameter than regular 9-5 / 9-3 rotors).
Stock stuff is fine - do NOT get the autozone house brand stuff tho. I've seen so many of those with enough runout right out of the box that you can feel the pulsation in the pedal.
Zimmerman / Brembo / ATE are all good brands if you can find them for a good price.
DrewP is offline
Old 07-21-2014, 11:52 AM   #6
Car dealers are in the business to sell cars, anything that catches a consumers eyes and helps sell cars, like fancy drilled and slotted rotors,.
will they stop you any better than a generic set, I guess you should give it a go and see for yourself.
My money says you won't feel not even the slightest difference
But if the long term elders here say spend your money on the fancy stuff then you aught better listen.
Me, I just know better.
My money says the care had no clue what type of rotors you run as long as there is something there for the pads to grab
Autozone stuff usually has a warranty, prolly lifetime...
Not promoting AZ but the point is it prolly spent matter what you replace with as long as decent for stopping
Gudday
Old 07-21-2014, 12:09 PM   #7
Wagon Shaggin'
Saabeh's Avatar
rockauto.com
Centric rotors, done!
Saabeh is offline
Old 07-21-2014, 05:51 PM   #8
jssaab's Avatar
True get decent rotors from a good manufacturer
Gudday
Vented rotors are stock and do make a difference, get them ( slotted and drilled are nto wirht it unless you are going for a look
Originally Posted by Saabeh View Post
rockauto.com
Agreed Centric are the bomb and cheap as well
jssaab is offline
Old 07-21-2014, 05:57 PM   #9
Wagon Shaggin'
Saabeh's Avatar
Centric Premium rotors with "C-Tek" coating on the non-pad surfaces from rockauto:
Everything shipped was cheaper than fronts locally.
Saabeh is offline
Old 07-22-2014, 04:54 AM   #10
Ditto on Centric, or Brembo (if you can snag a coupon). ATE is OEM quality too. I've had variable results with Zimmerman.
And re: vented rotors. Ignore any advice that tells you "all rotors are the same" and listen to DrewP on this. Vented rotors are preferable because they don't overheat as fast and the heat dissipates quicker. It's a nice bit of safety margin for a loaded car, which wagons often are.
Some of the 9-5 Aero Wagons had vented rear rotors from the factory for this exact reason. Some of us with modded cars have changed over to the vented rotors because of the increased stopping power.
Old 07-22-2014, 05:08 AM   #11
You may know better for a car that uses technology straight from the 1970s, but you're a bit clueless about what the OP's car needs. Vented rotors aren't "fancy stuff" -- they're OEM fitment for the OP's car because of its weight and power, and yes, there's a difference. That's why they're on the car in the first place.
Slotted rotors can actually improve braking performance, especially in the wet, by exposing new pad surface quicker, but it wears the pads down faster. It's a trade off that's likely not necessary on most street cars, but offers improved looks and performance.
Drilled rotors are mainly for looks, unless it's a really expensive ceramic compound racing rotor. Skip.
That said...I'd stick with the OEM blank style vented rotors like the ones in Saabeh's picture....
Last edited by mike saunders; 07-22-2014 at 05:22 AM. Reason: Toned down for peacefulness
Old 07-22-2014, 05:16 AM   #12
soccerrplyr's Avatar
Originally Posted by mike saunders View Post
I don't want this to become a pissing match, but for all the reasons I mentioned above, you're completely clueless about what the OP's car needs.
There needs to be some kind of a disclaimer on anything you post that doesn't involve C900s, similar to the warning labels on cigarettes. You need to advise people who read those posts that the info contained within may not be accurate and may cause wasted time, squandered money, injury, loss of limbs, and death.
This is probably why saabcentral banned him...must have irritated Scott
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 07-22-2014, 05:24 AM   #13
Lol....
Old 07-22-2014, 05:31 AM   #14
Wagon Shaggin'
Saabeh's Avatar
I think there is a communication breakdown between the words "vented" and "slotted/drilled."
Saabeh is offline
Old 07-22-2014, 05:33 AM   #15
Thanks for the advice Drew, jssaab, and sabbeh! The Centric C-Tek and E-Coating is a pretty interesting method for keeping the rust off the non-pad portions. Went with the C-Tek's, dirt cheap too! Full set front and rear for $115 shipped. Not bad.
Edit* just saw the above few posts. I appreciate the added clarification.
Old 07-22-2014, 05:40 AM   #16
Yeah, that's why I went back and edited with a cooler head. I need to approach those posts like I'm talking to an elderly neighbor about why her computer can't do The Google without an internet connection.
Can't go wrong with those. Great value for the price. Stoptech (noted maker of aftermarket big brake kits) uses Centric rotors for their builds.
(Just make sure you specifically ordered the size for your Aero wagon, which might have different fitment in the rear than that year's Aero sedan...)
Old 07-22-2014, 08:11 AM   #17
All that to say you would not fit the ones you claim are made for the car?
Is that I talk funny, because it basically sounds like you don't agree with me to agree with me??!!!???
Or is it only rite if someone else says it?
Cause honestly you said the same thing I did ..
As mentioned above, my point was the Op doesn't need what came on the car, as well Saabeh pointed out and you went to Cali and back to reassure.
Old 07-22-2014, 08:22 AM   #18
I'm no, this is a prime example.
I said the OP didn't need fancy rotors and aftermarket set would do just done
I get all these long engineering responses trying to down play my suggestion only to agree a generic set of rotors would do just fine
You all can go fuk yourselves I didn't say anything wrong
That's why hey ban me, cause I take kindly to the gang banging
Specially when you only repeat what I said
Now fuk off!
How you like the apples????
Old 07-22-2014, 08:27 AM   #19
Thank you for speaking the saablink language to your little robots.
Exactly my point. Why spend OEM parts money when you can get the same quality in an aftermarket part
At least you aren't like the rest of these fuk licks, you clearly understood my point.
Thanks for being rational.
Old 07-22-2014, 08:56 AM   #20
Anytime I go to a parts store they ask for make model and year of the car.
If it's a larger chain store, they usually flip The computer screen around so the consumer can get a visual.
The list of choices are usually OEM and several after market choices.
It is always explained that aftermarket parts were designed to operate with equal quality of the OEM.
It's usually the cost difference that make people choose aftermarket...
saab is nothing special, an it is totally uneseccary to put OEM rotors on when aftermarket would do just fine.
It's a Saab, and a GM one at that, do you really thing there is a specific part for te car?
Hell, I bet it cross references with any other GM car in its class
As mentioned earlier, crosses drilled and or slotted rotors on street daily drivers are useless waste of money.
Go ask your dad....
If your on a track that's a different story and even then may not be necessary.
Stop drinking the kool aide boys!!!!
